Any guides to the physical building of a PC? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 50 Old 08-15-2013, 06:13 PM - Thread Starter
Ian_Currie's Avatar
Quoted: 13 Post(s)
I've built a PC years ago following some step by step guide which I no longer have (plus, it would be out of date).
I've just received all the parts to build my HTPC and am going to give it a go, but would love to find some great step-by-step guide to building it.
I thought Assassin had one on his site, but if he does, I can't find it.
Anyone know of one?
Ian_Currie is offline
post #2 of 50 Old 08-15-2013, 06:53 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
Dropkick Murphy is offline
post #3 of 50 Old 08-15-2013, 06:57 PM
Dark_Slayer's Avatar
Quoted: 662 Post(s)
Liked: 435
Don't be too afraid to just roll up the sleeves on computer building. There are some good to know tweaks (12V fan mod), but the basics aren't easy to put into a guide. Some HTPC cases almost require you to mount your hdds and run the sata connections to your motherboard before seating your CPU (unless you have tiny hands)
Basics
  • Install motherboard standoffs to your case
  • mount drives (3.5 and 5.25) - also connect sata cables to motherboard
  • seat cpu and cpu cooler
  • install ram (snaps in)
  • install Graphics card (if applicable)
  • connect case power/reset buttons (and lights if you wish) - You usually have to open the mobo manual to determine where they should connect
  • connect case ports, USB, SD, firewire, etc (if applicable and/or you want to)
I usually do power last
  • Connect 24 pin to motherboard
  • Connect 8 pin to motherboard near cpu
  • Connect sata power cables to HDDs, SSDs, and ODD
  • Connect PCI power cable to graphics card (if applicable)
  • Connect molex cables to case fans
Some case fans power off the motherboard, it typically doesn't matter where. The cpu cooler fan typically should go to the 3/4 pin connector near CPU. 4 pin motherboard connections offer speed control, but if your motherboard only has 3pin connections it doesn't matter whether you end up powering those from the motherboard or PSU (since in that case neither offer variable fan speed control)
Dark_Slayer is online now
post #4 of 50 Old 08-15-2013, 07:02 PM - Thread Starter
Ian_Currie's Avatar
Quoted: 13 Post(s)
Originally Posted by Dropkick Murphy View Post
That guide is a buying guide by the looks of it; the second page has Part II: Assembly but the posts are empty (reserved for future editing).
post #5 of 50 Old 08-15-2013, 07:03 PM - Thread Starter
Ian_Currie's Avatar
Quoted: 13 Post(s)
Basics
Thank you very much. I'm giving it a go now.
post #6 of 50 Old 08-15-2013, 07:29 PM
LastButNotLeast's Avatar
Quoted: 1503 Post(s)
Liked: 1104
Here's one Assassin mentions:
http://www.tomshardware.com/forum/274745-31-step-step-guide-building
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
post #7 of 50 Old 08-15-2013, 07:53 PM
assassin's Avatar
Quoted: 83 Post(s)
Liked: 246
There are a ton of great guides and youtube videos out there on how to build a PC.
assassin is offline
post #8 of 50 Old 08-15-2013, 08:04 PM
Mrkazador's Avatar
Quoted: 255 Post(s)
Liked: 382
If you built a PC a few years ago then it won't be much different today.
Mrkazador is offline
post #9 of 50 Old 08-15-2013, 08:15 PM
Mac25's Avatar
Quoted: 14 Post(s)
most if not all motherboards have assembly instructions included in the box, also the bios setup pages in the manual, if all parts were correctly chosen and are completely compatible it makes it super easy, 1 thing to watch out for is to set the chosen hard drive to AHCI before loading windows to the drive, only use 1 stick of ram and only 1 hard drive connected during windows setup otherwise windows will write files to the 2 hard drive, check the motherboard bios version first against the processor you have chosen to insure it is supported can eliminate many startup and loading issues as well.
Mac25 is offline
post #10 of 50 Old 08-16-2013, 08:08 AM - Thread Starter
Ian_Currie's Avatar
Quoted: 13 Post(s)
Thanks for the help, but I'm confused. I only have one hard drive (ssd) but I do have 2 sticks of RAM. Why only use one???
post #11 of 50 Old 08-16-2013, 08:59 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
2 memory sticks is OK. But you'd better attach only one disk drive to avoid confusion, otherwise you may install OS not in SSD but in HDD by accident (although you can avoid this easily by looking at the disk size).
renethx is offline
post #12 of 50 Old 08-16-2013, 10:29 AM - Thread Starter
Ian_Currie's Avatar
Quoted: 13 Post(s)
So I finally turned it on and it doesn't work. :-(
I don't get any video and after a while the unit powers down and starts up again on its own, repeating this cycle.
