Display resolution changer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-02-2013, 05:00 PM - Thread Starter
Cowboys's Avatar
Liked: 107
Hi all,
I just got the Benq W1070 3D 1080p projector and need to find an easiest way to switch resolution between 1080p/60Hz for 2D, 1080p/24hz for 3D Over and under and 1080i/60hz for 3D side by side instead of manually changing resolution via my Radeon 6670 video card settings. Can someone help? Thanks.
Cowboys is offline
post #2 of 2 Old 07-02-2013, 06:50 PM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
With the 6950 you can just right click the amd control icon in the bottom tray, next to the volume control. Other than that I suppose you could try a program that does custom hotkeys, but they can be complex.
Although I'm not to sure about 3d settings...
Mik James is offline
Reply Home Theater Computers
