Theory About Intel's HDMI Quantization Range Setting (Full 0-255) - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #211 of 225 Old 03-01-2015, 07:51 PM
Quoted: 16 Post(s)
Liked: 5
hi I'm running intel i5 4440. The blacks looks grey and it's been driving crazy. This thread is 2yrs old and I was just wondering if the old hack is still current.
Originally Posted by Wizziwig View Post
Wow... lots of great developments since I started this thread almost 4 months ago.
I can confirm that the registry setting works on both Sandy Bridge and Haswell iGPU. Glad this has finally been resolved after all these years.
Combined with the best available refresh rate accuracy for 23.976 and 59.940 content, the Haswell iGPU is now unbeatable for most HTPC usage.
how do I make it 0?
Originally Posted by Foxbat121 View Post
Intel IGD will always convert 0-255 into 16-235 on your HDTV via HDMI (read this thread). You will have to use the registry key override posted in last page to force intel not to convert. So, did you use that registry hack when you posted that?
which registry hack did you use?
Originally Posted by olyteddy View Post
This is a photo of a cheap Vizio 26" TV fed by an i7-2600 (HD2000 graphics). I've had no trouble getting 0-255 on either of my Vizios, both of which are fed by Intel HD graphics.
Here's the whole testchart:
<a class="attachment loginreq" href="/attachments/72478" title="">testchart.zip 122k .zip file
viziotvowner is offline
post #212 of 225 Old 03-01-2015, 08:37 PM
Quoted: 16 Post(s)
Liked: 5
Originally Posted by SweetLow View Post
Anyone, who want FullRange RGB HDMI output on Intel Graphic may try this:
1. Find your current Intel Graphic Adapter software registry instance under:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\xxxx
(0000 on my PC).
2.Create DWORD value:
EnableRGBFullRange
and set it to 1
3. Reboot.
4. Enjoy.
AM I doing it wrong? why isn't it working? I shut it down and reset after following all 4 steps.
IT seriously took me an hour just to get this far. Please help.
post #213 of 225 Old 03-02-2015, 06:57 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 418
IIRC, new Intel drivers added necessary UI for you to choose output range. No hacks needed but the hack will still work (you just need to find out the correct driver reg key to apply the hack).
Also, there are other issues you need to consider. The hack is only to override video driver settings (so it won't try to convert) but the particular video player of your choice may still output video at limited range instead of full range. You will need to make sure playback software, video driver and TV all configured correctly. There is no magic fix.
Foxbat121 is offline
post #214 of 225 Old 03-02-2015, 07:13 AM
Quoted: 1704 Post(s)
Liked: 731
What do you do with the settings under color management/advanced/ windows color system defaults and icc rendering intent? Seems that these would also affect your output....would it not?
JimP is offline
post #215 of 225 Old 03-02-2015, 05:43 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 418
No, those are typically for photo display, not affecting video playback at all.
Remember videos are always produced using limited range (16 as darkest black and 235 as brightest white). It will never match well with the default PC display range (0 as darkest black, 255 as brightest white) unless someone does the properly conversion. HDTVs, cable box, DVD and BD players are all designed to use limited range as its standard format, not the PC full range.
post #216 of 225 Old 03-02-2015, 07:12 PM
Quoted: 16 Post(s)
Liked: 5
So I had to input a reg key on registry ???? I'm not good with computers so you gotta explain to me in steps.
post #217 of 225 Old 03-03-2015, 03:29 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 418
No, just follow the instructions carefully. Or, you can google for a tool that can set the registry for you written by fellow forum member.
But remember, that's just one of the 3 major factors in determine the final outcome of a video black level. The other two are the video player software and HDTV. All three have to be perfectly matched. Yes, either one can be configured to use either full range or limited range.
post #218 of 225 Old 03-04-2015, 01:13 PM
SweetLow's Avatar
For right hardware only.
SweetLow is offline
post #219 of 225 Old 03-10-2015, 03:39 PM
10k
10k's Avatar
Quoted: 1897 Post(s)
Liked: 2146
I just had a bear of a weekend with my i3 NUC. The short version is that I do not believe that the latest drivers output "full range" correctly, and the registry switch does not appear to work (at least for me) with the most recent driver version. Setting quantization to full range in the drivers and with registry entry results in significantly elevated blacks, measured at 0.3cdm2 vs my televisions true calibrated black point of 0.045cdm2.
Interestingly, the drivers versioned 10.18.10.3958 (https://downloadcenter.intel.com/search?keyword=153330) do not exhibit this behaviour, and do not have the "quantization range" setting in the control panel. The registry setting does however work and 0-255 output can be achieved via hdmi out with appropriate black levels.
