HTPC stuttering over new projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-18-2013, 06:46 PM - Thread Starter
TechNovice's Avatar
Hey folks
I recently upgraded my Panasonic AE4000 to the AE8000, which is connected to my HT/Gaming PC via HDMI 1.4. The PCs specs are:
i7 3770K
Dual GeForce GTX 780 in SLI
16GB DDR3 2133MHz
4 x SSDs
1 x 1TB HD
Creative ZXR sound card
I'm having a very strange problem that only started happening with the new projecto -I'm getting very bad stuttering/hiccuping when playing videos. It doesn't matter if they're Blu-ray, MKV or AVI, hosted locally or streamed over my network - they all stutter every few seconds. It also happens with VLC, PowerDVD 13 and WMP.
I've found a solution though - by changing my screen's refresh rate to 23Hz via the display screen resolution option. Yet I never had to do this with the AE4000 projector? What gives? It's not a huge problem, but is annoying, especially as I have to change it back to 60Hz when gaming.
Hope somebody can help!
TechNovice is offline
post #2 of 9 Old 06-19-2013, 04:50 PM
mo0sic's Avatar
Yep. Google refresh rate and HTPC. You'll find lots of threads... Enjoy.
mo0sic is offline
post #3 of 9 Old 06-19-2013, 05:01 PM
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 79
a lot of players can auto change the refresh rate. madvr can do it for a directshow player, xbmc can do it too.
MlNDBOMB is offline
post #4 of 9 Old 06-19-2013, 09:18 PM - Thread Starter
TechNovice's Avatar
I've googled the heck out of the issue, but can't find a single, simple answer. What concerns me most is that my AE4000 projector did not exhibit this problem whatsoever in over 18 months of use. Yet the newer AE8000 showed it immediately. Surely there's a setting on the projector that I'm overlooking?
post #5 of 9 Old 06-19-2013, 11:37 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Is the projector the only display connected?
Mrkazador is offline
post #6 of 9 Old 06-23-2013, 04:01 AM - Thread Starter
TechNovice's Avatar
Yes, the projector is the only display device connected.
post #7 of 9 Old 06-24-2013, 06:53 AM - Thread Starter
TechNovice's Avatar
Bump - surely somebody has an idea?
post #8 of 9 Old 06-27-2013, 01:30 AM
Bignickfly's Avatar
Just give utramon a try to lock down the refresh rate to your app. It just sounds like the projector does not like the video card, possible issue with reported EDID from the projector.
Bignickfly is offline
post #9 of 9 Old 06-30-2013, 05:11 PM
Andrew Hornfeck's Avatar
Quoted: 30 Post(s)
I use MediaPortal 1.4.0 as my front end and its Refresh Rate Changer option to select various refresh rates (that you configure) based on the metadata of the file you're trying to view.
Andrew Hornfeck is offline
Reply Home Theater Computers
