can not use my onboard video - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-19-2013, 02:52 PM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
when i set up my new CPU/mobo i just put my 550ti in and ran with it. noiw i would like to try and run it without the discreet card but cant figure out how to reenable my onboard stuff. i tried uninstalling and deleting the nvidia drivers, but with no card in the slot the screen stays blank, even vga wont work. any ideas?
cpu is g2020
board is GIGABYTE GA-B75M-D3H LGA 1155 Intel B75 HDMI
card is nvidia 550ti stock
manuetdeo is offline
post #2 of 6 Old 08-19-2013, 03:05 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
You might need to enable it in the bios. Clearing the CMOS will revert the bios to default settings which should have integrated video enabled.
Mrkazador is offline
post #3 of 6 Old 08-19-2013, 08:13 PM
im bored's Avatar
Usually its as simple as physically removing your Video Card (550ti) out of your PC and during the next boot bios should rout the video through the built in components.
im bored is offline
post #4 of 6 Old 08-20-2013, 05:43 PM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
thats the problem, i get no video if i take the card out; no bios, nothing?
i wonder if its because this board has dual uefi bios?
post #5 of 6 Old 08-20-2013, 05:52 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
Put the 550ti back in. Then enable onboard video in Bios. Shut down and pull 550ti
Andy_Steb is offline
post #6 of 6 Old 08-20-2013, 06:39 PM
cybrsage's Avatar
Liked: 154
If you reset the BIOS it will return to default, which is to use the onboard video if there is not an add in card detected. Look in your manual (or closely at the mobo) and you will find a jumper you can move that will reset the BIOS. An alternative method is to unplug the power supply from the wall and remove the battery. Wait a few minutes (or short the battery terminals with a jewlers screwdriver or such) and put the battery back in. Plug in the PC and power on, the BIOS should be reset.
cybrsage is offline
Reply Home Theater Computers
