Hotswap Cage conversion from SAS to Sata? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 08-19-2013, 02:36 PM - Thread Starter
kevin g.'s Avatar
Quoted: 329 Post(s)
Liked: 138
Hello again, all...
I have recently come in to an HP Proliant ML350, that was utilized at my work. It is a G5 model, and has 6 SAS bays in the bottom. Part of the deal, was, I could have the box, but not the actual Windows Server 2003 program that came with it, nor could I have the 15k SAS drives that came with it...
I understand that I can install Sata drives, by adding a bay with a Sata backplane... (if it were a Sata backplane, you cannot do the inverse, and add a SAS cage...as I understand it...)
I have been looking on NEWEGG, Amazon, MCM...all without a really good idea of how to transfer over to SATA. All the SAS cages specify which motherboard...not sure if that is an issue with the swap.
Naturally the other question is: how to power and plug in? There is only one sata port on the motherboard. I have seen adapter cabling, but that doesn't help with the drive caddy...
Thanks in Advance
"Once you learn good English...Can't nobody take it away!"
Xbox LIVE Gamertag: KEVIN G 40
kevin g. is offline
post #2 of 20 Old 08-19-2013, 09:19 PM
fraile's Avatar
Actually, if your server has a SAS backplane you can simply use it as is. You'll want to grab some SAS/SATA (doesn't matter) hot swap caddies and put in your drives of choice but SAS backplanes can take SATA drives (you are right about SATA backplanes not taking SAS though).
The only thing you will have an "issue" with is that the E200 or P400 that comes in that server will only do 1.5G SATA, but its probably not going to impact performance much unless you buy SSDs.
fraile is offline
post #3 of 20 Old 08-20-2013, 07:25 AM - Thread Starter
kevin g.'s Avatar
Quoted: 329 Post(s)
Liked: 138
Not sure what you mean here. I can just plug my drives in and go? The hotswap cage has the SAS connections in the back of it, to allow the caddy's to slide in and the drive to plug in to each SAS bay. not sure how a different caddy will help?
kevin g. is offline
post #4 of 20 Old 08-20-2013, 08:11 AM
fraile's Avatar
Yes, you can just use your SATA drives in the SAS ports. I was assuming you had no drive caddies as well but if you were able to keep them then you can use them as well.
SAS ports can take SATA drives.
SATA ports cannot take SAS drives.
I use a HP DL380 G6 with SATA drives as well as the HP SAS expansion cabinets. We also use many servers at my workplace (Dell, HP, IBM) with SATA drives but all have SAS backplanes with SAS raid controllers.
fraile is offline
post #5 of 20 Old 09-02-2013, 02:51 PM - Thread Starter
kevin g.'s Avatar
Quoted: 329 Post(s)
Liked: 138
A bit of an update,
I have been looking at some options for an O/S, and viewing opensource projects....Solaris, Amahi/Ubuntu, Freenas...
I had settled on Freenas, as I have a little experience with it.
I loaded an old drive in the caddy and installed it in the machine. The Proliant will not recognize it whatsoever. On the boot screen, it says; "No logical drive detected"
Not sure how to get past this one...
kevin g. is offline
post #6 of 20 Old 09-02-2013, 06:39 PM
fraile's Avatar
Hmm, well you never said which Raid controller you have in there. But if it is the P400 I'm not sure if you can just use a single drive as you usually have to go into the raid configuration utility and create a raid set (2 drives minimum) then a logical drive for the OS to see.
Some HPs can load the raid utility after the bios initializes but some systems you need to download the ACU offline image from HP's site and burn it to a CD to boot into and make the raid arrays.
fraile is offline
post #7 of 20 Old 09-03-2013, 08:03 AM - Thread Starter
kevin g.'s Avatar
Quoted: 329 Post(s)
Liked: 138
It does have a raid card, I believe it's the 200i...(based on startup bios splash...)
I never thought to try two HDD's. I wonder if I can get in to it enough that I may shut off the RAID, and proceed with my install? I did download HP's SmartStart, but there was no indication of being able to do that via the offline ACU...
kevin g. is offline
post #8 of 20 Old 09-03-2013, 09:26 AM
fraile's Avatar
Hmm, well if it is a E200i you can just hit F8 while the system is posting and it should bring you into the HP ORCA (Option Rom Configuration) tool. You should be able to use 1 drive with the E200 but it depends on what mode the controller is in (AHCI/RAID). If you do raid through the controller, remember it is a software raid controller and the OS will not see the raid array without drivers.
fraile is offline
post #9 of 20 Old 09-03-2013, 12:00 PM - Thread Starter
kevin g.'s Avatar
Quoted: 329 Post(s)
Liked: 138
THANKS,
I have been through every bios setting, and the ORCA config for the raid card, as well as the ACU...there is absolutely no ACI/RAID "switch", there is an option for ROM based boot config. ACU offers boot from prior install, but since I do not have the original drives...
stumped...
kevin g. is offline
post #10 of 20 Old 09-03-2013, 01:04 PM
fraile's Avatar
(Stole image from another website)
Does your E200i/ORCA screen not show any physical drives? It should like like this image if it shows a drive:
Also on boot does the system display the E200 to you in this manner (example):
And no other controllers appear in the same manner right (P400, P600/800, etc.)?