The only way for me to get correct black and white levels out of the current drivers with my i3 nuc is to set drivers: limited, input range: limited, TV: limited. The desktop actually gets compressed down to 16-235 so there are not any crushed blacks or whites for desktop relative to video.
More importantly, I was also able to conclude that Intel's DXVA implementation is broken, and does not output correct colors relative to other rendering methods. Using my meter I observed that white and primary color outputs using DXVA decoding and rendering measured consistently and significantly different than the same video files decoded and rendered using XBMC Software, XBMC Pixel Shaders, and MadVR. Additionally, the latter 3 all agreed with same color measurements taken using HCFR GDI Image Generator, and png's in Firefox. Back when I had NVIDIA driving my htpc I did not have this problem.
For owners of Intel graphics who DIY/professionally calibrate their displays you must choose from a set of non-optimal scenarios.
1 - Calibrate your display using video files rendered via DXVA.
Pro: You are calibrating with the videochain you will be viewing media from
Con: Everything else will have varying levels of error in calibration
2 - Calibrate using any non-DXVA chain. Render and decode media files using, for example, XBMC with pixel shaders or software implementations
Pro: Consistent colors across all applications
Con: Software decoding is cpu heavy and causes my NUC fan to turn on, which is highly annoying.
3 - Chuck it and get hardware which works as advertised.
I went with 1 as I value silence, and am able to have a setup where all of my decoding goes through dxva. The error isn't large enough that I care or notice in system menus etc.
Hardware: Intel NUC D34010WYK, Samsung ES8000 LCD, Denon 2310 AVR
Software: Windows 7, XBMC (Kodi) 14
10k is offline
post #220 of 225 Old 06-10-2015, 09:46 AM
Liked: 0
Black levels
Hello. I'm going crazy with black levels. Buy a ZOTAC ZBOX PI320, which has an Intel card, which I set in the panel as intel video ouput driver Graphic FULL RANGE, the GPU (registry hack windows in FULL RANGE), the Samsung TV from 2013 Limited range and xbmc (Kodi) Limited range in rank. All with auto rendering method (dxva I guess), hardware acceleration on and use DXVA2. This configuration gives it AVS 709 calibration disc with whiter than white (all bars flashing) and black bars from 17 to up flashin (i dont know if this its blacker than black). The problem is that certain video black levels are correct (almost all in low definition) and some have to enter OSD configuration during playback of a video and then lower the brightness level within kodi and black levels again be correct.) You can try these videos inside apple in kodi trailers. FELT trailer and trailer EXETER black levels give erroneous. Correct this with the brightness level of the OSD kodi. Then I'll make the avs 709 test and I see no bar to shine and if I try the trailer "Bound to Vengeance" scenes are too dark and lost many details. Some people recommend disabling the automatic rendering and put software rendering, in addition to clear the Use DXVA2. But then I have to put my TV to 65 brightness bars to see shining on 709 test avs
Jesus Artes Dura is offline
post #221 of 225 Old 04-27-2016, 04:11 PM
Liked: 1
Hi. I'd like to thank you guys. I'm not sure if it's the registry hack that worked, or registry hack combined with EDID override together. I tried EDID override via monitor.inf file. It didn't work. Then I applied the registry hack. Now I finally have NORMAL colors on my Samsung TV, which now looks just amazing compared to gray **** I had for over a week.
OK, my config is Intel HD on Intel Core-i5 661, Windows 10 and Samsung T24C300EW TV. I have Quantization Range option in my driver control panel, however it totally ignores anything I select.
Adding DWORD "EnableRGBFullRange" = 1
to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4d36e968-e325-11ce-bfc1-08002be10318}\0000
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4d36e968-e325-11ce-bfc1-08002be10318}\0001
fixed the problem with fugly colors for good. I'm overjoyed. I can't understand why evil people even invented limited range in the first place? WHY? WHY? WHY?
On every computer, every graphics adapter I ever used - when I connected a monitor or TV via HDMI port - limited quantization is ALWAYS ON by default. It means the picture looks like ****. On every device except my built-in Intel this setting however could be changed in driver configuration. BTW, before Windows 10 is loaded - black and white look normal, it's clear it doesn't limit quantization until the display driver is loaded. Then I can see how suddenly black becomes gray. So it's done on purpose, against hardware defaults or BIOS settings.
