**** So you've built your HTPC-NOW WHAT IS NEXT ?? How to get the "ULTIMATE" picture and sound quality from your HTPC !!!! (MADVR? SVP? XBMC? Mediabrowser? Jriver? ) - Page 30 - AVS Forum
 22Likes
post #871 of 879 Old 12-12-2014, 11:55 AM
clausdk's Avatar
Quoted: 111 Post(s)
Liked: 49
Tried searching around for settings to reduce or avoid banding. I am using jriver + madvr jinc 3 and output 3840x2160@23(24). I get too much blanding I believe and was wondering if there are some obvious settings I need to change?
GTX 970 GPU btw.
clausdk is offline
post #872 of 879 Old 12-12-2014, 12:38 PM
Doesn't madVR's built-in debend filter help?
StinDaWg likes this.
PetitDragon is offline
post #873 of 879 Old 12-12-2014, 04:21 PM
clausdk's Avatar
Quoted: 111 Post(s)
Liked: 49
Dont know. Just enabled dvxa upscaling and then maxed out everything else. Also set "high" in debanding. Didnt help. Maybe its in the source?
clausdk is offline
post #874 of 879 Old 12-13-2014, 12:02 AM
Maybe it's temporal color banding in sources and need some kind of frame interpolation technique to be solved I'm afraid.
post #875 of 879 Old 12-13-2014, 01:45 AM
clausdk's Avatar
Quoted: 111 Post(s)
Liked: 49
Didnt notice it on ny previous projector. Was using an AMD GPU and outputting 1080p. Now using nVidia and outputting 2160p.
clausdk is offline
post #876 of 879 Old 12-13-2014, 02:02 AM
have you tried the "madLevelsTweaker.exe" in the madVR directory?
post #877 of 879 Old 12-13-2014, 03:11 AM
clausdk's Avatar
Quoted: 111 Post(s)
Liked: 49
Not sure. Advice on what to tweak in it?
clausdk is offline
post #878 of 879 Old Today, 09:08 AM
bcec's Avatar
Quoted: 106 Post(s)
Liked: 29
What's the recommended level/upscaler to use for upscaling 1080p to 4k uhd? Is it Jinc+3 taps, or Nedi, or something else?
bcec is offline
post #879 of 879 Old Today, 12:57 PM
hifiaudio2's Avatar
Quoted: 157 Post(s)
Liked: 77
Is it a post in this thread somewhere or some other thread that gives general guidelines on what settings to turn on in madVR for the best quality? I have a HTPC running a mobile core i7 and integrated graphics and another running an overclocked i7 and GTX 980, so I need a guide to show me multiple scenarios. I know I saw it, just not sure in what thread, or if its constantly updated.
hifiaudio2 is online now
Reply Home Theater Computers
