purchasing Switches - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #1 of 67 Old 08-12-2013, 04:00 PM - Thread Starter
rinku2012's Avatar
Quoted: 24 Post(s)
Hello,
i am planning to buy a 1 Gbps Switch to my HTPC where i will be connecting my my router to Switch and HTPC machine, Vonage phone, PS3, Smart TV to Switch.
I have a question before purchasing switch.
if i planned to buy the below switch it shows as Eight 10/100/1000 Mbps Gigabit ports and 16 Gbps switching fabric
http://www.newegg.com/Product/Product.aspx?Item=N82E16833127508
does this mean, it can transfer 16 GB Speed across my internal network ?
say for example if i connect my HTPC ( which has 1 Gbps network card) and 3 laptops ( 1 Gbps Network Card) to switch, if i copy the files between all the 4 systems will i get 4 Gbps Speed without any latency issues ?
can some one please suggest me good 1 Gbps Switches so that i can purchase them
rinku2012 is offline
post #2 of 67 Old 08-12-2013, 04:27 PM
erickotz's Avatar
Liked: 30
Originally Posted by rinku2012 View Post
Hello,
It is 16Gb, not 16GB, but yes - an 8 port gigabit switch with a 16Gbps fabric will be able to fully saturate 8 1gbps ports in both directions
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #3 of 67 Old 08-12-2013, 04:42 PM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
At that price point, I'd go with the Trendnet TEG-S82g. I've had D-Links with loose power sockets, which coupled with the socket being on the "wrong" side for a desktop switch, has caused them to become unplugged.
EricN is offline
post #4 of 67 Old 08-12-2013, 05:18 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
I like DLink switches and have been using them since ~2006 (8 port variety).
I have around 6 8 port switches between various rooms.
When I do it all over again (planning on moving into house soon) I will likely consolidate to 16-24 port switches, but need to find quiet ones.
The DLink switches like shown are nice because you can stack 2-3 on top of each other, unlike some of the "pretty" consumer oriented versions which have oddly shaped top covers which do not stack at all!
qz3fwd is offline
post #5 of 67 Old 08-12-2013, 07:40 PM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
I'm not a fan of DLink gear as I've had a number of failures. My network at home currently uses Dell and Netgear enterprise switches, but I'm downsizing as don't need all the ports (and they suck power and the Dell is noisy) to HP 1410-8G and 1810-8G. You'd only need the unmanaged 1410. It's a bit more money, but I've never had an HP switch give problems.
A9X-308 is offline
post #6 of 67 Old 08-12-2013, 08:01 PM
gregzoll's Avatar
Liked: 33
I am now going with Trendnet Switches on my LAN. I still use a Netgear GS108 for my two U-Verse Set Top boxes, and the DVR, since I had to get a POE switch, due to adding in a POE IP Camera soon, to cover a front corner of my house. I like the Trendnet gear better, due to price point is low enough not to break the bank, but the gear is good that it is not junk.
DLink consumer grade I would not touch, but their higher end SoHo stuff is worthwhile, but it really comes down to how deep your pockets are, and how much are you willing to invest in your LAN infrastructure all together.
gregzoll is offline
post #7 of 67 Old 08-12-2013, 08:52 PM
elec999's Avatar
Stay away from dlink. Look at the hp procurve. They can be affordable and good.
ilovejedd likes this.
elec999 is offline
post #8 of 67 Old 08-13-2013, 05:40 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I have several Trendnet switches, including a wireless bridge. IMHO, they make a quality product at decent price.
Do you have Uverse for internet? Does their gateway modem/router still only have 10/100 LAN ports?
Sammy2 is offline
post #9 of 67 Old 08-13-2013, 07:07 AM
gregzoll's Avatar
Liked: 33
Only the ADSL2+ Gateway that they are now issuing from Pace has the Wireless-N wifi, and 10/100/1000 ports. Personally I would still use third party hardware, not the RG, since you have more flexibility, and really with the speed only being 24meg max down, there is no need for them to issue gateways with anything more at 10/100 or Wireless-g, which keeps the costs down for not only leasing the equipment by the consumer, but when they purchase it from Pace or Motorola.
