Assassin Gigabyte Brix Build - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 40 Old 08-23-2013, 06:19 PM
TeflonDog's Avatar
Is there ANY word on when the AMD version is going to be available?
TeflonDog is offline
post #32 of 40 Old 09-12-2013, 10:45 AM
TornadoTJ's Avatar
Quoted: 1619 Post(s)
Liked: 510
Is there anything wrong with using one of the cheaper Celeron models for HTPC duties?
Gigabyte GB-XM14-1037 is $199.
Intel BOXDCCP847DYE is $165 (I know, not a Brix, but a contender)
Just looking for a simple client to stream from my server. Windows 7.
TornadoTJ is offline
post #33 of 40 Old 09-12-2013, 10:49 AM - Thread Starter
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
Not sure about a Win7 machine but plenty of people using the celeron version and openelec for XBMC with 2 gb ram and a usb flash drive for the OS drive.
assassin is offline
post #34 of 40 Old 09-12-2013, 10:56 AM
TornadoTJ's Avatar
Liked: 510
Has to be Windows 7. My FiOS TV is all tuned by an HDHR Prime. Wife insists on having TV available. Sorry I did not specify this in the original post.
That's a cool idea, booting off USB for a streamer.
post #35 of 40 Old 09-12-2013, 11:19 AM - Thread Starter
assassin's Avatar
Quoted: 79 Post(s)
Liked: 242
I haven't tested the Celeron specifically with Windows and WMC. Maybe someone else has.
Maybe talk to Stardog: http://www.avsforum.com/t/1460922/assassins-intel-nuc-review/30#post_23033374
assassin is offline
post #36 of 40 Old 09-12-2013, 12:30 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
When I first got a Celeron 847 motherboard (Biostar version) I put together a PC with 4GB RAM, 128GB SSD and Windows 7. I hooked it up to the bedroom TV where there is a G620 system so my observations compare to that. This PC was connected to my GigE network via Cat 5e.
It ran Windows pretty well though the interactions in Windows felt a bit slow to me. Unzip is very slow. Starting programs seemed slow. WMC ran fine, moving through menus, etc. Live TV looked fine as well. I didn't notice any slowness in channel changing or the guide (HDHR3-CC tuner on the network). On the video playback side it played anything and everything -- all the high-bit rate samples I could find -- and looked very nice on my 50" plasma. Netflix HD played through the WMC plugin (Silverlight) which was remarkable since this was the first SoC to do so. CPU utilization was 85-90% and it did get hot but nowhere near the top end of 100C. I used the movie Firefly as the test and watched the whole thing. There was not one glitch. XBMC's internal player (Eden or Frodo) didn't work at all, either with or without DXVA. Launching an external player solved that issue.
StardogChampion is offline
post #37 of 40 Old 09-12-2013, 01:55 PM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
Has anyone been able to install Windows 7 and various apps on a bootable USB flash drive and run them from there? A 64GB USB flash drive should be large enough for the task. I'm curious as to whether the Windows installation disk will recognize the drive as an available drive for installing the OS.
captain_video is offline
post #38 of 40 Old 10-24-2013, 07:59 PM
Bryman31's Avatar
i just joined the forum here mainly because of a google search on this exact same setup.......looks like its been several weeks, hows this setup going?
ive got the exact same box......ive got a 3td WD Red drive....and ive got about 200 movies on it so far..........i have yet to get the computer mainly because just this week the new BRIX model hit newegg and the new NUC models should be following soon after...... figure ill wait a few weeks.........
Bryman31 is offline
post #39 of 40 Old 11-05-2013, 07:40 PM
Bryman31's Avatar
bump for update?
Bryman31 is offline
post #40 of 40 Old 01-09-2014, 08:02 AM
GuyLR's Avatar
Finally Newegg is showing an AMD based BRIX GB-BXA8-5545 with a 19W Richland A8-5545M for pre-order. It should be just a little more powerful than the low end Haswell equipped GB-BXi3-4010. It's also $40 cheaper and will be released at the end of January. Still no Kabini versions yet.
http://www.newegg.com/Product/Product.aspx?Item=N82E16856164009
GuyLR is offline
Reply Home Theater Computers