I've tried both analog and digital cables to two different monitors just to rule out something simple.
Since I'm using on board graphics, does this point to the motherboard being bad - or could it be something else like the CPU?
Any advice?
Thanks in advance.
post #13 of 50 Old 08-16-2013, 10:33 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
Make sure:
1. The memory is installed
2. The 4-pin power to the CPU is plugged in
Polemides likes this.
StardogChampion is offline
post #14 of 50 Old 08-16-2013, 10:36 AM
Polemides's Avatar
Check the power connections to your mobo. Check the power to your discrete graphics card if you have one.
Check the seating of your RAM sticks, try to swap those out if you have any others lying around.
Polemides is offline
post #15 of 50 Old 08-16-2013, 10:46 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
OK, in this case it's worth trying a single stick. smile.gif Remove all components from the mb and clear CMOS (check your mb manual how to clear CMOS)
1. Attach CPU carefully to the mb socket.
2. Attach the CPU cooler. You'd better use the stock one until everything is running fine. (Wipe thermal compound on the CPU heat spreader with tissue paper and attach the stock cooler; the stock cooler has already thermal compound preapplied .) Don't forget to connect the fan to CPU fan connector of the mb
3. Attach one stick of memory (to any slot). Make sure it be seated firmly.
4. Attach the mb to the case.
5. Attach the main power connector and the CPU power connector.
6. Connect display, mouse and keyboard.
7. Power on. See what happens
renethx is offline
post #16 of 50 Old 08-16-2013, 10:48 AM
politby's Avatar
Quoted: 76 Post(s)
Liked: 77
That symptom is pretty typical of a memory problem. It could mean bad memory or the RAM might not be compatible with the motherboard. Have you tried with just one stick of RAM? Try all RAM slots in turn.
A system I built last week refused to POST with RAM in either of the first two slots. The other two slots were fine. I had fumbled and dropped the CPU onto the open socket when installing it. That was enough to damage a couple of the pins in the socket and break the connection between the on-die memory controller and the first two RAM sockets. Fortunately I could live with just two functioning RAM slots...
Finally, are you sure your motherboard supports your processor? E.g. an 1155 board released before Ivy Bridge may need to have its bios updated to support IB CPUs.
politby is offline
post #17 of 50 Old 08-16-2013, 10:55 AM - Thread Starter
Ian_Currie's Avatar
Quoted: 13 Post(s)
Originally Posted by StardogChampion View Post
Make sure:
THANK YOU THANK YOU THANK YOU!!!!
4-pin power looked to be in but I guess it wasn't in all the way. Man I am relieved!
post #18 of 50 Old 08-16-2013, 11:19 AM
Quoted: 93 Post(s)
Liked: 160
You're welcome. I probably build half-a-dozen systems per week and I still sometimes forget to do one of the two and get to enjoy that momentary sinking feeling before I realize I've forgotten something.
post #19 of 50 Old 08-16-2013, 11:42 AM - Thread Starter
Ian_Currie's Avatar
Quoted: 13 Post(s)
OK, I have another issue (or possibly 2..):
Only 1 stick of RAM is being recognized (in slot B2). It's not recognized in A2 or A1, but it *IS* recognized in B1 (the latter being not desirable as it results in single channel memory mode).
I though the ram was bad until I tried B1... thoughts?
Also my CPU temperature is around 65 degrees - but my case is open. Should I be concerned?
Thanks again in advance.
post #20 of 50 Old 08-16-2013, 11:47 AM
DanPackMan's Avatar
Quoted: 236 Post(s)
Liked: 386
My guess is bad or incompatible RAM. I had similar symptoms/issues with a set I bought recently, one would work only in one slot, and even then not every time, messed around with timing settings in the BIOS, no luck ....tried another brand and everything was fine.
