controlling my computer with my harmony one remote. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-10-2013, 09:15 AM - Thread Starter
duder1982's Avatar
Quoted: 14 Post(s)
I have xbmc loaded to a computer, with all my movies loaded in standard def. Since I don't think the processor can handle blue ray. Anyway I am going to run the cable this week to my Onkyo receiver. I have a harmony one remote I would like to control everything with. Can someone point me in the right direction on how to do this and what hardware/software I may need.
Duder
duder1982 is offline
post #2 of 11 Old 07-10-2013, 09:30 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
http://www.ebay.com/itm/Brand-NEW-Original-Genuine-HP-USB-MCE-IR-Wireless-Receiver-Win7-Vista-US-fast-/270929871250?pt=US_Remote_Controls_Pointers&hash=item3f14adc192
Buy one of these and program as:
Media Center PC – Microsoft – “Windows Media Center SE”
in the harmony software, nothing else to download.
Works with my computer to sleep and wake with the power toggle command.
oman321 is offline
post #3 of 11 Old 07-10-2013, 11:10 AM - Thread Starter
duder1982's Avatar
Quoted: 14 Post(s)
So I just plug it into a usb port, and program it under harmony as media center pc-microsoft-"windows media center se". And all should work. Thanks that is what I have been looking for. How well is the ir range, as my computer is to the side of me and the receiver is in front of me. I guess I could all ways get a usb extension.
Thanks again.
post #4 of 11 Old 07-10-2013, 11:22 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
I'm sure it's ok. I have my equipment in a closet and use the Harmony 1100 with the RF extender so an emitter is attached right to it.
oman321 is offline
post #5 of 11 Old 07-10-2013, 01:07 PM - Thread Starter
duder1982's Avatar
Quoted: 14 Post(s)
Thanks for the input, for the price I went ahead and ordered it. I think this will work, thanks again for the heads up.
post #6 of 11 Old 07-10-2013, 02:18 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
No problem. This community is so helpful in many things, just a small way to pay it forward.
I was worried about the many knock offs. The wake/sleep commands were critical to me so I was thrilled to verify that it worked.
I've had it for about a month and so far it's been flawless.
oman321 is offline
post #7 of 11 Old 07-10-2013, 05:00 PM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
Been using the same HP IR receiver for several years with a Harmony One. Works great.
captain_video is online now
post #8 of 11 Old 07-10-2013, 05:15 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Some non-MCE dongles work well too, especially with xbmc, like Ortek/Adesso. It's quite a bit smaller than the HP and has an extension built in. It doesn't work with windows media center codes, rather it uses Ortek codes. It has never failed to sleep/wake and also works great on raspberry pi.
mdavej is offline
post #9 of 11 Old 07-11-2013, 09:33 AM
jsketto's Avatar
Quoted: 12 Post(s)
i would also check out EvenGhost....I use it with my harmony and it is AMAZING for setting up Macros and controlling all of your software like XBMC or WMC/Hulu
Streamcom Fanless FC5
Zotac Z68-ITX Wifi
Intel i3 2125
G Skill Sniper DDR3-2133 8 GB x2
Mushkin Chronos 60GB SSD
jsketto is offline
post #10 of 11 Old 07-11-2013, 11:02 AM
Quoted: 510 Post(s)
Liked: 336
EventGhost is a great app if you need control beyond what your remote can handle when programmed for Windows Media Center. I've found that setting it up to control WMC also allows it to control just about every other app on my PC, including XBMC and VLC Media Player.
post #11 of 11 Old 07-11-2013, 11:31 AM - Thread Starter
duder1982's Avatar
Quoted: 14 Post(s)
I couldn't agree more, I don't come here often as I really don't have alot of time. But when I do peeps are all ways helpful. Thanks
Reply Home Theater Computers
