xbmc sevear shutter, Movie un-watchable. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-10-2013, 01:11 AM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Hey guys, I am getting servere shutter in my living room HTPC, so bad that it takes about 2 mins to get through the first comic intro on Avengers (That usually takes only seconds to finish) The basement works great, but that was setup by the guys at Assassin. Is there something in the settings that need to changed or could this be a hardware issue like the PC itself, the router or cabling to the server? I have the AMD A10 5800K apu with 8 gig of memory for the HTPC.
Cheers Dave
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is offline
post #2 of 3 Old 07-10-2013, 03:35 AM
CountryBumkin's Avatar
Quoted: 214 Post(s)
Liked: 54
Try copying the file/movie to the HTPC and playing directly from there - to see if the stutter is due to network/streaming issues.
JapanDave likes this.
CountryBumkin is offline
post #3 of 3 Old 07-10-2013, 07:34 AM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
I tried another PC on the same line and it did not have the proble, so I re-installed xbmc and all is fixed. Thanks for the help.
My build thread
Reply Home Theater Computers
