Audigy 2 ZS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-19-2013, 07:33 PM - Thread Starter
rockon2u's Avatar
......any info would be great...
I have a computer dedicated for audio play back only, library of mp3 etc. files.
my audio card is an Audigy 2 zs ..I use a 3.5 to dual rca jack from card to run the main amp and speakers, works great.
I also have a subs and a separate amp that I need to hook up to a low pass (sub)output
any Idea how to do this? Thanks
rockon2u is offline
post #2 of 9 Old 06-19-2013, 07:51 PM
Mrkazador's Avatar
Quoted: 258 Post(s)
Liked: 386
Use a 3.5 to stereo rca and connect to the sub/center of your sound card. One of the rca ends will connect to the input on the subwoofer.
Mrkazador is offline
post #3 of 9 Old 06-19-2013, 08:08 PM - Thread Starter
rockon2u's Avatar
the problem I'm having is this sound cards hookup info doesn't show where or how or what jack. It only shows 4.1, 5.1 and 7.1
also I tried already and did this but it seems that all the other jacks are dead..
rockon2u is offline
post #4 of 9 Old 06-19-2013, 08:14 PM - Thread Starter
rockon2u's Avatar
is there a trick to activating the other jacks ?
rockon2u is offline
post #5 of 9 Old 06-19-2013, 08:21 PM
Mrkazador's Avatar
Quoted: 258 Post(s)
Liked: 386
I'm not familiar with that card but I'm sure you can "activate" the other channels in the control panel for the sound card.
post #6 of 9 Old 06-19-2013, 08:33 PM - Thread Starter
rockon2u's Avatar
I think I just figured it out ,,it says use a 3.5 (surround) to RCA cable
I was using a 3.5 stereo to RCA cable
rockon2u is offline
post #7 of 9 Old 06-19-2013, 08:37 PM
Mrkazador's Avatar
Quoted: 258 Post(s)
Liked: 386
There is no such thing as a 3.5 surround to rca cable.
post #8 of 9 Old 06-19-2013, 08:42 PM - Thread Starter
rockon2u's Avatar
that's what I thought ,, never herd of it before ,,I'm going to radio shack and find out ................
rockon2u is offline
post #9 of 9 Old 06-20-2013, 09:25 AM
LexInVA's Avatar
Quoted: 540 Post(s)
Liked: 220
The card was designed for the old analog surround speaker setups that Creative used to sell through their Cambridge Soundworks/Creative Labs speaker brand so you'd have to configure the outputs from the card to your hardware to resemble something like one of those setups. Another option is to use the CMSS (fake surround sound processing), which is what the current Creative 5.1 speakers require. The best way to get 5.1 is with the digital i/o drive and toslink output but that probably isn't an option for you.
LexInVA is online now
Reply Home Theater Computers
