New Haswell / Z87 HTPC Build Questions. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 58 Old 06-20-2013, 05:12 PM - Thread Starter
mickey79's Avatar
Quoted: 14 Post(s)
Guys,
March, 2011 I had started this thread (http://www.avsforum.com/t/1319438/sandy-bridge-3d-htpc-build) to help me build my first, a Sandy Bridge HTPC capable of full Blu-ray 3D Playback. 2 years and change down the road, I'm about ready to build my 2nd, a slightly more powerful HTPC. We're moving the SB-HTPC into the bedroom and I need to build a newer one for the main Home Theater.
My budget is around $800, which does not include storage, except for a 128GB SSD (For Operating System), as I already have 6 X 2TB HDD's which contain my media. So essentially the $800 is going to contain the CPU, Motherboard, Case, PSU & Memory. I might be cramping in a TV Tuner in there.
Although I have a good grasp on most of the components, I'm somewhat debating whether to go for the Haswell chip's Intel HD 4600 GPU as my main GPU, or if I should actually go for a dedicated Video Card. I know that Intel HD 4600 is "enough" for 3D Blu-ray Playback; but I can easily scale back the CPU Model and spend $80 ~ $90 on a very decent NVidia or AMD GPU far more powerful then Intel HD 4600.
I have the Epson 5010 Projector and currently I'm projecting a 106" Screen, which might be expanding to a 150" soon.
My SB-HTPC in '11 was a 'Starter' HTPC as it was my first one, and I was only concerned with media playback & full 3D Blu-ray Playback. Now that I have stronger budget and better all around Home Theater equipment, I'm definitely looking for the best Video/3D playback I can get -- and if that is served better with a dedicated GTX or Radeon as opposed to Intel HD 4600, then that's what I'd like to do.
Any comments / suggestions?
7.1: Polk RTi12 Fronts, RTi8 Surrounds, Monitor70 Surround Backs, CSi A6 Center + Outlaw LFM-1 EX Subwoofer.
Yamaha RX-A2000 AVR
Epson 5010 3D Projector
Intel Sandy Bridge 3D HTPC / Blu-ray Player
mickey79 is offline
post #2 of 58 Old 06-20-2013, 05:38 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
Silverstone Case
Rosewill / Seasonic / MKIII/ Antec / Corsair PSU (400-500 watts )
Intel i5 4670k
Asrock Extreme 4 mobo
Gskill Trident 2400mhz DDR3 8GB
Samsung 840 / Vertex4 or 450 / Vector / Plextor M5 SSD
That should come in under $800 and be really nice. You have room for a HD tuner. I'd get Ceton internal or HD HomeRun Prime network tuner.
You'd have a super nice HTPC.
If you want links let me know.
Mfusick is offline
post #3 of 58 Old 06-21-2013, 01:56 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Adding a dedicated GTX or Radeon is a moot point. You will get better PQ than Intel HD Graphics only when you use
- An external player + madVR + HD 7770 / GTX 650 Ti (or higher).
Details.
renethx is offline
post #4 of 58 Old 06-21-2013, 07:50 AM - Thread Starter
mickey79's Avatar
Quoted: 14 Post(s)
Wow -- Those are some nice suggestions; closely matching what I had in mind.
Some comments ...
Actually I wouldn't mind if you did share a link with me; PSU is one part I usually rely on suggestions as I don't have too much personal knowledge - and usually the recommendations work out very well for me.
Intel i5 4670k
Again, GSkill is usually what I go for; mostly the Ripjaws, but I'll look at Trident.
Perfect! Will check out all of these. Cost might decide which one I go with.
My last motherboard was a Gigabyte and I have to be honest, I wasn't too thrilled. I have had very good experience with ASUS and for this build I did have it narrowed down to ASRock & ASUS. Is there any reason you picked ASRock over ASUS?
Silverstone Case
Case is the one component I'm putting in a little more research; both wife & I are looking for something cool to compliment the Home Theater. Silverstone is definitely in the running with the Granadia & LC lineup, but I'm also looking at some other options like Fractal-Designs, Moneual MonCaso, Streacom, etc. All of these have some nice, cool designs. The only issue so far I'm having with these other cases is the Internal Drive Bays - I need a minimum of 6 and would prefer 8. So far Silverstone is the only one fulfilling that - all others are dropping short. But I'll look a little further.
