Help me choose an HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 40 Old 07-13-2013, 08:09 AM - Thread Starter
ChrisHarrington's Avatar
I've been using my primary desktop as my WMC for the past 3 years with 3 Xbox's as extenders. Up to this point it has worked great, but it has recently started blue screening on me all the time, like 5 times a day. So it's time to upgrade the 6 year old desktop. I'm thinking of getting rid of my primary desktop and replacing it with a laptop and a dedicated htpc. My thoughts are using an HTPC with a small SSD and connecting This [http://www.amazon.com/gp/product/B002UUPWP6/ref=ox_sc_act_title_4?ie=UTF8&psc=1&smid=A2WSTUX2A6RQ1A] to my Asus router to store and stream all my media from. I have all gigabit switches and router and think this should work with no problem. I think..
My problem is I can't seem to decide what I need for my actual HTPC. I will be doing NO gaming on it or browsing. I only want to run Windows Media Center, Netflix, Amazon Prime, etc. and stream to my extenders. I have it narrowed down to 3 choices and wondered if anyone had input on any of them.
1) the cheapest way to go ($237): refurbished Gateway SX2110G-UW308 (DT.GDYAA.001) AMD Dual-Core Processor E1-1200(1.40GHz) 4GB DDR3 500GB HDD Capacity AMD Radeon HD 7310 Windows 8
I would replace the 500gb hdd with a 64 or 128gb ssd and I should be able to fit my old tv tuner in this unit.
2) the flashiest way to go ($663): refurbished DELL Alienware X51 AWX5061990501SA Intel Core i3 3220(3.30GHz) 6GB DDR3 1TB HDD Capacity NVIDIA GeForce GT 640 / 1GB Windows 8 64-bit
Again, I would replace the 1tb hdd with a 64 or 128gb ssd but in this instance I would have to buy another HDHomerun.
3) the techiest way to go ($510): Intel NUC with Dual HDMI, Gigabit LAN, Core i3-3217U DC3217IYE, Lite On Plextor M5M 2.5-Inch 128GB mSATA Solid State Drive (M5M 128GB), Komputerbay 8GB (2x 4GB) DDR3 SODIMM (204 pin) 1333Mhz PC3 10600 8 GB (9-9-9-25)
This price doesn't include O/S, I'm assuming the version of windows 7 I have will work with it. It should. I will need another HDHomerun with this build too.
Samsung HL-67A750A1F | Pioneer VSX-1121-K | Energy Take Classic 5.0 | BIC America F12 | Xbox 360 Windows Media Center 7 | Belkin PureAV PF30
ChrisHarrington is offline
post #2 of 40 Old 07-13-2013, 03:20 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
Another option is a PC from the Dell Outlet website.
Mrkazador is offline
post #3 of 40 Old 07-13-2013, 03:35 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
I will try to help you out. (You need it wink.gif )
First,
Don't waste your time. A 1.4ghz AMD is worthless IMO. It's time for you to get something new.
I could build you a hell of a lot better HTPC for $663. 6GB seems stupid on an i3. Either run 8 or 4 in dual channel. That's my first thought. Sounds like they had some crap ram they needed to dump. I would go 2x2GB for budget and 2x4GB for performance- I would never mix em up and go 6GB. That video card is dated, and not expensive. And you would still replace the HDD with SSD??
I forbid you to do this. Or purchase it.
This option is the best option of the ones you listed. At least you get a decent little cute machine.
But I would still think you would be better off building your own HTPC for less $$$
Mfusick is offline
post #4 of 40 Old 07-13-2013, 03:38 PM
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
Hmm...
If only there was a company with affordable custom HTPC options...
assassin is offline
post #5 of 40 Old 07-13-2013, 03:44 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
How about:
Ivy Bridge CPU like G2020 ($60)
Asrock Mobo ($70)
Silverstone MILO 3 ($59)
PSU ($29)
DDR3 RAM ($40)
SSD 64Gb for Vertex4 for $70 or Sammy 840 128GB for $99
If you wanted a video card grab a $69 7750 GPU which is better IMO.
I could build you a better HTPC than your looking at for under $250 if I really started deal hunting.
Mfusick is offline
post #6 of 40 Old 07-13-2013, 03:47 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Originally Posted by assassin View Post
Hmm...
Not a bad option for him if doesn't want to build himself. At least he will get something proper, including a NUC if that is his thing.
BTW- Did you see this ???
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148690&cm_sp=&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=6146819&SID=afop7jhm53el
$6.99 LOL.
Too bad it's worthless ATA100. Still- that's cheap.
Mfusick is offline
post #7 of 40 Old 07-13-2013, 03:48 PM
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
$6.99 LOL.