DanPackMan is offline
post #21 of 50 Old 08-16-2013, 11:57 AM
Mac25's Avatar
Quoted: 14 Post(s)
set optimized defaults in bios, then restart, memory showing up now, in the other slots as well ?
if not what bios version is listed at POST, did you check the mobo bios support page to make sure your processor IS supported by the current bios version.
post links to
mobo
memory
cpu
Mac25 is offline
post #22 of 50 Old 08-16-2013, 12:02 PM - Thread Starter
Ian_Currie's Avatar
Quoted: 13 Post(s)
post links to
mobo
memory
cpu
Motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157373
Memory:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231587
CPU:
http://www.amazon.com/gp/product/B00CO8TBQ0/ref=oh_details_o03_s00_i01?ie=UTF8&psc=1
I flashed the bios (was 1.20) to 1.60.
post #23 of 50 Old 08-16-2013, 12:19 PM
Mac25's Avatar
Quoted: 14 Post(s)
G.SKILL F3-2400C10D-8GTX is not on the memory support list here http://www.asrock.com/mb/Intel/Z87M%20Extreme4/?cat=Memory, also it is OC Memory which can be difficult to get a sys started and windows loaded with.
from egg of you board: " Memory Standard DDR3 2800+(OC)/2400(OC)/2133(OC)/1866(OC)/1600/1333/1066 ", so all 1866 memory and above/higher is OC memory spec, got any Kingston value ram in 1600/1333/1066 ? or any non oc ram in slower speeds to get the system loaded with and set OC latter ?, cause memory is very likely your problem atm.
you proc is supported since mobo release.
Mac25 is offline
post #24 of 50 Old 08-16-2013, 12:25 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Make sure to select "XMP" profile in BIOS setup > OC Tweaker and select memory speed DDR3-1600. Save (press F10) and shutdown. Add two modules and see if it works. If worked, select DDR3-2400 in BIOS, save and restart and see if it works.
DDR3-1600 should work with SPD timings. Higher clocks may be difficult without XMP profile.
renethx is offline
post #25 of 50 Old 08-16-2013, 12:38 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2686
This.
If you have done it before you should be ok. You can ask here with specific questions.
I find using a mobile phone to post a picture is pretty easy on AVS mobile
Mfusick is offline
post #26 of 50 Old 08-16-2013, 12:52 PM - Thread Starter
Ian_Currie's Avatar
Quoted: 13 Post(s)
There are two XMP profiles, both set to 2400. As to which it was using, it was set to AUTO. I can change it to use a specific profile but I don't see any way to change the contents of the profile.
That said, it reports that the memory speed *IS* 1600...
post #27 of 50 Old 08-16-2013, 12:55 PM - Thread Starter
Ian_Currie's Avatar
Quoted: 13 Post(s)
I guess I can overnight some from Amazon.
So nobody thinks that the A channel on the motherboard may be bad? Both sticks load fine in channel B but neither of them work in channel A (I've switched around and re-seated many times).
post #28 of 50 Old 08-16-2013, 01:16 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Select "XMP 1.3 Profile 1". Load XMP Settings: "Auto" is a wrong choice. Then select DRAM Frequency: "DDR3-1600". Don't change any other setting. "Profile" is a set of timings determined by the memory manufacturer for each clock (1866, 2133, 2400) that guarantees the memory works at 1866MHz, 2133MHz, 2400MHz respectively.
Your mb could be defective. But unless you have the same problem with another memory module, you can't say so.
renethx is offline
post #29 of 50 Old 08-16-2013, 01:19 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2686
Asrock boards are supposed to use channel b for only 2 sticks.
Use slots 2 and 4 for running 8GB with 2x4GB sticks. This is how you do it. It is not recommended to use slot A or slots #1 and #3 for dual channel with only 2 sticks. The only time you should use slots 1 and 3 is if you have 4 sticks of memory installed.
Hope this helps.
PS: I believe this is because there is a shorter distance from the contacts that way.
Mfusick is offline
post #30 of 50 Old 08-16-2013, 01:24 PM - Thread Starter
Ian_Currie's Avatar
Quoted: 13 Post(s)
Yeah, that's what it's set to now and problem persists.
I ordered ram and will try tomorrow.
In the meantime, can I go ahead and install Windows (either using the one 4GB stick or both in single channel mode) so that I can continue to make progress? Even if I have to replace the motherboard it won't invalidate my Windows install, will it?
Reply Home Theater Computers