For TV Tuner I was looking at Hauppauge; is there a reason you recommend Ceton or HomeRun? I don't have any experience with either of those. I do have a Hauppauge Colossus HD-DVR Capture card which will be going into this HTPC for recording cable programs in HD.
And that brings me to my last issue ... still undecided between Intel HD 4600 as my GPU or getting a dedicated GTX/Radeon!
Yamaha RX-A2000 AVR
mickey79 is offline
post #5 of 58 Old 06-21-2013, 07:53 AM - Thread Starter
mickey79's Avatar
Quoted: 14 Post(s)
Details.
I have to be honest with you, I looked at the thread you linked but I couldn't understand anything - I'm definitely not as technically advanced as some of you are. I really couldn't understand the values or the technical terms and so couldn't really deduce what it was explaining. I don't even know what "madVR" means!
So let me ask you this - in layman's terms, do you recommend an HD 7770 or GTX 650 Ti over the Intel HD 4600 for the HTPC? And if yes, Why? What advantage do I get in terms of Media Playback? Do I get better PQ? Better 3D?
Thanks!!
Yamaha RX-A2000 AVR
mickey79 is offline
post #6 of 58 Old 06-21-2013, 08:16 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
If your not technical you will be fine with 1080p via 4670k. It's nearly perfect frame rate. If you desire MADVR or SVP or any of the other add ons your 4670k CPU should be up to the task and adding a GPU card at a later date is easy.
Unless your certain you want it now I'd hold off on the GPU card but I'd chose a case that could allow that upgrade in future.
Mfusick is offline
post #7 of 58 Old 06-21-2013, 08:18 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
MadVR is a video renderer that includes a video scaler running on GPU. Perhaps you usually use EVR (Enhanced Video Renderer) built in Windows, that uses GPU driver's scaling algorithm via DXVA2. MadVR is usually better than EVR to upscale SD / HD (1280x720) contents, but there is little difference between them when you play back FHD (1920x1080) 2D. MadVR does not support 3D. I think the difference in upscaling DVD is clear between Intel HD Graphics 4600 and madVR Level4/5 in this post.
MadVR runs its scaling algorithms on GPU. The highest algorithm requires some GPU processing power, HD 7770 or GTX 650 Ti is minimum.
renethx is offline
post #8 of 58 Old 06-21-2013, 08:27 AM
lagittaja's Avatar
I might add to the SSD recommendations that all those are great except for the 840, 840 Pro is great but the Basic version I wouldn't bother with.
http://www.xbitlabs.com/articles/storage/display/samsung-840-pro_5.html#sect1
Generally it's worse than the previous gen 830. It's not bad by all means but just not worth it.
For big file storage (not sure you'd use a SSD for that though considering cost per GB) it'd be good but since I believe you'd use the SSD for OS drive then the random read/write matters a lot.
When the request queue's build up the 840 Pro just accelerates away leaving the Basic version biting the dust.
Then there's of course the question of TLC and it's degradation. For normal OS use I doubt it matters much but still, the TLC cells do die faster than MLC.
http://uk.hardware.info/reviews/4178/hardwareinfo-tests-lifespan-of-samsung-ssd-840-250gb-tlc-ssd-updated-with-final-conclusion
The first SSD, the one you could follow live on the stream, had its first re-allocated sector on May 22, after 2,945 program/erase cycles and 707 TiB of written data according to the S.M.A.R.T. data. That's quite remarkable, as Samsung guarantees a lifespan of 1,000 cycles, while in reality their SSD last three times longer.
707TiB of writes rolleyes.gif My 1½ yr old Intel 520 Series 60GB has 4.8TiB of writes right now. Non issue like you can see from the hardware.info torture test but I for myself would buy something that's better rolleyes.gif
If we take the 764 TiB and an average of 10 GiB of writes per day, we arrive at a lifespan of 214 years. Keep in mind that we sequentially write and fill the SSD which gives us write amplification factor of only 1.04 or 1.05. That's the difference between the write commands sent to the SSD and the writes executed by the SSD internally. The general assumption is a WAF of around 3.0 for normal consumer use with SSDs that don't employ compression tricks. That translates to a lifespan of 75 years. Even when you push an SSD to the max by downloading lots of movies everyday up to an average of 30 GiB per day, the SSD will still last you 24 years. Nomatter how you use it, it will last longer than the period you plan on using it (most people like to add more capacity after a certain time). A functional lifespan of 10 years is already unusually high for a storage medium.
lagittaja@Overclock.net | Lagittaja@MuroBBS | Also Anandtech AVForums DIYAudio Head-Fi XDA-Developers e-Savuke ECF VFF VaporWall VapePit & etceteros
Main rig
lagittaja is offline
post #9 of 58 Old 06-21-2013, 08:29 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
It's better than most for $99, but I'd take a vertex or vector at same price.
