Not getting 5.1 Output from Quicktime Files - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-04-2013, 08:59 AM - Thread Starter
cw4u's Avatar
I'm having trouble getting 5.1 output from my quicktime files. All .mov files I play are outputting as PCM 2.0. Any other format outputs correctly. I'm using a Mac Mini with optical audio output into my receiver. I'm running Windows 7 64 bit with Shark007 installed.
Any help would be appreciated.
cw4u is offline
post #2 of 4 Old 07-04-2013, 09:17 AM
Shark007's Avatar
Quoted: 80 Post(s)
Liked: 73
few MOV files have 5.1 audio but those that do usually use AAC.
To get control over them, disable the Microsoft Audio decoder on the SWAP TAB.
This should give you multi-channel pcm to the receiver.
To know the actual contents of any video (speaker count etc), use the button on the Misc TAB to [Analyze a media file]
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
post #3 of 4 Old 07-04-2013, 09:53 AM - Thread Starter
cw4u's Avatar
I've got LAV Audio now showing that it's inputting 5.1 AAC and outputing 5.1 PCM. However, my receiver is still showing that it's receiving 2.0 PCM.
Any other suggestions?
cw4u is offline
post #4 of 4 Old 07-04-2013, 10:02 AM
Shark007's Avatar
Quoted: 80 Post(s)
Liked: 73
Sorry, I overlooked the fact that you are using optical to carry the audio to the receiver.
Optical cannot carry 5.1 pcm, only 2.0
Although I rarely recommend it, you'd need to use ffdshow to decode the audio and use it to re-encode to AC3 on the fly.
To do this, on the Audio TAB, use the button to [disable LAV audio]
Then, on the Config TAB, use the button to access [FFDshow Audio config]
Scroll the leftside and click on Output then check the box for [x] AC3 (SPDIF encode mode)
and also check the box for [x] Encode 5.1 streams only
Shark007 is offline
Reply Home Theater Computers
