Solaris 11 zfs server recommendation for media server - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 38 Old 06-24-2013, 02:24 PM - Thread Starter
dimyself is offline
post #32 of 38 Old 06-24-2013, 03:17 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
Looks the same to me, By part number and description, although the picture is of a different motherboard.
The last letter is packaging. The -O means Retail. The -B means Bulk.
From what I have read, these Supermicro boards are real picky about memory.
This is what I have in my board.
http://www.superbiiz.com/detail.php?name=D38GE1600S#
dimyself likes this.
Andy_Steb is offline
post #33 of 38 Old 06-24-2013, 03:59 PM
robnix's Avatar
Quoted: 664 Post(s)
Liked: 495
We build supermicro based storage servers for bulk backup and archiving of data. Most are using XEON E-54** series processors. I put Kingston Value RAM in all of them. Kingston has a handy tool that will let you search by motherboard model so you buy the right RAM:
http://www.kingston.com/us/memory/search/options/
Looky here!
robnix is offline
post #34 of 38 Old 06-24-2013, 05:13 PM - Thread Starter
dimyself's Avatar
Well I got the cpu, motherboard, and ram!! I ended up getting the kingston ram on their page...can't wait for it all to arrive biggrin.gif
dimyself is offline
post #35 of 38 Old 06-24-2013, 05:36 PM
jmelan's Avatar
Quoted: 57 Post(s)
Liked: 33
i have used a couple of supermicro boards - kingston value ECC ram in both with no problems
good luck with the build! should be a great setup for solaris
if you need more hard drives than motherboard SATA slots, then
the m1015 flashed to IT is a great option
jmelan is offline
post #36 of 38 Old 08-21-2013, 02:38 PM - Thread Starter
dimyself's Avatar
Hi! I know its been awhile...... but...... i'm in need of a sata card for 4tb drives. The M1015 chipset you mentioned flashed with IT will be sufficient? Are there any other sata cards that you guys can suggest? I don't want raid just passive sata. 4 port will probably be enough and it needs to be PCIE thanks!
dimyself is offline
post #37 of 38 Old 08-21-2013, 10:25 PM
mcturkey's Avatar
Liked: 43
Yeah, the M1015 will be fine, but if you only need 4 ports, there are likely cheaper options on NewEgg or Amazon
mcturkey is offline
post #38 of 38 Old 08-23-2013, 09:18 AM - Thread Starter
dimyself's Avatar
can you recommend any other cards/chipsets? I may just get the M1015 so I have future expandability...
dimyself is offline
Reply Home Theater Computers
