My Haswell i7 needs GRAPHIC CARD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 31 Old 07-18-2013, 09:55 PM - Thread Starter
iwanrs's Avatar
Quoted: 48 Post(s)
I newly upgraded my 4 years old AMD HTPC to the latest Haswell i7 processor HTPC without dedicated Graphic Card
I found out that picture quality out of Intel Haswell internal graphic processor is far below of that from the old HTPC running with ATI Radeon 5800 graphic card.
It looks grainy, dim, no contrast and not sharp.
I do direct comparison with my Denon AVR4520 through 2 HDMI inputs on Epson 1080p Projector.
My new Haswell HTPC has Windows 7 - 64bit
My old AMD HTPC running on Windows 8 - 64bit
Can anyone explain this ? I am very desperate about this issue.
Should I install additional Graphic Card, if yes which one?
THANKS
iwanrs is offline
post #2 of 31 Old 07-18-2013, 10:06 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
THANKS
http://www.avsforum.com/t/1464148/should-i-wait-for-haswell/200_100#post_23542449
Did you see my post ?
Mfusick is offline
post #3 of 31 Old 07-18-2013, 10:07 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I newly upgraded my 4 years old AMD HTPC to the latest Haswell i7 processor HTPC without dedicated Graphic Card.
I found out that picture quality out of Intel internal graphic card is far below of that from the old HTPC running with ATI Radeon 5800 graphic card.
0-255 versus 16-235.
That's your problem. Intel GPU integrated will only do 16-235 limited range over HDMI, so if your display, and your player are trying to do full 0-255 scale your going to get what your getting.
You must either set your player, your TV, and everything else to output 16-235 to match what the Intel GPU sends out- or upgrade to a GPU card that will do 0-255.
Imagine I told you to fit 255 somethings into a container that only holds 219 somethings (235 minus-16 = 219 ) It might get messy.
Your projector should accept both 16-235, and 0-255 so that's the good news.
Which player are you using for playback? how is it set ?
Mfusick is offline
post #4 of 31 Old 07-18-2013, 10:19 PM
JackDiesel14's Avatar
Quoted: 12 Post(s)
Liked: 31
Mfusick, if your mobo has display port can it do 0-255?
JackDiesel14 is offline
post #5 of 31 Old 07-18-2013, 10:24 PM - Thread Starter
iwanrs's Avatar
Quoted: 48 Post(s)
Mfusik,
My source is 1080p x264 mkv files (not BluRay disc).
Can you be more detail about the setting you mentioned above? I am not Computer Savvy guy.
My Projector is Epson full HD 3D Projector, should be technically up-to-date model.
iwanrs is offline
post #6 of 31 Old 07-19-2013, 07:16 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I meant what player your using to play the videos ???
VLC?
MPC-HC?
Wmc?
XBMC?
Mfusick is offline
post #7 of 31 Old 07-19-2013, 07:17 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
If your player is set to 0-255 but then your GPU sends 16-235 your going to have a problem.
Mfusick is offline
post #8 of 31 Old 07-19-2013, 11:06 AM - Thread Starter
iwanrs's Avatar
Quoted: 48 Post(s)
VLC?
MPC-HC?
Wmc?
XBMC?
VLC
But the display quality problem is in general speaking, even if I open IE browsing internet that's also the case. not only watching movies.
iwanrs is offline
post #9 of 31 Old 07-19-2013, 01:11 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
VLC
Yup.
I feel your pain. How do you have it hooked up ? What kind of cable? What kind of TV or monitor ?
You might want to set the control panel for Intel GPU to limited range- that should help. I am pretty sure your Projector and your AVR should accept limited range.
Mfusick is offline
post #10 of 31 Old 07-19-2013, 02:18 PM
JL-F1's Avatar
Did you set your desktop resolution/refresh rate to match the native resolution/refresh rate of the Projector?
Are you connected via HDMI?
JL-F1 is offline
post #11 of 31 Old 07-19-2013, 03:31 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
VLC
See this http://www.avsforum.com/t/1479632/intel-4770k-4600-video-issue. It will affect all outputs. But VLC itself also has some options that needs to be setup correctly (the video render option) first. Then, you need to match your projector to your iGPU output. Even if you are going to buy a new GPU, you still need to make sure it matches up. With Intel GPU, you just don't have option at all. It outputs limited range RGB on HDMI. The result of mis-match will be low contrast, washed out color.
Foxbat121 is offline
post #12 of 31 Old 07-19-2013, 08:55 PM - Thread Starter
iwanrs's Avatar
Quoted: 48 Post(s)
2 of my HTPCs (old AMD and new Intel Haswell) connected to Denon AVR4520(Denon latest model) through 2 same quality HDMI cables and from Denon via one 25ft HDMI cable to Epson projector HOME CINEMA 5010.
I am talking direct comparison of both HTPC's picture quality, huge difference in term of sharpness, brightness, contrast, also color, everything..
AMD is way far above Haswell, can not be right?
iwanrs is offline
post #13 of 31 Old 07-19-2013, 09:02 PM - Thread Starter
iwanrs's Avatar
Quoted: 48 Post(s)
Mfusick, you said in other thread:
I re-used my old 6870 XFX Radeon card.
If I was buying today I would get a 7770 or 7790 for $99-$150 or a 7850/7870 for the next step up.
I am also thinking in that direction.
What do you think the best Graphic Card we can get for max $400 ?
I do only HD/Bluray movies and TV watching, seldom Games or not at all.
iwanrs is offline
post #14 of 31 Old 07-20-2013, 09:46 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
$400 is kinda crazy if your not gaming!
