Help me end my miserable quest for a 100% silent power supply - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 122 Old 04-07-2014, 07:09 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
The third pin is just for rpm sensor for the sake of the user. It has nothing to do with fan speed control. The fan speed is controlled by varying the voltage to the power pin (5-12V). Another pin is grounded, of course.
renethx is offline
post #92 of 122 Old 04-07-2014, 07:39 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
The tachometer winding can be meaningful to system boards with more modern features. For example Asus system boards that support FanXpert calibrate the fan by running it over a range of applied power voltages and monitor the actual fan speed that results. They provide an interactive means for adjusting various fan speeds (CPU, chipset, graphics) to temperatures that are known to the motherboard through those parts built in sensors.
The fourth pin is for implementing PWM fan speed control. With PWM control the fan receives a steady 12 volts and its speed is controlled using an internal controller and the voltage on the fourth pin. I can be argued that this offloads the motherboard's fan speed control circuits but in practice I haven't seen a lot of difference.
arnyk is offline
post #93 of 122 Old 04-07-2014, 08:45 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
RPM sensing has nothing to do with fan speed control, at least in the case of CX430 (and most PSUs), it's not "FanXpert". smile.gif
renethx is offline
post #94 of 122 Old 04-07-2014, 08:51 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Agreed.
So far, PC power supplies don't seem to be nearly as smart as the rest of the PC. I predict it is just a matter of time... ;-)
Meanwhile I've had some luck wiring the PSU fan to the motherboard to take advantage of the smarts that are there.
arnyk is offline
post #95 of 122 Old 04-07-2014, 09:31 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Originally Posted by StinDaWg View Post
It is a little odd that fan speed is controlled by wattage and not temperature though, since some cases are worse than others for airflow and will run hotter at less wattage.
PSU takes cold air from the outside of the case via the fan, then emits hot air from the rear. So the case temperature won't affect PSU (and PSU won't affect the case temperature either). Unless you orient the fan toward the inside of the case intentionally, of course. (The figure below is not so good to illustrate this because this particular PSU is designed to take also the air inside the case.)
renethx is offline
post #96 of 122 Old 04-07-2014, 04:55 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
If the fan is spinning and the PC works and it's quiet then I would just use it until it blows up or starts over heating. If it ain't broke don't fix it. Slow fans are a good thing.
Mfusick is offline
post #97 of 122 Old 04-07-2014, 05:31 PM - Thread Starter
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
I'm assuming I could just get a 2 pin to 3 pin adapter and re-purpose the Yate Loon psu fan as a case fan (slowed down with a 5v adapter)? This would put rpm at about 832 if the Yate Loon is 2000.
StinDaWg is offline
post #98 of 122 Old 04-07-2014, 08:53 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Perhaps it easier to buy a Molex 3-pin connector ($6.50 shipped!) than find an appropriate adapter.
renethx is offline
post #99 of 122 Old 04-08-2014, 04:12 AM - Thread Starter
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
lol, $5 economy shipping on a $1.50 piece of plastic. They could stick that in an envelope with a 50 cent stamp. biggrin.gif Highway robbery.
StinDaWg is offline
post #100 of 122 Old 04-08-2014, 05:38 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
If you are willing to wait for it to come from China (up to a month) you can get all kinds of adapters and connectors direct shipped, for a buck or two on eBay.
http://www.ebay.com/itm/6inch-4Pin-Molex-Power-to-3-pin-PC-Fan-adapter-/281274447797
arnyk is offline
post #101 of 122 Old 04-08-2014, 08:45 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
PSU fan connector is like this
I don't think there is an adapter to the Molex 3-pin connector.
renethx is offline
post #102 of 122 Old 04-08-2014, 09:00 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I've never needed one! Just slip the 3 pin connector (female) over the right 2 pins!
arnyk is offline
post #103 of 122 Old 04-08-2014, 09:03 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
The pin intervals are different. I am not sure what we are talking about. smile.gif
renethx is offline
post #104 of 122 Old 04-08-2014, 12:07 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
The difference in pin spacing has never caused me a problem. The pins are pretty thin and bendy. I'm far from the first person to recommend this.
arnyk is offline
post #105 of 122 Old 04-08-2014, 12:34 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
renethx is offline
post #106 of 122 Old 04-09-2014, 05:47 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Yup, it will fit if you bend pins...