IDE
assassin is offline
post #8 of 40 Old 07-13-2013, 03:52 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Yeah. I know. I said that above ^
Mfusick is offline
post #9 of 40 Old 07-13-2013, 04:37 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
OP,
How about this:
ASRock B75M R2.0 LGA 1155 Intel B75 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard with UEFI BIOS $62.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157356
Intel Pentium Dual-Core Processor G2020 2.9GHz 5.0GT/s 3MB LGA 1155 CPU, Retail $57.99
http://www.superbiiz.com/detail.php?name=G2020BOX
APEX DM-387 Black Steel Micro ATX Media Center / Slim HTPC Computer Case w/ ATX12V Flex 275W Power Supply $41.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811154087
SAMSUNG 840 Series MZ-7TD120KW 2.5" 120GB SATA III Internal Solid State Drive (SSD) $109
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147185
Mushkin Enhanced Essentials 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model 997029 $36.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226285
You could save about $30 more with a 60GB SSD instead of the premium Samsung 840 128GB.
Something like this for $79:
Mushkin Enhanced Chronos MKNSSDCR60GB 2.5" 60GB SATA III Asynchronous MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226247
This would be at least as good as all the stuff your looking at.
Lots of fine tuning options if you prefer mini ITX or a different case look etc....
Also,
You can always upgrade to something like this:
XFX FX775AZNJ4 Radeon HD 7750 1GB DDR5 CI-Express 3.0 x16 Video Card $65
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150663
Depending on the case and PSU you use^
I think build it yourself is the way to go.
Mfusick is offline
post #10 of 40 Old 07-13-2013, 04:39 PM - Thread Starter
Thanks for the replies, and if it seems like I don't know what I'm doing... it's because I don't. I've been running a Media Center PC for 3 years now on my AMD Athlon 64 X2 Hewlett Packard machine with 3 gigs of ram which I bought 6 years ago. It's dying and I'm trying to do it right this time, but I don't want to spend a ton of money. I would like to have an HTPC for under $500. I have a 2 terabyte internal and a 1 terabyte external drive as well as an old 500gb internal. I wanted to use those for storage so I don't care if the pc itself has ****e for hard drive space. I just want something that works good on the cheap. I would also like something that is a lot more energy efficient than what I'm currently using. I know this thing is killing my electric bill.
post #11 of 40 Old 07-13-2013, 04:45 PM - Thread Starter
I have never built a pc before and it's a little daunting. It's the software side especially that scares me. I have replaced hard drives before and that's easy, but to install the drivers and everything is very new to me. I will look at all the things you put on that list
post #12 of 40 Old 07-13-2013, 04:49 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
That build I put above is perfect and about $300. Under $300 with 60GB SSD, just over $300 with premium Samsung 128GB SSD. You can use your existing hard drives for storage, they would work well with that build. You mentioned you already have windows 7 too- so it's nearly a no brainier for you.
Assassin has a really good set up guide available that would walk you through putting it together, installing windows, and setting up the HTPC software. I think that's a smart move for you given your starting position. You'd learn a lot really easy and really fast, and that would make you really happy biggrin.gif
Saving $200+ on hardware costs and getting just as good a machine I think you can splurge the $25. The hard part is setting it up. No one seems to get that part right without hours of tinkering, testing, and a little bit of luck. I took me about 10 HTPC builds before I truly felt like I understood it well. His guides would walk you right through it.
There is really nothing to be scared about. If you've replaced a hard drive you can do this.
Mfusick is offline
post #13 of 40 Old 07-13-2013, 05:08 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
If you care about the noise and wattage like you mentioned in PM- Your better off making an SSD only HTPC biggrin.gif
use your drives in a NAS or server connected to your network. That would keep your build cool and quiet. You had a link to a NAS - do you own that or your just considering it ?
Mfusick is offline
post #14 of 40 Old 07-13-2013, 05:25 PM
junglalien's Avatar
junglalien is offline
post #15 of 40 Old 07-13-2013, 05:31 PM - Thread Starter
Don't own it was thinking of buying it to use as my storage. It would be plugged into the router on the other side of the room on my desk
Sent from my GT-N8013 using Tapatalk 4 Beta
post #16 of 40 Old 07-13-2013, 05:47 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
You could re-purpose your existing machine as a server for next to nothing in cost wink.gif A clean install of windows of $39 WHS would likely be in order- or you can run it off a USB stick with Unraid.
Mfusick is offline
post #17 of 40 Old 07-13-2013, 06:40 PM - Thread Starter
My existing machine is no good. I just did a fresh install and am still getting constant blue screens.
post #18 of 40 Old 07-13-2013, 07:53 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
post #19 of 40 Old 07-15-2013, 07:39 AM - Thread Starter
OK, I've decided to take the plunge. I've listened to things people have said and read so much stuff my head hurts but I think I'm going to attempt to build my own HTPC and this is what I'm going to use.