I think that within the next five years, when h.265 and 4k UltraHD starts rolling out, probably will see ATT offering equipment upgrades. They tried sending me a 3801, due to a bad firmware rollout a couple of months ago. did some research and found out that for the overall spec's, the 3800 is still better than the 3801.
gregzoll is offline
post #10 of 67 Old 08-13-2013, 07:08 AM
gregzoll's Avatar
Liked: 33
The HP Procurve is a little overkill for the every day common LAN, unless you are looking at doing some special LAN setup, or setting up a lab on your LAN.
gregzoll is offline
post #11 of 67 Old 08-13-2013, 08:09 AM
robnix's Avatar
Quoted: 661 Post(s)
Liked: 494
Another brand to look at is TP-Link. I bought their 24 port Gb managed switch not long back for less than $200.00. Zero issues so far, transfers are at line speed to and from my file server. LACP is available if you need it.
Looky here!
robnix is online now
post #12 of 67 Old 08-13-2013, 08:37 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
+1 for TP-Link. I've used the 24 and 16 port Gigabit switches and they both work very well. Mine were both under $100. They often go on sale. I've done well with Trendnet too.
StardogChampion is offline
post #13 of 67 Old 08-13-2013, 08:56 AM
jkleslie's Avatar
I often hit eBay for used Dell PowerConnect switches. You can often find used ones in very good condition for less than a new unmanage SOHO switch. I have a 5324 in my basement that works perfectly.
You're not limited to Dell, of course. Companies dump all brands on eBay all the time, so you can find just about anything.
jkleslie is offline
post #14 of 67 Old 08-13-2013, 08:59 AM
gazebo's Avatar
Quoted: 14 Post(s)
I have 4 Netgear GS108's for home and office uses. Two failed due to leaky/bulging capacitors. I had to replace all 5 capacitors (two 1000uF and three 330uF, all are electrolytic) over time. I fully expect the other two GS108's to fail over time as some capacitors already show signs of bulging. They are all 2008-2008 vintage models.
I hope Netgear addressed the capacitor problem in newer models. Even though they carry a lifetime warranty you have to pay for shipping to send the bad unit to them. So figure this into your total cost of ownership if you are considering purchasing a Netgear.
gazebo is offline
post #15 of 67 Old 08-13-2013, 10:14 AM
Ken.F's Avatar
Quoted: 1471 Post(s)
Liked: 1255
Monoprice 8 Port 10/100/1000 Mbps Desktop Gigabit Ethernet Switch
I have 2 PCs, 3 Media Center extenders, 2 Roku streamers, a network printer, and a HDHR Prime running on two of those switches without any issues.
Aryn Ravenlocke likes this.
Ken.F is offline
post #16 of 67 Old 08-13-2013, 10:28 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
I second staying away from anything made by D-link. However, I disagree that a home user needs to spend the kind of money on ProCurve.
TrenNet 8 port green gigabit switch will serve the same purpose at half the price, and half the electric use.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #17 of 67 Old 08-13-2013, 10:30 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
If you are stacking them on top of each other, then you need a higher port count switch because your connection between the devices on different switches will be limited to the bandwidth of the single wire that connects the switches together.
If you need 3x 8-port ones, just get a 24 port switch. It will be cheaper, and you will gain 2 additional ports since you won't needto uplink 3 switches together.
post #18 of 67 Old 08-14-2013, 07:14 AM
Mac25's Avatar
Quoted: 14 Post(s)
could someone recommend a 12 port 10/100/1000 switch for home use, somewhat reliable and streaming capable for Netflix or amazon for $100 or below, not streaming bd rip's at the moment but may in the future.
2 pc's and 1 server
2 roku xs
1 print
hdtv
bd player
av receiver
Mac25 is offline
post #19 of 67 Old 08-14-2013, 07:59 AM
Quoted: 93 Post(s)
Liked: 160
2 pc's and 1 server
2 roku xs
1 print
hdtv
bd player
av receiver
I have this switch and I am very happy with it: http://www.amazon.com/TP-LINK-TL-SG1016-1000Mbps-Rackmountable-Capacity/dp/B002HAJQGA ($70 @ Amazon)
I have several PCs, a couple of network tuners, a printer/scanner and a server hanging off it.
