Current generation Blu-ray disc playback software-what are you using? - AVS Forum | Home Theater Discussions And Reviews
Old 06-11-2013, 02:19 PM - Thread Starter
jcruse's Avatar
Liked: 27
I recently rebuilt my HTPC, and had previously used Arcsoft TMT3. It worked really well for me, and I really liked the MCE integration. On the new HTPC I'm still using WIndows 7, but I upgraded to TMT6, and it has been very disappointing. For one thing, it really slows down my boot times (a well-documented issue), but it's also responds verly slowly during playback to pause/FFW/RW buttons, which TMT3 did just fine before.
So I'm looking to move away from Arcosft, but was wondering what others were using for Blu-ray disc playback. I know of PowerDVD 13 and WinDVD (version #?). Also why did you choose that application over the others?
I'm looking for streamlined MCE integration (insert a disk, and it just starts playing), and full blu-ray playback capability (menus, BD-Java, etc.). I'm also outputting analog audio, so any app that doesn't down-sample analog would be preferred (I know arcosft TMT3 down-sampled, but it didn't seem to affect the sound that significantly).
jcruse is offline
Old 06-11-2013, 02:21 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
IF TMT3 worked well for you why not just use it?
Sammy2 is offline
Old 06-11-2013, 02:45 PM - Thread Starter
jcruse's Avatar
Liked: 27
While my TV is not 3D, I'd like to be able to play 3D blu-rays (as I understand, you can convert a 3D movie to 2d for playback, but TMT3 can't play 3D disks at all...)
jcruse is offline
Old 06-11-2013, 03:06 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I am using the newest version of MakMKV (beta)
Bluray playback software is for noobs. Discs are crap. I'm too lazy to take care of them, organize them, or get up and put one in or take one out.
Mfusick is offline
Old 06-11-2013, 05:28 PM
A9X-308's Avatar
Quoted: 1300 Post(s)
Liked: 964
MPC-HC or Potplayer for playback and MakeMKV to rip either DVD or BD. Chosen because they are small, resource light (without added filters in MPC at least) and free but they don't autoplay on disc insertion which is a feature I find annoying anyway. I'm happy to select from a menu. MakeMKV is a killer app, sort of like what DVDShrink could have become with more development and is even easier to use. Assassin has a great how to on his website.
I also have no problems using discs, except that living in an apartment I'm running out of space to store them (as well as all my books and LPs) so I'm going to rip all my SD discs onto drives and later BRs when I run out of space for them too. Eventually, I can see them all being on HDD.
A9X-308 is offline
Old 06-11-2013, 06:01 PM
acejh1987's Avatar
Not sure if the above posters missed this but MakeMKV isn't going to be any good in this situation, its no good if you want full menu's and it couldn't play straight from the disc anyway.
In my experience I didn't really like PowerDVD or WinDVD, I didn't find them any better than TMT.
I'm using TMT 5.3.1.146 and it seems to be working pretty good for me, I tried TMT6 but I also rolled back because of the boot time issue (Although this looks to be fixed in the latest build)
Another option if you could live without the menus is something like DVDFab Passkey/AnyDVD HD which will allow the disc to be played in non commercial software like MPC/XBMC/VLC etc (Main Movie Only though).
acejh1987 is offline
Old 06-11-2013, 06:55 PM
emcdade's Avatar
Quoted: 141 Post(s)
Liked: 141
My solution: buy a reference quality Panasonic blu ray player for about $100. Experience none of the headaches of crap BD software and have perfect 1080p/24 output and outstanding chroma resolution.
When you're done caring about menus and extras, rip to your htpc and enjoy having all your media a button press away.
Sammy2 and sawfish like this.
emcdade is offline
Old 06-11-2013, 07:17 PM
Chronoptimist's Avatar
Liked: 532
I use AnyDVD and JRiver Media Center 18.
I use it over anything else because it handles all my media playback with the highest fidelity possible, is highly customizable, and has great library management tools.
MakeMKV is also a good solution for a HTPC in addition to (or instead of?) AnyDVD because it lets you rip the main feature without having to store all the menus, extras, languages you don't speak...
These two things are in opposition of each other. Having support for BD-J and menus means that you are stuck sitting through trailers and unskippable sequences before you can play the film. JRiver doesn't use the menus, and starts playback of the film immediately with no ads etc.
Chronoptimist is offline
Old 06-11-2013, 08:32 PM
cybrsage's Avatar
Liked: 154
TMT5 for my Win7 HTPC, TMT6 for my gaming machine.
cybrsage is offline
Old 06-11-2013, 09:18 PM
robnix's Avatar
Quoted: 664 Post(s)
Liked: 495
Real men have enough storage to rip everything to full iso ;-)
Besides, there is no viable solution for 3D playback on an HTPC other than bluray playback software. Stereoscopic player still won't do simple things like exit on stop like MPC-HC does.
Looky here!
robnix is offline
Old 06-12-2013, 08:44 AM
mslide's Avatar
I use a cheap, stand-alone Blu-Ray player. I haven't had any Blu-Ray troubles since. Best $60 I spent for my home theater.
mslide is offline
Old 06-12-2013, 12:22 PM
Polemides's Avatar
J. River MC18. Best audio handling around, IMO. Never had a problem with Blu-Ray folder structure, either.
I kept hoping that the proliferation of YouTube would kill on-disc trailers, but alas, no. If I wanted to see trailers on the big screen, I'd be at the movie theater.
Polemides is offline
Old 06-12-2013, 12:36 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Mfusick is offline
Old 06-12-2013, 01:19 PM
cybrsage's Avatar
Liked: 154
cybrsage is offline
Old 06-13-2013, 12:10 PM
sycochkn's Avatar
PDVD 10, and XBMC 12. Backup with AnyDVD.
sycochkn is offline
Old 06-13-2013, 01:11 PM
Roussi's Avatar
Quoted: 45 Post(s)
Liked: 36
TMT 5.3.1.144 in Windows 8-64 and 7-64, for BDs, 3D with menues and HD-DVDs.
The standalone application works (with Any DVD running and occasional non-critical glitches); the WMC version is hopeless.
WMC for everything else.
Used to have PDVD10 on Win7 for the frame-rate conversion feature and good dvd upscaling, but gave up on it and did not re-install it after the Win 8 upgrade.
Roussi is offline
