Streaming High Bitrate H.264 Content via 1GB Ethernet versus Local Playback - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-04-2013, 06:09 AM - Thread Starter
Bizzy G.L.X.'s Avatar
Hi Everyone,
The time has come for me to build out a new HTPC, as my trusty Thermaltake DH101 has outlived it's usefulness (the VHD display went bad, plus all of the lights on the front where getting annoying).
I'm seriously considering building out a server that will act as a central repository for all of my media and a tiny mITX box acting as my HTPC.
Both would be connected via 1GB Ethernet.
Playback of the media would be thru Media Browser 3 Classic, being served by Media Browser Server (MB3 Server would be installed on the server).
Pretty straightforward stuff, a lot of people on this forum probably have very similar setups like this already.
Here's the question: Playback of high bitrate content via 1GB - anyone notice laggy seeking, dropped frames, stuff like that?
Case:Fractal Design Node 605
APU:AMD Richland A10-6700
RAM:8GB AMD 1866
Board:ASUS A88XM Plus
Storage:OCZ 256 GB Vector
Optical:Panasonic Slim BDR
PS:Silverstone Strider 550 Gold SFF
Software:WMC8+LAV+madVR+MPC-HC
Input:Logitech K400 mini KB/trackpad+Harmony 720
Output:Sammy 55" S6 LED LCD+Yamaha soundbar
Bizzy G.L.X. is offline
post #2 of 5 Old 07-04-2013, 06:51 AM
lockdown571's Avatar
Quoted: 36 Post(s)
Liked: 87
Gigabit: 1000 mb/s
Blu-ray: max bit rate ~40 mb/s
You will not have any issues streaming video over gigabit ethernet.
lockdown571 is online now
post #3 of 5 Old 07-04-2013, 07:23 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Originally Posted by Bizzy G.L.X. View Post
Hi Everyone,
Max bitrate for bluray is 55mbps if I recall so there will be no lag issues, especially if you are playing dxva files. If anything, you might notice latency issues depending on how you are set up.
DotJun is offline
post #4 of 5 Old 07-04-2013, 01:06 PM
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 80
yea, it just is simple math.
100 megabit is more than enough for bluray, which is 40 megabit tops iirc.
If you are talking about stuff you encoded from a camcorder, then it depends on the bitrate, but I can't imagine you using close to 1 gigabit bandwidth.
MlNDBOMB is offline
post #5 of 5 Old 07-04-2013, 05:43 PM - Thread Starter
Thanks much Lockdown, DotJun, Mindbomb, your advice makes total sense.
I performed some testing this morning to help satiate my curiosity:
Test Beds
1) Installed MB3 Server on an old desktop (Phenom II x4, 8 GB DDR3 1333 RAM, two 1 TB WDD HDDs)
2) Copied up 5 different folders containing MKVs of varying bitrates (all where pretty high, pretty large rips) and their metadata and stuff
3) Uninstalled MB2.x and installed MB3 Classic on my current HTPC (LAV Splitter, LAV Video, LAV Audio, EVR)
4) Played back content thru MB3 Classic, streaming from MB3 Server, 1 GB Ethernet between both systems
Streaming Test 1: Results of Streaming Video vs Local Playback
1) Picture quality - Good, streaming versus local no difference
2) Seeking (FWD/RR) - Good, streaming versus local, no difference
Test 2: Results of Streaming Video vs Local Playback - Heavy Disk I/O on the Server
For this test, I started copying 30 GB of data between both WD Green HDDs on the server.
Disk I/O hovered about 60 MB/sec
CPU usage was nil
2) Seeking (FWD/RR) - Not good, streams kinda froze up a bit, sometimes got to the point of being unwatchable
Final Thoughts
As I am heavily dependent on seeking forward and backwards, I'll need to build out a Media Server with a good disk subsystem. I'm thinking WD Reds (maybe Greens) in a RAID array.
I know, it sounds weird that I care so much about seeking, but I have a habit of falling asleep while watching stuff and need to seek to the point I left off. Also, I like to watch scenes two, sometimes three times in a row to make sure I get all of the dialogue and take in the settings, etc.
RAM:8GB AMD 1866
Reply Home Theater Computers
