Split HTPC into an HTPC and Media Server - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 56 Old 07-29-2013, 04:36 AM
assassin's Avatar
Quoted: 91 Post(s)
Liked: 246
Originally Posted by Sammy2 View Post
Back on the SSD vs HDD discussion.. for me, the jump to an SSD for the OS drive made all the difference in making the HTPC snappy like an appliance device such as a Cable Co STB because the SSD makes the OS basically "embedded" like a STB OS.
Don't fool around here. Two years ago it was questionable on the value of an SSD but now it is a no-brainer.
Agreed. An ssd is a fraction of what they used to cost just a few years ago at this point.
assassin is online now
post #32 of 56 Old 07-29-2013, 08:19 PM - Thread Starter
Wilky13's Avatar
No worries there. I built my HTPC with an 64GB SSD. I liked it so much, I upgraded it to a 128GB SSD and put the 64GB in my laptop. I get angry at work because my computer does not have one! The server OS drive will definitely be a SSD!
I have to return some video tapes....
Wilky13 is offline
post #33 of 56 Old 07-29-2013, 08:22 PM
Jsolo's Avatar
If you're building a htpc from scratch, sure. If you're building it from assorted spare parts, then priorities are a bit different.
Jsolo is offline
post #34 of 56 Old 07-29-2013, 08:30 PM
assassin's Avatar
Quoted: 91 Post(s)
Liked: 246
Of course.
post #35 of 56 Old 07-30-2013, 05:45 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
I could not use a HTPC without an SSD. It's like using dial up internet.
Mfusick is offline
post #36 of 56 Old 08-08-2013, 10:57 AM
mark_anderson_u's Avatar
Quoted: 43 Post(s)
Liked: 42
Don't understand that at all. I don't have an SSD: works great
mark_anderson_u is offline
post #37 of 56 Old 08-08-2013, 01:50 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
You probably said the same thing before you got high speed and you were dialing up. I remember lots of people saying it worked fine and didn't want to spend the extra for high speed. wink.gif
Mfusick is offline
post #38 of 56 Old 08-08-2013, 01:52 PM
Jsolo's Avatar
2400 baud ftw!
Jsolo is offline
post #39 of 56 Old 08-08-2013, 02:32 PM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
Hell, two of my HTPCs don't have any drives. I'm not sure how an SSD would help them either.
EricN is offline
post #40 of 56 Old 08-08-2013, 03:42 PM
ajkrishock's Avatar
Quoted: 80 Post(s)
Liked: 33
If you want to keep the ceton on the HTPC then WHS would be best.
I run my Ceton card in my Windows Home Server and I attach the HD tuners to my two HTPC's via network bridge. I don't think you can do that with extenders substituted for the HTPC's though. If your goal is to continue using the extenders for live TV, you'd probably have to use Windows 7 as your server OS otherwise, the extenders won't connect to it. If you don't require live TV on the extenders, or want to move to a network tuner model like I have, WHS2011 might serve you better.
Of course, how well the network tuner model works is also dependent on who your cable company is. My provider (Verizon) is pretty relaxed with DRM compared to some of the other cable companies. I can record to the server and play back on any of the connected HTPC's (or computers for that matter).
ajkrishock is offline
post #41 of 56 Old 08-08-2013, 03:53 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
Good points. I don't do this personally, I only have a cheapo card that records non encrypted channels. I don't bother recording flagged stuff because I know I would have an issue in future. I tear apart my pc's too often and mess around to worry about DRM. For that reason I don't keep anything that is flagged. I just keep stuff that would always play anywhere and I have no problems biggrin.gif
Mfusick is offline
post #42 of 56 Old 08-09-2013, 02:00 AM - Thread Starter
Wilky13's Avatar
How do you check if anything is DRM tagged? I have Comcast, but have never had a problem watching anything recorded in my HTPC on the HTPC or either extender. And MCEBuddy has never thrown an error transcoding any wtv files to MKV. And I've converted shows on ABC, CBS, NBC, FX, USA, AMC, etc.