The pro and the vector are clearly better and in a class of their own but I'm not sure the difference is a big deal for a HTPC.
Mfusick is offline
post #10 of 58 Old 06-21-2013, 08:39 AM
lagittaja's Avatar
Yeah of course. Also I updated my post a bit.
Main rig
post #11 of 58 Old 06-21-2013, 09:47 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
Regarding MadVR,
You'll have to decide for yourself if you want or require this functionality in your HTPC. Many people do not require it.
If you do then add a GPU card like Renethx suggested above. It should add in well and work well with the type of system your looking at.
Many are happy with simple players integrated into WMC or XBMC- Other people require more.
Mfusick is offline
post #12 of 58 Old 06-21-2013, 10:41 AM - Thread Starter
mickey79's Avatar
Quoted: 14 Post(s)
Ah! That explains it much better. I'm quite convinced now about taking the dedicated GPU route at this point. I do have quite a bit of SD and 720p HD Content (TV Shows mostly) which could benefit from MadVR. Aside from that, doing some more research, there is a lot of suggestion out there for dedicated GTX or Radeon over Intel HD even for 3D Blu-ray. The cost isn't significant enough to pass up on MadVR or other benefits of dedicated GPU.
Which brings me to a question: between Radeon HD 7770 & GFX 650 Ti, both running round $149, which one would be a better choice for 3D Blu-ray Playback & other media playback?
Those are all great suggestions & I'll keep this in mind when hunting down my SSD. I won't be using SSD's for media storage; I have a whole bunch of 2TB SATAIII 6.0Gb/s drives for that - and plan to expand the same. SSD is only going to be for my OS.
Regarding MadVR,
Pretty much decided on dedicated GPU at this point; just trying to narrow down between GFX 650 Ti or Radeon HD 7770. These 2 cards are pretty similarly priced ... contemplating between either:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121725
.OR.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121772
Although I'm open to other suggestions as well.
Thanks guys.
Yamaha RX-A2000 AVR
mickey79 is offline
post #13 of 58 Old 06-21-2013, 11:13 AM
lagittaja's Avatar
If you plan to use SVP then better to pick up a HD 7770. More of that in the SVP thread, on erm page 10 iirc.
Main rig
post #14 of 58 Old 06-21-2013, 11:41 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Personally I recommend ASUS HD 7790 DirectCU II ("DC2") 1GB or 2GB (choose 2GB if you can afford, there is no difference in video playback though), that should fit GD07/GD08 (won't fit most microATX cases because of taller heatpipes).
mickey79 likes this.
renethx is offline
post #15 of 58 Old 06-21-2013, 12:03 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
The master has spoken^
No one has tested these things as much as him. I am looking at the same GPU card myself actually , or possibly even a 78xx.
I just installed my 6870 (older card) into my 4770k last night and it made a nice difference and sold me on why I need a GPU over HD4600.
I love your build. Your building a real HTPC, unlike many of the low budget builds that are really to just watch videos from your PC on your TV. Your budget is very realistic and I think your going to end up with a really nice machine!
Mfusick is offline
post #16 of 58 Old 06-21-2013, 12:21 PM - Thread Starter
mickey79's Avatar
Quoted: 14 Post(s)
GPU is going to be the main component in this system, as it's all about the Media, Graphics & 3D, so I have no hesitations in spending the extra $$'s on the GPU - as Mfusick notes below, I don't even mind upping to HD 78xx. But, here's an important question, and you must take this question as a humble question from someone who's in a learning process, and not Questioning your choice ...
Why Radeon over GTX? What is the deciding factor that makes you lean towards Radeon over GTX?
