Need advice w/ WiFi antenna/ signal booster - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-17-2013, 07:23 AM - Thread Starter
stevethebrain's Avatar
Quoted: 108 Post(s)
Liked: 25
recently the router that I'm connecting to has been relocated farther away from me so I having very weak internet if any at all.
Speed is is 144Mbps, it's never been more than 54Mbps however it reduces down to 1Mbps
The 1Mbps connection is actualley (when I have a connection) stronge enought to download W7MC TV guide.
signal quaility is 5 bars
This is the WiFi adaptor I'm using it really helped alot to increase the signal quaility to 5 bars however there's still connection problems.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166056
Maybe a WiFi antenna will increase the WiFi signal like this one?
http://www.tp-link.com/en/products/details/?model=TL-ANT2414A#spec
I believe this type antenna can only be connected w/ it's coax cable to a PCI type WiFi adaptor
I'm thinking I unscrew the small plastic antenna from the PCI module and connect this antenna in it's place? I wanting to conect to net w/ both Lap top and desktop.
Are there WiFi USB signal boosters available?or can I unscrew the Roswells plastic antenna and swap w/ the TL-ant?
Any advice on this situation is apresheated STB
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #2 of 4 Old 07-17-2013, 10:17 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
You can replace the antennas on both the router and receiver, but you will be better served with a repeater, or WDS enabled router in between.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #3 of 4 Old 07-17-2013, 06:44 PM
4th-horseman's Avatar
4th-horseman is offline
post #4 of 4 Old 07-17-2013, 07:30 PM
bryansj's Avatar
Quoted: 1335 Post(s)
Liked: 625
bryansj is online now
Reply Home Theater Computers
