A/V Sync with 59.94 Video using MPC-HC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-16-2013, 09:19 PM - Thread Starter
ADAT8's Avatar
Hi
I'm having trouble playing video (720 & 1080) at 59.94 fps through MPC-HC with ffdshow. After about 20-30 minutes, the audio & video slowly drift out of sync & get worse from there. This occurs when I either use a real-time bob deinterlacer, or if I create a progressive file using a bob during the encode. The CPU is running at about 50% during playback so it's not a bottleneck there. I've told ffdshow to drop frames on delay but that hasn't helped either. Could it be a bottleneck elsewhere? I'm running a Pentium Dual Core @ 3Ghz with an Asus ENGT240/512. Any ideas are appreciated.
ADAT8 is offline
post #2 of 2 Old 08-17-2013, 12:37 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Try
- Hardware deinterlacer (the best PQ) (just turn off ffdshow's internal deinterlacer, hardware deinterlacer will work if NV12 is output)
- yadif (the second best)
although this may not solve your problem.
renethx is offline
Reply Home Theater Computers