One of the reasons I ask is because I was just spending some time reading articles here & there, and I also put in "GTX 650 vs Radeon 7770" in google and it appears that more benchmarking & reviewing articles were giving a "slight" upper hand to GTX over Radeon. So I'm curious about your recommendation.
Let me also throw something completely different in the mix; this will NOT be a deciding factor & I could care less about this, but I'd still like to mention it. I'm a HUGE StarCraft gamer. I keep gaming on my PC and I have no intentions of bringing it to my HTPC. However, I was reading an article where they were playing StarCraft 2 on their HTPC, on a Projector Screen, in 3D. And it got me curious enough to think I'll probably give it a shot --- not to game constantly --- but just to try it out.
Would Radeon still be the better choice?
Your exploration definitely Confirms my decision of going with a dedicated GPU over Intel integrated; I'm glad now I'm choosing this path.
And thank you, I'm also very excited about this machine and can't wait to get started. For the right parts, I don't mind if my $800 budget pushes to $1K, I definitely do want the best Media Playback capabilities. I use MediaPortal as my front-end which gives me a lot of a Internet content via Tube+, etc. So it's really a whole bunch of media from Blu-ray's to MKV's to DVD's, TV Shows and Online Videos. And Like I said before, we're looking for something cool & hip in terms of the actual Chassis, something that will complement our Home Theater well, and not just a simple case that will hold the parts.
Yamaha RX-A2000 AVR
mickey79 is offline
post #17 of 58 Old 06-21-2013, 12:40 PM
lagittaja's Avatar
I seriously doubt you need more power than what HD7790 or GTX 650Ti has to offer. Except if you're planning to do some gaming.
Main rig
post #18 of 58 Old 06-21-2013, 12:45 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
I think you can use SVP on youtube videos.... It's pretty cool actually.
Mfusick is offline
post #19 of 58 Old 06-21-2013, 12:51 PM
lagittaja's Avatar
Yeah you can. Certain music videos look hell of a lot better with SVP. But you need to stream the Youtube to a player, like MPC-HC.
Also mickey79, remember when you're comparing that the GTX 650 doesn't stand a chance against a 7790, nor to a 7770. At least for gaming perf.
You gotta compare HD7770/7790 to GTX 650Ti and HD7850 to GTX 650Ti Boost.
Main rig
post #20 of 58 Old 06-21-2013, 03:15 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
What I like about Radeon are:
1. Precise 23.976Hz refresh rate right out of the box (with NVIDIA you will need to create a custom resolution)
2. Support for full-range and limited-range RGB as well as 4:4:4 / 4:2:2 YCbCr output (with NVIDIA you will need to run madNvLevelsTweaker.exe and restart the system to switch between full-range and limited-range RGB)
3. 3D is easier (with NVIDIA you have to go through a set of 3D tests [necessary for 3D Vision, but unnecessary for HDMI 1.4a 3D]; 3D will mess up the newly created "23.976Hz")
4. Both madVR and SVP work better with Radeon. In gaming GTX 650 Ti is better than HD 7770, but in video playback with madVR / SVP + madVR, HD 7770 is better (lower GPU usage, lower power consumption)
What I don't like about Radeon are:
1. Dual (actually up to six) audio stream work only when DisplayPort is used. But dual audio stream matters only when you play HDMI 1.4a 3D with a HDMI 1.3 AVR.
You can play games in 3D with either AMD or NVIDIA. Output resolution is restricted to 1280x720, however (because of HDMI 1.4a). AMD requires TriDef 3D Middleware ($50) / NVIDIA requires 3DTV Play ($40), to convert standard PC games to 3D.
renethx is offline
post #21 of 58 Old 06-21-2013, 03:25 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
You just sold me on a Radeon card. Wondering if I should get that Asus 7790 2GB or perhaps look into a 78xx ??
Mfusick is offline
post #22 of 58 Old 06-21-2013, 03:43 PM - Thread Starter
mickey79's Avatar
Quoted: 14 Post(s)
LOL -- I was just going to type EXACTLY what Mfusick just said - you SOLD me on the Radeon as well. Enough said.
That being the case, I'm going to start scouting prices - we have a Fry's down the road which most of the time will beat Newegg's prices. I'll be comparing both 77xx's & 78xx's and seeing if I can score a good deal and pick up the better card at a good price.
