Network Share drives not available after a reboot or wakeup from Sleep - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-24-2013, 01:03 PM - Thread Starter
Rew452's Avatar
Quoted: 106 Post(s)
Liked: 64
I am using WHS 2011 and when my clients using a SSD as boot drive first boot or after returning from sleep I get a drives not available warning.
The server has 2 shared drives for movie and file storage and from what I can find it has to do with the speed of bootup with the ssd drive. The shares are actually there but somehow missed due to the speed. One can check after boot or return from sleep and they are there and working.
I know I can't be the only one seeing this, is there a good work around, script or what ever to get rid of these erroneous message error???
Rew
Rew
Vizio P75-C1 | OPPO UDP-203 | Samsung UBD-K8500
Denon AVR-x5200w | Nvidia Shield Android TV | C =Axiom VP150 |FL/FR =Axiom M60 |SL/SR =Axiom QS4 |TFL/TFR =Bose 161 | TRL/TRR =Bose 161 |Sub =Reaction Audio S-15 500W SEALED SUBWOOFER
Rew452 is online now
post #2 of 12 Old 06-24-2013, 01:14 PM
itznfb's Avatar
Liked: 58
So the shares just take a few seconds/minutes to show up after booting/resuming from wake? From the host server or the client? From the client side that's normal. From the server side I've only seen that with external drives.
Running Windows Home Server 2011 Evil Abandoned Edition
itznfb is offline
post #3 of 12 Old 06-24-2013, 01:16 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
It takes a second to load a LAN driver sometimes. Give it a minute. Does it work then ?>
Mfusick is offline
post #4 of 12 Old 06-24-2013, 01:25 PM
N3W813's Avatar
Quoted: 22 Post(s)
Liked: 70
Rew
What OS are your clients running?
My ArgyllCMS/MadVR 3DLUT Creation Workflow
My Sharp Elite Movie THX AV Mode Settings
--Aug 2011 Set, 2.2 gamma [ link ]
--Nov 2012 Set, 2.2 gamma [ link ]
N3W813 is offline
post #5 of 12 Old 06-24-2013, 01:29 PM - Thread Starter
Rew452's Avatar
Quoted: 106 Post(s)
Liked: 64
The share drives are there a short time after booting or wakeup but initially they are not as far as Win7 is concerned.
I believe it calles them not accessible. not here right now to check the correct message but it is annoying.
I found some references to this behavior and it was sited that MS never planned for drives to come up as quickly as those with ssd drives do. And that was the problem.
My drives are fully usable but of course event viewer logs errors for this behavior and I would like to patch around this to get rid of those errors.
Perhaps a delay of some sort, but I have not found a fix
You guys have not seen this?
Rew
Rew
post #6 of 12 Old 06-24-2013, 01:51 PM
JL-F1's Avatar
yep, every time I reboot I get the message 'shared drives inaccessible' .
evry time I just ignore it and everything always works fine.....
JL-F1 is offline
post #7 of 12 Old 06-24-2013, 02:16 PM
jmelan's Avatar
Quoted: 57 Post(s)
Liked: 33
http://zornsoftware.codenature.info/blog/windows-7-disconnected-network-drives.html
Mapdrive works for me - used to have all kinds of problems as mediabrowser would not see my collections after sleep
jmelan is offline
post #8 of 12 Old 06-24-2013, 02:16 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Same here. Takes a few seconds for my LAN to kick on...
Mfusick is offline
post #9 of 12 Old 06-25-2013, 03:02 AM - Thread Starter
Rew452's Avatar
Quoted: 106 Post(s)
Liked: 64
Thanks! jmelan
Had a busy night and didn't see your post until late last night. It certainly looks like what I have been experiencing.
Going to put it to use today and will post back my results.
Thanks again
Rew
Rew
post #10 of 12 Old 06-25-2013, 09:52 AM
shortcut3d's Avatar
Quoted: 21 Post(s)
Liked: 29
I'm having a similar problem with an iSCSI target not showing up after restart. I had to duplicate the target and apply a fake MCS round robin to reliably reconnect after reboot. My log has errors on every reboot because the first attempt to connect always fails. Then the round robin attempts to connect to the exact same target again. Apparently enough time has passed, so it works. My guess is that its related to the network drivers coming up slow because its not all that prevalent of an issue that SSDs are the root cause, if so there would be tons of posts on the NAS forums.
shortcut3d is offline
post #11 of 12 Old 06-25-2013, 09:55 AM
Elpee's Avatar
Quoted: 61 Post(s)
Thank you. I have the same issue. Will try this.
Elpee is online now
post #12 of 12 Old 06-27-2013, 02:47 AM - Thread Starter
Rew452's Avatar
Quoted: 106 Post(s)
Liked: 64
Works like a Champ!
Very good find; Can be a little daunting to setup but when you get it working Wa..Laaaaa.
IF you have some difficulty use CMD box and run Net Use command for the exact server share name.
Rew
Rew
Reply Home Theater Computers