These often go on sale so keep an eye on Slickdeals.net
[Edit]Actually, this is the one I have: http://www.amazon.com/TP-LINK-TL-SG1016D-1000Mbps-Rackmountable-Capacity/dp/B004ELA0SS ($85 @ Amazon). The first one above doesn't have the "D" in model number. I don't what the difference is.
robnix likes this.
post #20 of 67 Old 08-14-2013, 10:07 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
2 pc's and 1 server
2 roku xs
1 print
hdtv
bd player
av receiver
I can't say I ever seen a 12 port one, but 16 port ones are pretty common. Trendnet is what we use.
post #21 of 67 Old 08-14-2013, 10:32 AM
robnix's Avatar
Quoted: 661 Post(s)
Liked: 494
For a little more the 24 port version is available as well.
Looky here!
post #22 of 67 Old 08-14-2013, 11:15 AM
A9X-308's Avatar
Liked: 951
2 pc's and 1 server
2 roku xs
1 print
hdtv
bd player
av receiver
HP 1410-16G
I had a quick look on Amazon and it was $144, but as I can get them in Australia for <$100, you should be able to as well. Comes with a lifetime warranty too.
A9X-308 is offline
post #23 of 67 Old 08-14-2013, 06:52 PM
jlv
jlv's Avatar
I have several Trendnet's ... a pair of TEG-S80g (bought onsale at $20 each) as well as a TEG-S50g and a gigabit wireless router. I see no reason to pay more than $30 for an 8 port unmanaged gigabit switch! (Amazon has the TEG-S80g for $30 with prime right now)
jlv is offline
post #24 of 67 Old 08-14-2013, 09:49 PM
Mac25's Avatar
Quoted: 14 Post(s)
2 pc's and 1 server
2 roku xs
1 print
hdtv
bd player
av receiver
and a hd homerun = 10 ports, plus 2 more I could use on the p8cws mobo's would = 12 ports total.
the hp procruve is what ive seen a lot of ref to and spoke highly of, but haven't seen at 100 or less, I shopped around this eve and cant find such a deal, the 8 port trend net is what I am using now and works fine, with incoming hardware and expandability needed shortly is why I asked and was looking for more ports, 16 ports would be good for now but 24 @ justified cost is still within reach, gona have to mount mid house and would like to avoid a noisy unit if possible, maybe watch for a deal on a good 16/24 port switch I could make use of for years to come.
Mac25 is offline
post #25 of 67 Old 08-15-2013, 06:31 AM
cdru's Avatar
Quoted: 20 Post(s)
While technically important, saying it has a 16 gigabit switching fabric is marketing fluff to make the switch sound more impressive then what it really is. I can't remember the last time that I saw a residential, soho, or even medium sized switch that didn't support a switching fabric equal to the maximum speed of all ports in both directions.
cdru is offline
post #26 of 67 Old 08-15-2013, 07:19 AM
gregzoll's Avatar
Liked: 33
You can get the Trendnet TEG-S24Dg for $94, or TEG-S24 for $130
http://www.amazon.com/s/ref=nb_sb_ss_i_0_16?url=search-alias%3Daps&field-keywords=trendnet%2024%20port%20gigabit%20switch&sprefix=trendnet+24+port%2Caps%2C190&rh=i%3Aaps%2Ck%3Atrendnet%2024%20port%20gigabit%20switch
The TEG-240WS will set you back around $200 http://www.amazon.com/TRENDnet-Auto-Negotiation-Auto-MDIX-Mini-GBIC-TEG-240WS/dp/B0001LS36Q/ref=sr_1_7?s=pc&srs=2530657011&ie=UTF8&qid=1376572594&sr=1-7&keywords=trendnet+24+port+gigabit+switch
Right now is the time to start grabbing up hardware, before prices go up, just as RAM has already inflated, starting about four months ago.
gregzoll is offline
post #27 of 67 Old 08-15-2013, 07:39 AM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
I picked up a used Dell PowerConnect 24-port gigabit switch on ebay for about $100 or so. There's a ton of quality used ethernet switches on ebay for a fraction of what you'd pay for new equipment.
StardogChampion likes this.
captain_video is offline
post #28 of 67 Old 08-15-2013, 10:26 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
If one waits for newegg sales, one can easily grab TEG-S24Dg for $60 or so. Very cost effective switch.
post #29 of 67 Old 08-15-2013, 10:27 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Do you use the management features of it?
post #30 of 67 Old 08-15-2013, 11:46 AM
Quoted: 510 Post(s)
Liked: 336
LOL. No, I'd be afraid to screw it up. I have the manual but have't taken the time to understand how to use it as a managed switch. It seems to work perfectly fine in an unmanaged state so, if it ain't broke...
Reply Home Theater Computers