Case
$45 In-Win 200-Watt Mini-ITX Case, Black BP655.200BL http://www.amazon.com/gp/product/B005ITOAL8/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Motherboard & RAM
$130 MSI Z77IA-E53 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 Mini ITX Intel Motherboard with UEFI BIOS http://www.newegg.com/Product/Product.aspx?Item=N82E16813130673
$0 Crucial Ballistix Sport 8GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Profile Desktop Memory Model BLS8G3D1609ES2LX0 http://www.newegg.com/Product/Product.aspx?Item=N82E16820148661 (included with MOBO right now)
CPU
$137 Intel Core i3-3225 Dual-Core Processor 3.3 GHz 3 MB Cache LGA 1155 - BX80637i33225 http://www.amazon.com/gp/product/B0093H8H8I/ref=ox_sc_act_title_4?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Hard drive
$64 SanDisk 64 GB Solid State Drive with Low Power Consumption SDSSDP-064G-G25 http://www.amazon.com/gp/product/B007ZWLRSU/ref=ox_sc_act_title_5?ie=UTF8&psc=1&smid=A5NGTWX0QUPDH
$7 Silverstone Tek 3.5-inch to 2 x 2.5-Inch Bay Converter (SDP08B) http://www.amazon.com/gp/product/B008O510FW/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Optical Blu-Ray drive
$60 Pioneer Electronics USA 15x SATA Internal BD/DVD/CD Burner with 4 MB Buffer BDR-208DBK http://www.amazon.com/gp/product/B00A4ZXE40/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Network storage bay for my existing 3.5 terabytes of hard drives
$90 Mediasonic HF2-SU2S2 ProBox 4 Bay Hard Drive Enclosure for 3.5" SATA Hard Drives http://www.amazon.com/gp/product/B002UUPWP6/ref=ox_sc_act_title_5?ie=UTF8&psc=1&smid=A2WSTUX2A6RQ1A
Total $443 for the PC
Grand total $533
Little pricier than I initially wanted, but I got carried away. Should be a very worthy machine. Any thoughts?
post #20 of 40 Old 07-18-2013, 08:28 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
I like 128GB SSD these days for value and for the extra size and speed. Not a deal breaker but just a thought. You spent up on the i3 I see, so a few extra for a Samsung 840 128GB $89 now one newegg might be worth it.
I am a bit of an SSD snob and hypersensitive so feel free to discard my thoughts tongue.gif
Mfusick is offline
post #21 of 40 Old 07-29-2013, 04:56 PM - Thread Starter
If looks like the i3 has thermal paste on it, do I need to put anymore on?
post #22 of 40 Old 07-29-2013, 05:13 PM
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
No, you do not.
ChrisHarrington likes this.
assassin is offline
post #23 of 40 Old 07-29-2013, 05:39 PM - Thread Starter
No, you do not.
Thanks. I'm a total noob. This will be my first attempt to build a pc. Trying to read up as much as I can before I begin.
post #24 of 40 Old 07-29-2013, 05:49 PM
adam1991's Avatar
Quoted: 40 Post(s)
Liked: 43
Been there, done that.
I screwed up the CPU fan install, and ended up back at Micro Center to get something to remove all the old paste as well as a tube of new paste.
If (when?) that happens to you, don't worry.
adam1991 is offline
post #25 of 40 Old 07-29-2013, 05:50 PM
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
No problem. Take a look at the FAQ tab at my blog as there are some classic questions and answers there that may help as well.
assassin is offline
post #26 of 40 Old 07-30-2013, 05:47 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
me too.
That is how I discovered the thermal paste remover and surface purifier. I use that to remove the stock thermal paste if I am using aftermarket thermal paste. I keep a tube laying around.
Mfusick is offline
post #27 of 40 Old 07-30-2013, 05:59 PM
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
Something I discovered that is an amazing thermal paste remover and cleaner is alcohol based hand sanitizer (the gel kind). A little goes a long way and for most people its free!
Edit: As with any alcohol based cleaner make sure it all evaporates after cleaning before applying any heat (i.e. a CPU).
assassin is offline
post #28 of 40 Old 07-30-2013, 06:13 PM
Jsolo's Avatar
I used this on my last build
http://www.coollaboratory.com/en/products/liquid-ultra/
It's not exactly a paste. More along the lines of similar consistency of mercury, but not as toxic. Works extremely well with my delidded 3770K.
Jsolo is offline
post #29 of 40 Old 07-30-2013, 06:37 PM - Thread Starter
I have one stick of RAM (8gb), is it OK to just use one or do I need to install 2? And if so, does the second one also have to be 8gb?
post #30 of 40 Old 07-30-2013, 06:39 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
I have this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100010&Tpk=thermal%20paste%20remover
It's really quite excellent. I have a couple of them.
Mfusick is offline
Reply Home Theater Computers