I must thank you, renethx, for all the wealth of information & time you spared to explain all this to me.
The system is starting to take shape:
To buy ...
Intel i5-4670K
Asus or Asrock Z87 Motherboard (Still researching)
Rosewill or Corsair PSU (Still researching)
G.Skill Trident 2400 Mhz 8GB DDR3
Silverstone Granadia or LC (Still exploring other designs -- Moneual MonCaso, Streacom, Fractal-Designs)
AMD HD Radeon 7790 or 78xx (Still researching)
TV Tuner (Still Researching)
128 GB SSD (Will pick from list above)
Already have ...
6 X 2TB SATAIII 6.0Gb/s HDD's
Intel Gigabit PCI-Express Network Adapter (Used as 2nd NIC in the system)
Hauppauge Colossus HD DVR Capture Card
Toshiba HD-DVD Drive (Used as CD/DVD/HD-DVD Optical Drive)
Yamaha RX-A2000 AVR
mickey79 is offline
post #23 of 58 Old 06-21-2013, 03:44 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Right now 7790 is powerful enough. 7850/7870 is future-proofing in that madVR may add more complex algorithms in future. 7870 is roughly 1.5x more powerful than 7850, so personally I would go with 7870. 7850 consumes 20W more power with SVP+madVR (~150W system power vs 130W of HD 7770). One of the quietest HD 7870 cards is PowerColor, $270 ($240 AR).
HD 7970 is 4K-ready in that it supports madVR Level 5 for all SD/HD/FHD/4K UHD contents in a 4K UHD screen. But SVP for 4K contents is out of question right now (SVP has to move to 64-bit first). ASUS DirectCu II is the quietest.
renethx is offline
post #24 of 58 Old 06-21-2013, 04:05 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
I can imagine what that's going to take. I'll probably have to upgrade my i7 I just bought.
Mfusick is offline
post #25 of 58 Old 06-21-2013, 04:45 PM - Thread Starter
mickey79's Avatar
Quoted: 14 Post(s)
Well, I definitely don't need a 4K-Ready GPU right now, LOL.
In terms of 7790 / 7850 / 7870 ... the price difference between 7790 & 7850 is negligible ... around $20, so that's almost a no-brainer. I would more then likely going be going with a 7850 and have some madVR future-proofing available to me. Unfortunately 7870 puts me above $200 (Unless a shell-shocker comes along), and I really wanted to spend no more then $160 ~ $190 on the GPU. So 99% I'll be going with a 7850 at this point.
Is there any manufacturer I should avoid? I've had a terrible experience with Sapphire so I usually avoid them. I see PowerColor, HIS, MSI, XFX, Gigabyte & ASUS as the majority players, with ASUS being my brand of choice - although the most expensive most of the time.
Yamaha RX-A2000 AVR
mickey79 is offline
post #26 of 58 Old 06-21-2013, 05:26 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
XFX Double D FX-785A-CDFC 2GB
XFX Double D FX-785A-ZDF4 1GB
are surely one of the quietest.
renethx is offline
post #27 of 58 Old 06-24-2013, 06:25 PM - Thread Starter
mickey79's Avatar
Quoted: 14 Post(s)
Guys,
Couple of quick question:
I'm having a hard time deciding between these 2 motherboards ...
ASRock Extreme6: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157371
ASUS Z87-PLUS: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131980
Both are exactly the same cost! I've never owned an ASRock before but have heard nothing but good things about it. On the other hand, every single motherboard I've ever owned (except once) has been an ASUS and I have had nothing but great experience with each. So I'm completely undecided here.
Any advice?
Yamaha RX-A2000 AVR
mickey79 is offline
post #28 of 58 Old 06-24-2013, 06:27 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
I've owned a few XFX Radeon cards and I've always been happy with them.
Mfusick is offline
post #29 of 58 Old 06-24-2013, 09:48 PM
jeffkro's Avatar
I thought 4K was going to require a new HDMI format. Maybe it was 4K @ 60 fps.
jeffkro is offline
post #30 of 58 Old 06-25-2013, 12:57 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
HDMI 1.4 supports 3840×2160 up to 30Hz. DisplayPort 1.2 and the upcoming HDMI 2.0 support frame rates beyond that.
renethx is offline
Reply Home Theater Computers
