XBMC setup advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 07-11-2013, 03:08 PM - Thread Starter
wasp23's Avatar
Please could anyone offer any advice on setting up xbmc 12.0 Frodo to playback using external players ?
I can get the internal xbmc player to play back every format ok except for when files have HD audio and then they stutter badly.
I want to set it up to use Total Media Theater 6.0 but the xml files I have tried to setup have failed. The files I have which I am trying to play are mkv and Blu-Ray ISO.
Alternatively is there a way to get HD audio playing back perfectly through XBMC ?
wasp23 is offline
post #2 of 14 Old 07-11-2013, 04:40 PM
mud sloth's Avatar
HD audio is supported in XBMC. Check this out for supported formats and how to set it up, depending on your hardware: http://wiki.xbmc.org/index.php?title=AudioEngine
mud sloth is offline
post #3 of 14 Old 07-12-2013, 12:58 AM - Thread Starter
wasp23's Avatar
I have checked and I'm missing the following options in the audio menu of xmbc
Audio output device – Direct Sound Speakers- Speakers
Passthrough output device - Direct sound
my setup is xmbc frodo 12.0
graphics card asus 6450 graphics card
hp micro server 8gb ram
avr receiver onkyo 606
I can play HD audio with tmt 6 or powerdvd 13 without issue.
Any help is greatly appreciated.
wasp23 is offline
post #4 of 14 Old 07-12-2013, 06:26 AM
ikkuranus's Avatar
Quoted: 87 Post(s)
Liked: 53
Has to be wasapi for passthrough output.
ikkuranus is offline
post #5 of 14 Old 07-12-2013, 07:52 AM - Thread Starter
wasp23's Avatar
Thanks for the reply
I have re-installed the software and I now have the options for direct sound and passthrough and have set to wasapi and now have hd sound, however the video playback is not natural and kind of runs slow then catches if that makes sense.
Do you I need to change any video settings or is this still audio related ?
Thanks in advance
wasp23 is offline
post #6 of 14 Old 07-12-2013, 09:16 AM
wpbpete's Avatar
Quoted: 119 Post(s)
Liked: 110
This is most likely an audio setting. While playing a movie click the audio button on the bottom right. You'll be able to see the video change while you're making changes. Hope this helps. Btw...are you using HDMI PC to receiver?
wpbpete is offline
post #7 of 14 Old 07-12-2013, 09:56 AM
Charles R's Avatar
Liked: 649
Under Video Settings you might try toggling Allow hardware acceleration.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Sony UBP-X800 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Roku Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #8 of 14 Old 07-12-2013, 10:26 AM
ikkuranus's Avatar
Quoted: 87 Post(s)
Liked: 53
That option is usually enabled by default.
post #9 of 14 Old 07-12-2013, 12:44 PM - Thread Starter
wasp23's Avatar
hardware accelaration enabled
are there any 3rd party codecs thaty i need to install ?
wasp23 is offline
post #10 of 14 Old 07-12-2013, 01:36 PM
Charles R's Avatar
Liked: 649
Yep. And often I have to disable it.
post #11 of 14 Old 07-13-2013, 08:15 PM
sycochkn's Avatar
I sometimes get bars of messed up video on a couple of movies when using hardware acceleration. Blu-ray ISOs
Subtitles are also enabled by default. You can disable them in the audio settings menu.
sycochkn is offline
post #12 of 14 Old 07-13-2013, 11:59 PM - Thread Starter
wasp23's Avatar
Thanks for the replies
The screen flickers for a millisecond through out the film and any Format of media
It only happens when playing directly from the htpc in tmt6 or power DVD 13 if I stream using plex it does not do it.
Any ideas ?
wasp23 is offline
post #13 of 14 Old 07-14-2013, 12:46 PM - Thread Starter
wasp23's Avatar
Hi guys. I have tried playing media files through all combinations of setup I can think of and have come to the conclusion that it only gets the flicker when I am playing videos through windows. When I stream files direct to the tv through it's in-built streamer they play fine with no flicker but obviously no HD audio which is no good.
The same flicker is also noticeable when in Windows and I am using firefox. It can clearly be seen when scrolling up and down in the browser window. I believe the issue is with either windows 7 or the graphics card itself or even the drivers. I have tried the latest stable release of the drivers and also the newest beta version but with the same result.
My card is am ATI HD6450 with the following software
wasp23 is offline
post #14 of 14 Old 07-16-2013, 06:22 AM
wpbpete's Avatar
Quoted: 119 Post(s)
Liked: 110
Have you solved this issue yet? If you haven't, here's imo the most helpful thread on all things Xbmc
http://forum.xbmc.org/showthread.php?tid=146911
wpbpete is offline
Reply Home Theater Computers
