Random trailers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-30-2013, 11:11 PM - Thread Starter
TK Doom's Avatar
Hello,
I have a dedicated home theater now and eventually plan to have a HTPC of some sort.
For now, what I'd like to have is some ripped trailers to play randomly before my movie, granted i would have to switch inputs, but I'm just curious the best way to go about it.
Blu Rays are very sparse of trailers these days, so I would be using both DVD and blu-ray content.
Any ideas?
TIA!
TK Doom
Unreal Tournament Forever
Project Gotham Racing too!
TK Doom is offline
post #2 of 12 Old 07-01-2013, 12:33 AM
Mrkazador's Avatar
Quoted: 253 Post(s)
Liked: 378
You can find lots of HD trailers here but most of them are in 2ch.
http://www.hd-trailers.net/
Mrkazador is offline
post #3 of 12 Old 07-01-2013, 10:50 PM - Thread Starter
TK Doom's Avatar
thanks, but what program would play and randomize them?
thanks!
Also would like to have the MPAA prologue to it...i guess i could edit that in? or have it play in front of each random trailer?
TK Doom
TK Doom is offline
post #4 of 12 Old 07-02-2013, 05:39 AM
stanger89's Avatar
Quoted: 2694 Post(s)
Liked: 1380
Something like this?
http://wiki.xbmc.org/index.php?title=Add-on:Cinema_Experience
I'm surprised no one here talks about it, but then again it seems most here are happy to just have a PC connected to their TV.
stanger89 is online now
post #5 of 12 Old 07-02-2013, 09:16 PM - Thread Starter
TK Doom's Avatar
Got anything more plug and play like? ...I'm not as bright as I was in my youth!
TK Doom
TK Doom is offline
post #6 of 12 Old 07-03-2013, 05:43 AM
stanger89's Avatar
Liked: 1380
Cinema Experience is about as plug and play as you get, you just install the plugin and configure it with a skin that supports it, and it automatically pulls down trailers. Of course you can configure it to do neat stuff like play DD/DTS clips before movies with the respective audio tracks, THX intros, I've got mine setup to play the TI DLP Cinema intro (since I've got a DLP Home Cinema biggrin.gif).
post #7 of 12 Old 07-03-2013, 07:42 PM - Thread Starter
TK Doom's Avatar
Oh, i didn't realize i needed a skin..thanks...bbl!
TK Doom
TK Doom is offline
post #8 of 12 Old 07-03-2013, 10:02 PM
stanger89's Avatar
Liked: 1380
If you don't like the "over the top" flashy ones, ACE MQ is a nice clean skin with Cinema Experience built in (well you have to install the plugin, but that's just a matter of selecting it from the UI).
post #9 of 12 Old 07-04-2013, 07:21 PM - Thread Starter
TK Doom's Avatar
It says its installed, but how do i get it ...going?
TK Doom
TK Doom is offline
post #10 of 12 Old 07-04-2013, 09:53 PM
stanger89's Avatar
Liked: 1380
you can configure it under the program addons. Once you do that you should see a "Cinema" option listed on the info screen of a media file. You may have to search to figure out how enable it in the skin you chose.
post #11 of 12 Old 07-05-2013, 12:36 AM - Thread Starter
TK Doom's Avatar
yeah, i'm not getting it...what files types do they look for?
I point it to a directory that has a .vob, it doesn't show up, I also have a ripped bluray, doesn't show up either.
TIA
TK Doom
TK Doom is offline
post #12 of 12 Old 07-05-2013, 12:01 PM
stanger89's Avatar
Liked: 1380
I'm not sure I follow, here's info on Cinema Experience:
http://forum.xbmc.org/showthread.php?tid=87563&pid=664143#pid664143
If it's more XMBC in general, you might want to check out the XMBC thread here or the XBMC wiki.
Reply Home Theater Computers
