How to automaticaly Rip disks to server? Assassin HTPC - Page 2 - AVS Forum
post #31 of 33 Old 07-06-2013, 03:01 AM
pittsoccer33's Avatar
Quoted: 59 Post(s)
Liked: 192
most bluray drives are also subject to a "feature" called riplock. it slows the read speed of a drive way down, claiming its quieter while watching a movie. and theres probably some truth to that. the real reason though has to be to discourage and frustrate you in what youre doing.
if you dig around the web there are some guides and firmware floating around to remove this feature but ive never bothered with it.
My HTPC front end set up
Integration for whole home ATSC, CableCARD, FM radio, Blu-Ray, HD-DVD, DVD, VHS control & capture, video games, and archived & streaming media playback
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #32 of 33 Old 07-06-2013, 09:30 AM
Mfusick's Avatar
Quoted: 70 Post(s)
Liked: 663
You can change the region on many drives to remove this feature- or just flash it away with a firmware update. There is info on the MakeMKV forums.
I never bothered either. Mine works well enough.
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is online now
post #33 of 33 Old 07-06-2013, 11:47 AM
olyteddy's Avatar
Quoted: 45 Post(s)
Liked: 199
These drives aren't rip-locked. Inexpensive too: http://www.newegg.com/Product/Product.aspx?Item=N82E16827136250
olyteddy is offline
Reply Home Theater Computers
User Tag List
