DolbyTrueHD Won't Play In Mediaportal - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-19-2013, 05:11 PM - Thread Starter
crazy4daisy's Avatar
Liked: 31
I just got my first Htpc and am finding that all my DolbyTrueHD titles will not play in mediaportal. I press play and they just flick back to the title screen. All my DTS HDMA titles play no worries. I also notice that as I scroll through them in list mode that the said DolbyTrueHD titles lettering is dull, they are there in the library, but obviously a setting or something is wrong. Any suggestions most welcome. I use dvdfab to copy and to rip.
Collingwood Magpies 2010 AFL Premiers
crazy4daisy is offline
post #2 of 11 Old 08-20-2013, 04:03 AM
captain_video's Avatar
Quoted: 524 Post(s)
Liked: 341
captain_video is offline
post #3 of 11 Old 08-20-2013, 05:00 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
The latest MP uses LAV Filters by default. Open LAV Audio Decoder configuration and make sure TrueHD bitstreaming is checked.
Selecting the correct main title a BD movie is not so straightforward.
It looks like you didn't choose the correct format in DVDFab. you have to choose "mkv passthrough", otherwise you won't get HD audio nor the unconverted, original video format.
renethx is offline
post #4 of 11 Old 08-20-2013, 06:54 AM - Thread Starter
Liked: 31
How do I go about getting into it to check True HD is checked, I cannot find any of the boxes to ensure it is bit-streaming the signal? Thanks.
post #5 of 11 Old 08-20-2013, 06:56 AM
pittsoccer33's Avatar
Quoted: 650 Post(s)
Liked: 432
a little blue lav logo should appear on the notification bar next to the clock. you can double click on it.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #6 of 11 Old 08-20-2013, 07:05 AM - Thread Starter
Liked: 31
Ok thanks, I'm currently copying a movie so I'll give it a shot as soon as the copy ends smile.gif
post #7 of 11 Old 08-20-2013, 07:11 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Or Windows Start menu > LAV Filters > LAV Audio Configuration. By default every HD audio is to be decoded to LPCM (I am not sure how you can get DTS-HD MA bitstreaming without setting LAV Audio properly).
renethx is offline
post #8 of 11 Old 08-20-2013, 09:03 AM - Thread Starter
Liked: 31
Well unfortunately no success. It doesn't show up on the task bar or notification area, I've gone in and set it to show but it doesn't. It doesn't show up on the start menu screen anywhere either. So I'm gradually getting all my titles onto mediaportal but The Dark Knight, Iron Man 1&2, the Spider-man trilogy etc. (all DolbyTrueHD audio) won't play. Just a total bummer at this point, very cheesed off frown.gif
post #9 of 11 Old 08-20-2013, 12:21 PM
el_kano's Avatar
Do you have the LAV filters installed?
Under Control Panel>Programs>Uninstall a program
will be a list of programs installed on the computer. Is LAV filters included?
LAV filters are an optional mediaportal install, so unless you selected to install them during setup they won't be available.
You can either run the setup again (this time install LAV) or manually download and install LAV.
el_kano is offline
post #10 of 11 Old 08-22-2013, 04:39 PM - Thread Starter
Liked: 31
Issues all sorted thanks all for the advice. Was a combination of several things. Being new to Htpc's I thought I'd be able to play any title thru my tv without a receiver. I'd only setup with a tv to copy movies before I moved it to the main system to save using the projector. Anyway once hooked up to my Integra and the appropriate settings ticked all is good. In hindsight its kind of good I had happen what happened as I've learnt a lot and know just about every setting there is on my Htpc! Thanks again smile.gif
post #11 of 11 Old 08-29-2013, 03:29 PM
David Olsen's Avatar
Just wanted to add that if you use external soundcard then dont tick the bitstreamning, its only for hdmi and spdi
David Olsen is offline
Reply Home Theater Computers
