Logitech Wireless Touch Keyboard K400 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 07-08-2013, 05:02 PM - Thread Starter
macman13's Avatar
Bought it for $20 at Target, works perfectly with both of my HTPC's.
2x HDHomeRun Prime - 3CC
Sharp 65" TV; Sharp 46" TV; Panasonic 42" TV; Sony 40" TV; Sony 32" TV
WMC HTPC Server: Intel Celeron G1840, 4GB RAM, MSI H81M-P33, 1TB
Main HTPC: Mac Mini 2.3Ghz i5, 8GB RAM, 500GB, 1TB, 2TB, 3TB
XB360 WMC Extender, Ceton Echo, Roku 3, Apple TV 3
macman13 is offline
post #2 of 18 Old 07-08-2013, 05:03 PM - Thread Starter
macman13's Avatar
Oh crap, I accidentally made a new thread. How do you delete threads?
macman13 is offline
post #3 of 18 Old 07-09-2013, 07:05 AM
pittsoccer33's Avatar
Quoted: 650 Post(s)
Liked: 432
that looks exactly like the Revue's keyboard, minus a few Google TV specific keys. I've used that with my HTPC and it works pretty well. Adding function keys is a huge win.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #4 of 18 Old 07-09-2013, 08:34 AM
SlantNGo's Avatar
If you use Logitech's SetPoint software, beware that versions 6.50 and up (necessary to support the new Logitech K400r revision) have a bug that cause them to chew up CPU cycles when your computer is idle: http://forums.logitech.com/t5/Mice-and-Pointing-Devices/high-cpu-dwm-exe-due-to-setpoint-in-win-8/td-p/923142
This drove me crazy for months. The best solution seems to be using the Task Scheduler or an AutoHotKey script to kill SetPoint when the computer goes idle and restart it when the computers is active again.
SlantNGo is offline
post #5 of 18 Old 07-09-2013, 08:49 AM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
Good information as I am considering getting a K400. Maybe I should look elsewhere?
Sammy2 is offline
post #6 of 18 Old 07-09-2013, 09:01 AM
itznfb's Avatar
Liked: 58
Get a K400 as long as you can fine one for $20 or less. If you're going to spend the $40~$50 MSRP you might as well get a Logitech Mini Controller.
Don't worry about the SetPoint bug since you should never install SetPoint anyway. Windows is perfectly capable of handling the keyboard without SetPoint.
Running Windows Home Server 2011 Evil Abandoned Edition
itznfb is offline
post #7 of 18 Old 07-09-2013, 09:08 AM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
Even Better information! I'm going to move my RiiN7 mini to the echo and get a new keyboard for the HTPC proper.
Sammy2 is offline
post #8 of 18 Old 07-09-2013, 11:07 AM
SlantNGo's Avatar
If you can find a way to disable "smooth scrolling" without SetPoint, let me know. Logitech seem to have written the driver in a way such that they have their own built-in "smooth scrolling", which wreaks havoc with the Windows 8 modern UI and certain other applications that have also implemented smooth scrolling. I haven't found a way to disable the built-in Logitech "smooth scrolling" aside from using their software, which appears to intercept the touchpad input and filter it so it appears "unsmoothed".
SlantNGo is offline
post #9 of 18 Old 07-09-2013, 11:12 AM
SlantNGo's Avatar
I ended up getting one despite the odd keyboard layout because it's the best keyboard + touchpad combination I've found in terms of touchpad functionality. It supports Windows 8 edge swipes and several two-finger gestures, but there are two funny things about the touchpad:
1) Tap and drag works a bit funny. With a Synaptics laptop touchpad, the drag starts from where your second tap begins. With the K400 touchpad, the drag starts a little bit further out. So you need to start your tap and drag motion a bit off from where you really want to start. For example, if I wanted to move something to the left using tap and drag, I need to start the tap and drag motion a few pixels to the right of the object.
2) Two finger tap for right-click works only about half the time. It's not like independent coin flips either. If it doesn't work, repeatedly doing the two finger tap won't do anything. You need to move the cursor a little bit using one finger then try to repeat the two finger tap.
With that being said, it is still the best keyboard + touchpad combo that I've found. Even with the SetPoint software bug, I would still recommend it because it's better than anything else out there, especially at the $30 price point. It's a sad state of competition really.
SlantNGo is offline
post #10 of 18 Old 07-09-2013, 11:23 AM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
I'm not very worried about Win8 usability. I assume that these problems are more specific to Win8 over Win7?
Sammy2 is offline
post #11 of 18 Old 07-09-2013, 12:55 PM
itznfb's Avatar
Liked: 58
I'd have to install Win 8 and play around with it. I haven't seen a reason to use Win 8 over Win 7 though.
I'd still question it's value at $30... The Logitech Mini Controller is an exponentially superior HTPC keyboard at only $20 more. The $20 is worth the back-lighting alone for most people. As I said in another thread I picked up the K400 when it's MSRP was $14.99 and it was on Amazon for $11.99. I really wouldn't consider it worth much more than that.
Yeah. Just plug in the wireless usb controller and you're good to go in Win 7 and earlier.
itznfb is offline
post #12 of 18 Old 07-09-2013, 01:09 PM
SlantNGo's Avatar
The SetPoint bug I think is not Win8 specific--some of the complaints from that thread come from Win 7 users, and since it's causing DWM to hog CPU cycles I'd guess that it affects Vista even as well. If you can do without the Setpoint software, you'll be fine. As I mentioned, the main reason I run SetPoint is to kill the Logitech smooth scrolling implementation. Even if you do decide to run SetPoint, it's not a dealbreaker--you can just run an AutoHotKey script or a scheduled task to kill SetPoint when your computer goes idle. I think I'm more frustrated in general that Logitech's software is behaving so poorly and that they refuse to acknowledge this as a bug.
SlantNGo is offline
post #13 of 18 Old 07-09-2013, 01:09 PM
bob2300NX's Avatar
Well I guess thats why everyone has different tastes. My friend has the diNovo Mini and honestly I feel the K400 is more usable. Its slightly bigger yet is alot more usable and comfortable (rest on lap while surfing). I like the backlight but its not a big deal since I am using the k400 when tweaking (daytime or lights on at night) and using my harmony when watching a movie (when lights are out).
bob2300NX is offline
post #14 of 18 Old 07-09-2013, 01:48 PM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
That sounds like my usage scenario with a keyboard but my kid uses the backlit Rii N7 when I'm asleep to thumb through youtube. I think that a "full" keyboard would be better for this use but not having it backlit is a "minor" drawback.
I'm not sure what the issue is with the scroll smoothing? Is it jerky without the setpoint software?
Sammy2 is offline
post #15 of 18 Old 07-09-2013, 02:11 PM
bob2300NX's Avatar
I dont use the software and havent noticed any problems. I will let you know how scrolling is when i get home.
post #16 of 18 Old 07-09-2013, 02:58 PM
mdavej's Avatar
Quoted: 2257 Post(s)
Liked: 985
The Logitech software does indeed smooth the scrolling quite a bit as well as let you redefine some of the keys and set some other options which I find useful. It is a memory hog, but I've got plenty, so it isn't so bad.
mdavej is offline
post #17 of 18 Old 07-09-2013, 03:32 PM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
I don't need any memory hog crappy code on my HTPC!
Sammy2 is offline
post #18 of 18 Old 07-10-2013, 01:21 AM
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
I like the size of the K400 & use it for maintenance or occasional browsing, neither of which I do in the dark so lacking backlit keys is not an issue in my situation.
Mike99 is offline
Reply Home Theater Computers
