DTS playback "glitchy?" in MPC with MadVR LAV + FFDshow filters - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-28-2013, 09:49 AM - Thread Starter
Ben Agg's Avatar
Hey,
I am using an intel hd4000 I have everything setup correctly in madvr get no dropped frames , rarely any repeat frames but I noticed when I play a full DTS video (complete untouched m2ts rip) I get this weird "glitchy" or skipping audio every few seconds , I still get no dropped frames from it or repeat frames, I have tried messing around with reclock + LAV and I cant seem to find a solution. I am down mixing to stero as I have no surround sound. I have also put the DTSdecoder.dll from arcsoft into LAV folder (and tried deleting it with a test) which was unsuccesful. Any other suggestions? ac3 tracks work fine.
Ben Agg is offline
post #2 of 6 Old 06-29-2013, 09:18 AM - Thread Starter
Ben Agg's Avatar
Any suggestions smile.gif ?
Ben Agg is offline
post #3 of 6 Old 06-29-2013, 09:36 AM
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 81
how do you have reclock configured?
MlNDBOMB is offline
post #4 of 6 Old 06-29-2013, 10:35 AM - Thread Starter
Ben Agg's Avatar
Hey I thought I had disabled reclock in the testing but in the advanced options just now I unticked the red checkbox I highlighted and changed my default audio renderer in MPC to system default and it works fine, I would obviously like to be using reclock though and reclock is clearly the problem , not sure what I should change though.
Ben Agg is offline
post #5 of 6 Old 06-29-2013, 12:14 PM
Chronoptimist's Avatar
Liked: 535
Change the output mode to WASAPI
Increase the buffer size or reduce the quality.
Disable vsync correction.
Disable the high CPU priority option. (changing priorities can interfere with playback)
Most DVDs are not 23.976fps, so you probably want to change that too.
Max slowdown/speedup should be 5% if you want it to work correctly with PAL content.
It might help to reset the timing database.
Chronoptimist is offline
post #6 of 6 Old 06-29-2013, 12:31 PM
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 81
I wouldn't touch the max slow down speed up, there is another option for pal speedown elsewhere if you are interested.
Anyway, there is nothing in the reclock settings that looks like it would cause problems with audio playback.
It might be clipping maybe? Do you have clipping protection on in lav audio?
MlNDBOMB is offline
Reply Home Theater Computers