Does the hard drive caddy light up all on on boot/when inserted?
I checked my E200i setup on my DL120 G6 and it is actually set to use 1 Physical disk with RAID0 selected as opposed to actually offering an AHCI option, which allows my ESXi installer to see the drive w/o RAID.
fraile is offline
post #11 of 20 Old 09-03-2013, 05:36 PM - Thread Starter
kevin g.'s Avatar
Quoted: 329 Post(s)
Liked: 138
Nope...here"s what I have
Sorry, F8 brings me in to the Integrated Lights Out menu...not ORCA
Diag//Inspect utility
This only allows me to view the setup configuration. Unable to change any values.
kevin g. is offline
post #12 of 20 Old 09-03-2013, 06:44 PM
fraile's Avatar
Ok, I just checked and the RAID F8 option only appears when it actually detects an attached drive.
Can you tell me what drive/caddy you are trying to use and also verify that there are no PCI/PCI-X/PCIe RAID controllers in the system?
fraile is offline
post #13 of 20 Old 09-03-2013, 06:59 PM - Thread Starter
kevin g.'s Avatar
Quoted: 329 Post(s)
Liked: 138
I really appreciate all the help...
It is the stock 6 bay SAS drive bay...with 3 original drive caddies and 3 generic.
Oh, and the l.e.d extension lights only ignite at startup, and when I insert a drive.
The only bay that is occupied is for the 200i...
I really thought I was on to something yesterday, when I read the the G4 had a switch to tell the Motherboard that you had SATA drives installed. Not so with the G5
kevin g. is offline
post #14 of 20 Old 09-03-2013, 07:13 PM
fraile's Avatar
Sure np, So you've only got 1 drive inserted into the SAS bay with one of these caddies?
What size is the drive? I see many online posts regarding issues with drives over 1TB.
fraile is offline
post #15 of 20 Old 09-03-2013, 07:40 PM - Thread Starter
kevin g.'s Avatar
Quoted: 329 Post(s)
Liked: 138
yeah, so far only one drive. I will try two as suggested...
It's an older 40 gig WD, more than enough for FreeNAS to start...I was just trying to get it up and running.
That surprises me about the over 1tb, but it did come with 3- 72 gig enterprise drives...
kevin g. is offline
post #16 of 20 Old 09-03-2013, 07:43 PM
fraile's Avatar
Yeah that definitely should work... Only thing I can think of is its not making the drive connection, bad drive or bad port but seems unlikely if you've used this drive recently in another system and they were using that port at your workplace.
fraile is offline
post #17 of 20 Old 09-05-2013, 07:18 PM - Thread Starter
kevin g.'s Avatar
Quoted: 329 Post(s)
Liked: 138
update
Added a 320 gig that has been showing bad sectors in my N40L. It was immediately recognized as a valid drive. The 40 gig is now showing a red constant LED. In another box, it is showing a SMART test of all healthy...go figure.
I wonder if it is the fact that it is older, or maybe that it's a 40? (too small?)
kevin g. is offline
post #18 of 20 Old 09-06-2013, 08:03 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Why don't you just buy a new hard drive ?
Mfusick is offline
post #19 of 20 Old 09-06-2013, 09:36 AM
fraile's Avatar
Well thats good it sees the 320GB, the 40GB work too as they have 36GB drives that are common in servers but you never know as there can me firmware issues between the controllers and drives.
fraile is offline
post #20 of 20 Old 09-06-2013, 11:51 AM - Thread Starter
kevin g.'s Avatar
Quoted: 329 Post(s)
Liked: 138
I will be...Multiple drives for it, actually.
I just needed to get it up and running...It has not been used in a number of years, it was filthy inside and out, (bodyshop environment) and it was a question whether it was even worth spending the time.
I would have thought that was the case as well, but I have swapped it over to my WHS machine and it reads ok, Home Server SMART raises no faults...I have put it in a different caddy, different bay, etc...red light every time.
It's just too small to really do anything with anywhere else...
The funny thing is, the 320 that reads fine here, in the ML350, but does not check out in my WHS box...(Home Server SMART, again)...states bad sectors.
kevin g. is offline
Reply Home Theater Computers
