HTPC 2.1 Audio Only w/ nVidia HDMI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-10-2013, 11:49 AM - Thread Starter
Dirtydeedz's Avatar
Hey! Thanks for reading my post.
I recently put my HTPC online.
1. Mobo - nVidia GeForce 9400-T2RS LGA 775
2. Video - nVidia 620GT-EX + Onboard
3. Receiver - Yamaha RX A1000
4. Display - Sharp Aquos
5. OS - Win7 x64
Basically the HTPC only sees the Sharp TV which isn't 5.1 or 7.1 so it doesn't output 5/7.1
Is there anyway to force Surround Sound?
Dirtydeedz is offline
post #2 of 5 Old 07-10-2013, 01:41 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
Does your receiver have some kind of pass through feature to hear audio on the tv? Might be your problem.
Mrkazador is offline
post #3 of 5 Old 07-10-2013, 02:59 PM
Postmoderndesign's Avatar
Quoted: 305 Post(s)
Liked: 143
Right click the speaker icon in the lower right corner of your display. Left click on playback devices. Your sharp TV should be listed if the computer sees it as an audio device. Right click on the TV and set it as the default device. Then click on configure in the playback device window and set the number of speakers your TV has. Or do you have speakers connected directly to your receiver? If so set the receiver as the default device and configure it.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Postmoderndesign is offline
post #4 of 5 Old 07-10-2013, 03:18 PM
JJHTPC's Avatar
I have given this advice a few times. The best solution that I have found is to do dual display and use the HDMI to the receiver and DVI to the tv. Use Extended display and set the tv as the main monitor. Then you should be able to set up bitstreaming and also be able to push the correct outputs to the TV. I had a somewhat similar problem that when I ran the video through my pioneer receiver it would only allow me to use 1080 60i as video output as it recognized only the receiver for the HDMI handshake. So I setup the dual monitor and have never had a problem.
JJHTPC is offline
post #5 of 5 Old 07-11-2013, 10:11 AM
--Sclaws's Avatar
Quoted: 32 Post(s)
Liked: 37
I have a 460GTX and couldn't get 5.1 to pass either...just 2.1, so I sort of caved and bought this http://www.amazon.com/gp/product/B00AHS8LD8/ref=wms_ohs_product?ie=UTF8&psc=1.
I now run optical direct to my receiver and HDMI to the display...for me it works great (short of reducing the number of cables to manage).
Vizio M801D-A3
JimK
--Sclaws is offline
Reply Home Theater Computers