Usually the plug slips on easily enough that I don't even notice the bending.
arnyk is offline
post #107 of 122 Old 05-03-2014, 01:37 PM
leebo's Avatar
Quoted: 525 Post(s)
Liked: 293
Originally Posted by arnyk View Post
Originally Posted by leebo View Post
Two questions:
What happens if a PS overheats? Does it simply burn out (in which case I can just replace it)?
About 99 out of 100 PSU failures harm only the PSU. The other one sends a power surge through the PC and it is not pretty.
What exactly is the "5 volt trick? Is there a post in this thread explaining how to find a 5v source?
The 5 volt trick takes many forms, but this is an easy one to explain:
Here is a typical adaptor for connecting a fan to a hard drive power connector:
As you can see the red wire to the plug for powering the fan is connected to the yellow wire on the hard drive connectors. The yellow wire carries 12 volts.
Probably the simplist form of the next step is to cut off the red wire where it enters the hard drive power connector, and then splice it with the red wire in the hard drive cable. It carries 5 volts.
Or, you can spend a little money on one of these that just plugs in line with the fan power:
http://www.amazon.com/Zalman-Fan-Speed-Controller-FANMATE-2/dp/B000292DO0/ref=sr_1_1
Resuming this discussion, I opted for the Zalman fan speed control. I'm using a cheap OEM PSU, with two fans, but one is disconnected.
As long as there is not much load, the PS is relatively quiet (still not htpc quiet). But when I'm doing video encoding, it still ramps up like a jet engine!
I plan on installing the CX 430 PS I bought last month, but I suspect even that will get loud during video encoding.
My next step is to go further back in this thread and check out those quiet replacement fans that were discussed.
Sent from my generic not my computer device.
leebo is offline
post #108 of 122 Old 05-03-2014, 02:29 PM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
In my main desktop PC, I have a relatively old FSP PSU (3-4 yrs old) and the fan got loud over time. It uses a 140mm fan. I popped in a new Antec fan, hotwired the fan connector to the two pin connector on the PSU, but it was still a bit too loud for my tastes. Threw in a fan voltage reducer cable (5v), and I can't hear the fan from 6" away. I can't complain.
The cable looks like this, you can get them at a number of places.
kapone is offline
post #109 of 122 Old 05-03-2014, 11:45 PM
leebo's Avatar
Quoted: 525 Post(s)
Liked: 293
Nice. A number of places = Newegg?
leebo is offline
post #110 of 122 Old 05-03-2014, 11:50 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Mrkazador is offline
post #111 of 122 Old 05-04-2014, 06:58 AM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
Originally Posted by Mrkazador View Post
You can make your own
http://www.blackfiveservices.co.uk/fanspeed.shtml
Sure you can. It's just easier when they are cheap and pre-built. If I recall correctly, I had ordered mine from Jab-Tech a while ago, with a bunch of other stuff. And they were like a dollar each.
kapone is offline
post #112 of 122 Old 05-04-2014, 09:10 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Two questions:
If you are really lazy, get some of these:
http://www.ebay.com/itm/50-RED-3M-QUICK-SPLICE-SCOTCH-LOK-WIRE-CONNECTOR-TERMINALS-22-18-GA-/151269732154
You don't have to cut the red wire, just pull on it with a little jerk and it will break off inside the Molex connector.
Snap one of the above onto the thick red wire running between the Molex connectors, stick in the end of the red wire you just ripped off, assemble and squeeze with a pair of pliers.
arnyk is offline
post #113 of 122 Old 05-08-2014, 01:12 PM
leebo's Avatar
Quoted: 525 Post(s)
Liked: 293
Originally Posted by Mfusick View Post
I am not sure what to tell you. It's really quiet for me. I sit right next to it. I have a lightning in my desktop and it's very quiet. I have a Capstone in my server and it's very quiet. I have an Antec Neo in my HTPC (Seasonic) and it's also equally quiet. Lightning is the quietest but it might be because of the superior case I have it in. The HTPC is inside an Antec 300 case which isn't the greatest. My Server is in a Norco 4020 and I replaced the fan blades with silent X fans on 120mm Fan blade. I also replaced the 80mm back fans with silentX fans and I run them off fan control to slow them down when it's cool. (it's always cool) To me the Antec NEO, The lightning, and the Capstone are all quiet. I think all three are quality PSU's. I also have a Seasonic branded 550watt and it's no different than the Rosewill's or the Antec. The difference is nearly indiscernible between them and I can't see many people not happy with any of them.