Maybe they had a secret agenda of discouraging people from using HDMI ports and choose for example Display Port instead? This is my theory, because otherwise it's unexplainable. Why limit the number of displayed color on purpose? If someone has a crazy preference of seeing washed-out colors - every monitor and TV has contrast setting, the effect is achievable and fully customizable. Most of display drivers have also separate settings for video overlays. But the most important fact is: full device capabilities should be the default option!
There is another one. On Radeon display adapters when you use HDMI connector it scales the display to overscan! This is as stupid as limiting the quantization range.
chros73 likes this.
HTDx64 is offline
post #222 of 225 Old 02-08-2017, 02:27 PM
ShoutingMan's Avatar
Quoted: 262 Post(s)
Liked: 52
>Intel always outputs 16-235 over HDMI. Period. Stop. Settings matter not, Intel chooses to follow strictly the HDMI whitepaper specs for HDMI (16-235).
>You can use DVI or Displayport output to get full range , or you can add a GPU card. Otherwise just go with 16-235 and set up everything accordingly.
No, it's not the true. Intel remove this functionality from UI, but it still possible.
(0000 on my PC).
EnableRGBFullRange
and set it to 1
3. Reboot.
4. Enjoy.
I personally (discover and) test it on HD4000 mobile version with drivers from May 2013 on Windows 7 x64 + HDMI1/DVI input with "PC mode" on Samsung LE40B530 TV as HDMI Sink.
Another thing which I test - Intel drivers (current) don't accept standard MS EDID override feature, but allow the same functionality with ReadEDIDFromRegistry and FakeEDID_%d_%d_%x_%x registry keys pair.
I personally use this to switch HDMI device to DVI mode (Full RGB Range by default) by disabling CEA extension in EDID to verify equality of levels of DVI and HDMI+EnableRGBFullRange.
Can anybody test and verify my "research"?
Public Beta #2 of my home theater and HTPC brought up the issue of video range and black levels. Googling, there's a lot of frustration with Intel's IGP and this workaround from circa 2013. There's nothing regarding current hardware, 6th gen HD530 or newer.
Playing with my system, my conclusion is Intel HD530 (6th Gen) appears to output correct video levels and a display with automatic HDMI range detection will detect and use Limited or Full accordingly.
I have a 6th gen Skylake i5 with HD530 IGP. The graphics control is shown below. With the video range set to Default, running PowerDVD 16, and my Projector set to Auto (for HDMI Range), the blacks and whites look correct. In some cases, I see the sync happen with the image starting off blown out (or blacks looking gray and whites looking off), and the projector image will black out, sync and then come back with the right grayscale.
Setting the graphics output to Limited Range or Full Range, the projector's auto mode will sync up and the output looks the same. And if I manually toggle the projector's video setting to match the HD530 setting, everything looks good.
I was toggling back and forth to the output from my PS4 playing the same dark scene from the same Blu-ray. Visually, they matched.
This seems good news to anyone building an HTPC around a current Intel IGP system.
Name:	HD530 Graphics.jpg
ShoutingMan is offline
post #223 of 225 Old 02-09-2017, 01:05 AM
SweetLow's Avatar
Don't read only one post. If you read thread then you will know what kind of problem still exist
SweetLow is offline
post #224 of 225 Old 02-09-2017, 04:47 AM
Quoted: 262 Post(s)
Liked: 52
I've skimmed the recent threads. I didn't see anything about 6th gen HD530 Intel hardware. (There's a Haswell from two years ago but no Skylake.) If there's something to note, can you point me to it?
JimP and SupersonicUK like this.
post #225 of 225 Old 02-25-2017, 03:02 PM
Liked: 0
I also couldn't see anything referencing HD 530 or later.
My Intel chip is outputting the correct format. However, the brightness levels are significantly higher than its predecessor - a Radeon 5450. Once the brightness was adjusted in the driver settings (to about -12) all looked about the same, with minimal banding etc.
Just one other thing which might help someone in the same boat:- disable the xvycc option to get RGB (otherwise you get Component). At first I missed that setting as I was concentrating on RGB Full/Limited.
SupersonicUK is offline
Reply Home Theater Computers
Intel Core I5 4670k 3 4ghz Lga 1150 Quad Core Desktop Processor , Intel , Intel Core I5 3570 3 4 Ghz Processor , Intel Pentium G2020 2 9ghz Lga 1155 Dual Core Desktop Processor , Intel Pentium G3220 3 0ghz Lga 1150 Dual Core Desktop Processor , Intel Core I7 4770k 3 5ghz Lga 1150 Quad Core Desktop Processor , Intel Core I3 4130 3 4 3 Fclga 1150 Processor Bx80646i34130