Wilky13 is offline
post #43 of 56 Old 08-09-2013, 07:21 AM
pittsoccer33's Avatar
Quoted: 649 Post(s)
Liked: 427
That little icon will show up when you look at your recording details.
In Pittsburgh Retroplex is the only non premium (HBO, Starz, etc) I've ever seen it on.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #44 of 56 Old 08-09-2013, 11:57 AM - Thread Starter
Wilky13's Avatar
Ah ha! Thanks, I don't think I've ever seen that. I have Comcast in central CA, but I will check.
Wilky13 is offline
post #45 of 56 Old 08-12-2013, 01:26 PM - Thread Starter
Wilky13's Avatar
Okay just when I thought I would put the Haswell in the server and run Win7, I stumbled across SVP! In order to run SVP you need a strong CPU in your HTPC. So my new plan:
Buy Haswell i7-4770, MoBo and $150ish GPU for HTPC.
Move i3-2100 and MoBo to the server.
This should allow the HTPC to run SVP and my extenders will still be "attached" to the HTPC and not the server.
So only question now is WHS2011 or Win7 64-bit for the server OS?
Wilky13 is offline
post #46 of 56 Old 08-12-2013, 02:19 PM
Quoted: 649 Post(s)
Liked: 427
what tv model do you have where you plan to run svp?
post #47 of 56 Old 08-12-2013, 03:35 PM - Thread Starter
Wilky13's Avatar
Philips 52PFL7403D/F7. It is about 4-5 years old, I believe it is 120Hz.
Wilky13 is offline
post #48 of 56 Old 08-12-2013, 03:39 PM - Thread Starter
Wilky13's Avatar
I went through all of my recordings today. None of them have the "Copy Protected" symbol. Yeah!
Wilky13 is offline
post #49 of 56 Old 08-12-2013, 04:00 PM
Quoted: 649 Post(s)
Liked: 427
Heres my opinion on SVP. It really seems to be geared towards 60hz tvs. The ones that cant do frame interpolation. Which is cool because it fills a nice niche and since youre analyzing the video stream at the source you should theoretically get more accurate frames.
However your 120hz tv can do this too. If SVP could send your tv a 120hz signal that would probably look awesome. Unfortunately tvs can only accept up to 60hz signals. When the tv frame interpolation is turned on it syncs the frame rate of the video to 120hz. So a 24fps movie would have 96 frames created every second. SVP would only be able to create 36.
It would be cool to compare them side to side.
post #50 of 56 Old 08-14-2013, 06:02 AM
Quoted: 43 Post(s)
Liked: 42
Nope.I have an SSD in both my laptops and they bot really fast and programs launch faster. My HTPC I my DVR and I on 24/7 , what's gonna get faster?
post #51 of 56 Old 12-19-2013, 11:43 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
What did you end up going with ?
Mfusick is offline
post #52 of 56 Old 12-19-2013, 12:13 PM
Spec4's Avatar
Liked: 24
This is a very informative thread, I can't believe I missed it....subbed.
Spec4 is offline
post #53 of 56 Old 12-19-2013, 02:25 PM
Dark_Slayer's Avatar
Quoted: 667 Post(s)
Liked: 436
It would be cool to compare side by side. Buying a more expensive computer to do what a nicer display is already doing doesn't always make sense (especially if you know you'll soon be in the market for a new display). I'd like to see a good side by side, particularly on a high-end frame-interpolation set with it's interpolation features turned on compared to SVP output to the same display with the display's interpolating turned off
Dark_Slayer is offline
post #54 of 56 Old 12-20-2013, 03:47 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
I would be interested in the results. I just down own a display that I can compare with.
Mfusick is offline
post #55 of 56 Old 12-21-2013, 04:02 PM - Thread Starter
Wilky13's Avatar
Project postponed....
Sick family pet is taking up all my $
Wilky13 is offline
post #56 of 56 Old 12-21-2013, 05:30 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
Oh.. sorry to hear this. I know what you are going through and it's never easy. Unless someone has a family pet and has been through it, it's hard to understand- Prayers and best wishes.
Mfusick is offline
Reply Home Theater Computers