My original fear was that OP is just more sensitive than normal to noise so I am hesitant to recommend anything at all... lol.
Your idea of replacing the fan seems legit. Cheap and easy to do. Just replace the fan on that cheap Corsair you have.
Have you ever done any re-encoding on your HTPC? I have the same Antec Neo in my desktop/HTPC. It's fairly quiet, but when I'm re-encoding, it ramps up and is pretty loud. That's why I don't use it for that during the night (it's near my bed). I may test connecting it's fan outside the PS so it can't do that. I'm a bit nervous it'll eventually die though.
leebo is offline
post #114 of 122 Old 05-08-2014, 02:30 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I've only done a little encoding with the Antec and it's usually through RDP so I'm not in the same room.
The Antec is in my HTPC.
Mfusick is offline
post #115 of 122 Old 05-08-2014, 04:42 PM
leebo's Avatar
Quoted: 525 Post(s)
Liked: 293
Well, that's one way to make it quiet! Actually, that was one reason I finally made a server. I can have it work through the night in another room. I still would like to use my desktop at night though.
Sent from a mobile device.
leebo is offline
post #116 of 122 Old 05-19-2014, 10:58 AM
leebo's Avatar
Quoted: 525 Post(s)
Liked: 293
Originally Posted by Chronoptimist View Post
Don't use PWM fans if you want a quiet system.
That's what a PWM fan sounds like.
I only use voltage controlled fans, because the pulsing/ticking sounds from PWM fans really annoy me. And if you want really quiet fans, use Noctuas.
I have decided to buy a couple Noctuas. I have tried connecting my PSU fans to 5v. I've tried using a fan speed controller. although they do make the fan pretty quiet, I often use my PC's to re-encode BR's. When I re-encode without ltering anything with the PSU fan, the fans always ramp up after a few mins of encoding. This probably means temps are rising, and the increased fan speed may be necessary.
So I am worried about causing damage. I think it might be a good idea to try quieter fans, and keep them at 12 volts.
But Noctua makes fans with and without PWM. And both have tons of positive reviews on Newegg.
so b4 I order, should I avoid their PWM fans or not? what are the advantages of PWM fans (if any)?
Someone mentioned they have four wire pins. My PSU's seem to have only two pins (maybe three). so will I even be connecting the extra two pins? Will having only two pins connected effectively make a PWM fan a non-PWM fan?
leebo is offline
post #117 of 122 Old 05-19-2014, 03:11 PM
Chronoptimist's Avatar
Liked: 532
For what it's worth, I recently replaced all the fans in my case with Noctuas, and while I intended on using them as voltage-controlled fans, they have changed my opinion on PWM.
Noctua's PWM controller eliminates the audible distractions that I had with other PWM fans, and I would recommend them to anyone.
With the Noctua fans, they can be reduced to about 600rpm when using voltage control, but will go down to 300rpm using PWM - and even at 300 rpm there is no "ticking" or other noises from the fans caused by PWM driving.
So if you're buying Noctuas, I would definitely recommend PWM control. I still wouldn't recommend PWM controlled fans from another brand. (unless they do something similar)
Chronoptimist is offline
post #118 of 122 Old 05-19-2014, 04:05 PM
leebo's Avatar
Quoted: 525 Post(s)
Liked: 293
Sold! I'm going to get one for each of my three PC's that I use for encoding.
leebo is offline
post #119 of 122 Old 07-08-2014, 02:31 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
so was there a proper outcome to this thread? final solution ?
Mfusick is offline
post #120 of 122 Old 07-09-2014, 08:40 AM
Aluminum's Avatar
Quoted: 22 Post(s)
Liked: 25
Buy a fanless plat w/ 7 year warranty for $100 or sometimes less on sale. Sometimes you do get what you pay for.
When I stopped caring about super quiet: E5 1680v2 @ 4.5Ghz, 980ti, i750 SSD - JS9500 & Dell P2715Q for dual 4k@60 because reasons
SAN shares over 56Gb infiniband, microcenter + fleabay = severe risks to my wallet
Aluminum is offline
Reply Home Theater Computers