Get a 7790 is fine.
7870 if you want overkill.
Mfusick is offline
post #15 of 31 Old 07-20-2013, 08:25 PM - Thread Starter
iwanrs's Avatar
Quoted: 48 Post(s)
Thanks Mfusick.
Hope that will solve the problem and I get what I want for best picture quality.
7870, nVidia or Radeon, any particular GC you prefer?
iwanrs is offline
post #16 of 31 Old 07-21-2013, 07:20 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
7870 is a Radeon. Radeon does 6000 series, 7000 series, 8000 series etc....
The XX50 is weaker than the xx70 or xx90.
Example:
7750>7770>7790 or 7850>7870.
There is no Nvidia in this conversation biggrin.gif I think Radeon cards are better for HTPC for a variety of reasons, but that's not saying Nvidia can't be used.
7790 with 2GB DDR is what I would say you should get. Save your cash and you won't mind upgrading sooner if you needed it. (You won't wink.gif )
ReneTHX has had lots of posts and testing done with various cards and he's much more an expert than I am but I think he generally says the same thing.
You could PM him and he might chime in for additional specifics.
Mfusick is offline
post #17 of 31 Old 09-16-2013, 11:08 PM - Thread Starter
iwanrs's Avatar
Quoted: 48 Post(s)
I want to buy a dedicated Graphic Card for my HTPC.
I decide to go with AMD ATI Radeon.
My HTPC Casing is Silverstone Grandia HTPC Case GD08B.
The space inside is very limited, the maximum length of PCI-e card can be install is 10 inches long.
The GC must be 9" or shorter in length.
I need help:
What is the highest-end of ATI Radeon GC I can get and can fit into my limitation of PCI-e slot space (9" or shorter) ?
HD7970 ?
THANKS a bunch.
iwanrs is offline
post #18 of 31 Old 09-17-2013, 12:42 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
7790: 8.5"
7850 / 7870: 9.5" (there are a couple of shorter cards, but not recommended because of noise)
7950 / 7970: 10.5"
renethx is offline
post #19 of 31 Old 02-17-2014, 07:24 PM - Thread Starter
iwanrs's Avatar
Quoted: 48 Post(s)
I end up install HD7750. Work well, many step upgraded than the Intell Haswell onboard graphic processor.
Image looks sharp and flicker-free.
Unfortunately after 7 months of enjoyable moments, the problem arise.
Due to its tiny micro HDMI socket and the "heavy" weight of HDMI cable, the connection began to lose. Image appear on and off. I have to use Stick-Wax to keep it firm, but it still not 100% fixed.
I must looking for another Graphic Card with FULL size HDMI socket.
Any recommendation the latest model? AMD Radeon, Card length maximum 9", budget up to $350.
THANKS
iwanrs is offline
post #20 of 31 Old 02-17-2014, 08:54 PM
kaibrok's Avatar
Quoted: 13 Post(s)
did your card come with a DVI to HDMI adapter? Most (if not all) AMD cards output Audio through the DVI connector when using the DVI to HDMI adapter. Before you spend a bunch of money on a new card give it a try!
perpetual98 likes this.
kaibrok is offline
post #21 of 31 Old 02-18-2014, 08:52 PM
boe
boe's Avatar
Quoted: 886 Post(s)
Liked: 412
Not sure how good these are but this is probably what I'd try -If I had no front or back cooling fan, I might attach a fan too it but lower the RPM to a ridiculously low setting.
boe is offline
post #22 of 31 Old 02-18-2014, 09:51 PM - Thread Starter
iwanrs's Avatar
Quoted: 48 Post(s)
I have tried it, no sound came out, may be I use the wrong adapter (no sound connection) ?
iwanrs is offline
post #23 of 31 Old 02-19-2014, 07:13 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Do you ever think of going back to the embedded intel GPU? The output range issue has been resolved by using a registry key posted in another thread. Once the output range matches your TV/Monitor, you should not be able to tell any difference at all with a dedicated vide card.
post #24 of 31 Old 02-19-2014, 07:46 AM - Thread Starter
iwanrs's Avatar
Quoted: 48 Post(s)
Can you give me the thread link?
iwanrs is offline
post #25 of 31 Old 02-19-2014, 08:25 AM
steelman1991's Avatar
Quoted: 211 Post(s)
Liked: 116
steelman1991 is offline
post #26 of 31 Old 02-19-2014, 09:03 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
^ that's the thread.
post #27 of 31 Old 02-19-2014, 09:50 AM
leebo's Avatar
Quoted: 525 Post(s)
Liked: 293
Can anyone explain how to see what your graphics card is putting out (0-255 or 16-235)?
My TV does not appear to have a setting to switch, so I assume it's looking for 16-235.
Sent from my generic not my computer device.
leebo is offline
post #28 of 31 Old 02-19-2014, 11:49 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
That depends on what your graphics card is. Each chipset vendor and even different drivers have different way to check or set (or not able to set). This is a very complex question. Also, applications need to be configured accordingly as well. Not just video card. There is no easy or one size fits all answers.
post #29 of 31 Old 02-19-2014, 02:56 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
You can set everything 16-235 and it should work fairly well if your display won't accept 0-255
Mfusick is offline
post #30 of 31 Old 02-19-2014, 06:50 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Yes both DVI and Display port on Haswell do 0-255. Only HDMI is limited to 16-235.
Mfusick is offline
Reply Home Theater Computers
