Bluray disc or ripped which is better? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 08-16-2013, 10:35 AM - Thread Starter
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
Is there any dif in sound or video quality between watching a Bluray movie straight from the disc or watching one that is ripped to the HDD? I am talking about a lossless rip. I am thinking that a hdd might give better performance over a Bluray player. What are your thoughts?
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #2 of 16 Old 08-16-2013, 10:39 AM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
There wouldn't be any difference. It's the same data going through the PC's GPU.
ellisr63, Osirus23 and Polemides like this.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #3 of 16 Old 08-16-2013, 11:10 AM - Thread Starter
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
What I am thinking is the stability of the drive speed.... sorta like the old days of turntables. I was thinking maybe a HDD would be more consistent in transferring the data.
ellisr63 is offline
post #4 of 16 Old 08-16-2013, 11:17 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
In a system with the parts all working correctly, the I/O speed necessary to play a Blu-ray will be achieved by either and there will be no difference in quality since it's digital data. It can either read it or it cannot.
Likely, since both can read faster than the playback speed, the software will even read ahead and buffer in memory.
ellisr63 likes this.
StardogChampion is offline
post #5 of 16 Old 08-16-2013, 03:13 PM
gerall's Avatar
Quoted: 50 Post(s)
There are many in the audiophile community who feel that the sound quality of a ripped cd sounds better than the actual cd itself - more like the master tape. I have found this to be true - the ripped cd played from the hdd sounds better - I have done a/b comparisons. You would think the same would apply to at least the audio from a dvd or blu-ray. I will compare and report back.
gerall is offline
post #6 of 16 Old 08-16-2013, 03:24 PM
Quoted: 93 Post(s)
Liked: 160
I could believe that if somehow the optical drive were somehow causing electronic interference on the analog side while the HDD doesn't, assuming the DAC is happening in the PC. Otherwise, the same 1s and 0s should produce the same analog output when using the same DAC.
With a Blu-ray, the DAC is likely to happen outside the PC in the audio receiver, at least in the case of HD audio bitstreaming. I would find it very difficult to believe that digital data, regardless of source, would sound different in that scenario where the DAC is isolated from the source like that.
post #7 of 16 Old 08-16-2013, 03:30 PM
newirishman's Avatar
Liked: 31
This is - to use a simple phrase - utter nonsense as it technically makes no sense what so ever.
I recommend educating yourself on how digital is different from analog and therefore the physical storage media is completely irrelevant.
Simply put, a word document doesn't look "better" or has more sophisticated content depending if you read it from a hard disc, USB stick, or a CD.
newirishman is offline
post #8 of 16 Old 08-16-2013, 03:34 PM
JackDiesel14's Avatar
Quoted: 12 Post(s)
Liked: 31
So you're telling me in college I didn't have to turn in all my papers on BluRay discs?
JackDiesel14 is offline
post #9 of 16 Old 08-16-2013, 03:41 PM
Liked: 31
Only if you wrote them using laTex. Makes a huge difference to the compilation process. Much smoother.
post #10 of 16 Old 08-16-2013, 03:55 PM
jcruse's Avatar
Liked: 27
Audiophiles are notoriously "suggestable".
For example, believing that high $$ power cords improve the sound of amplifiers (when those amps have huge toroidal transformers and capacitors inside that supply the amp with all the reserve power, and the power cord just "tops it off"), and the fact that the house is powered by 12 gauge romex wire, but the last 12-36 inches of power cable "really makes a difference"?
You say you have done a/b comparisons...have you done BLIND a/b comparisons? (where you didn't know which method was playing)
jcruse is offline
post #11 of 16 Old 08-16-2013, 05:11 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
I better mark this thread...I have a feeling it's going to get really ugly in here smile.gif
P.S. I don't care either way, I rip my blu-rays to the server for the convenience of not having to get up and find one when I want to watch it. If it looked or sounded a little bit better one way or the other, that wouldn't amount to a "hill of beans" to me.
Dropkick Murphy is offline
post #12 of 16 Old 08-16-2013, 05:32 PM
Somewhatlost's Avatar
Quoted: 20 Post(s)
Liked: 25
actually its much simpler than that...
Audio CD's don't inherently use any real error correction, the audio CD format came along well before computer cd-roms came along... it is quite possible for audio played from a CD to have up to a 10% BER and still be 'in spec'.
now say you rip that audio CD with dbpoweramp/EAC/or the like, they will rip and rerip until they get the exact audio off the CD and look up the checksum online just to triple check they got the correct bits off the cd...
once the file is ripped, computers tend to treat their bits with a bit more respect than your average CD player... so you will consistently get 0% BER.
so it is possible that ripped music could be 'more perfect' than that from CD... I have no clue if you could actually hear the difference or not, I would guess not since when they originally came out with the Audio CD spec they felt up to 10% BER was perfectly acceptable, but as far as CD's go (and this only applies to Audio CD's) there could be a difference.
NOTE: As one wise professional something once stated, I am ignorant & childish, with a mindset comparable to 9/11 troofers and wackjob conspiracy theorists. so don't take anything I say as advice...
Somewhatlost is offline
post #13 of 16 Old 08-16-2013, 05:58 PM
JL-F1's Avatar
Jitter
JL-F1 is offline
post #14 of 16 Old 08-18-2013, 02:15 PM
aufVidyZen's Avatar
Quoted: 34 Post(s)
Which looks better on your system? There are differences between the playback codecs, the physical interfaces (jitter), and what's actually doing the "final"  decoding.
At one point in time you could get some DVD players modified to deliver content over SDI (serial digital interface) to an SDI capable video processor. That combination was not snake oil. It was <expletive deleted> amazing.
At this point in time, I would put my money on streaming rips. The HDMI interface to your display device is what it is. You can do a lot more in S/W than H/W to tweak it.
aufVidyZen is offline
post #15 of 16 Old 08-18-2013, 06:53 PM
cybrsage's Avatar
Liked: 154
It depends on how many torrents you are serving up from that save HDD while your kids view your pron stash at the same time you are trying to watch a move from it.
cybrsage is offline
post #16 of 16 Old 08-18-2013, 10:31 PM - Thread Starter
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
LOL
ellisr63 is offline
Reply Home Theater Computers
