Storage solution help (flexraid or some thing similar) - AVS Forum | Home Theater Discussions And Reviews
Old 08-21-2013, 09:42 AM - Thread Starter
hcker2000's Avatar
So I have read the flexraid alternative thread on here. Sounds like a lot of people have more experience than I do so perhaps you can help me out.
I used to use a raid5 setup but was burned twice during recovery by URE's so thats been abandoned.
I'm running ubuntu.
My current disk setup is as follows:
Storage Drives:
  • one 3tb storage drive for movies.
  • one 1tb storage drive for music/temporary storage
  • one 1tb storage drive for personal assets like family photos/videos, documents, etc..
Backup Drives:
  • one 3tb external drive to backup the movies drive
  • one 2tb external dive to backup the two 1tb drives
Now I have at least one more 1tb drive laying around maybe two. My movie drive is almost 100% full. So its time to either buy a couple more 3tb drives (expensive) or re-setup my storage solution to better make use of the space.
Let me tell you what I like about my current setup:
  • I know which files are on which drive.
  • If one drive dies it dosn't take my other media offline with it.
  • Easy to tell which drive needs replaced and where to find its backed up date for restore.
  • I know for sure my backup drives are powered off and not wasting their life span just sitting doing nothing.
I have been considering flexraid as it offers both protection and pooling but I dont absolutely need to have pooling.
The main goal is better use of the drive I have + simpler managment. Right now I power up the external drives and run my backup software about once a month because I'm lazy.
I'm fine with a snapshot type solution which is basically what I'm doing now.
So it seems really simple to me to see if there is a way to use my one 2tb backup drive as a storage drive as well as my other 1tb unused drive? The 3tb backup drive could be used as a parity drive. Keep in mind though I want to make sure that if for some reason say my parity drive + another storage drive fails that all my other data will remain safe and accessible. Also keep in mind i need to be able to set this up without losing any existing data in the process.
hcker2000 is offline
Old 08-21-2013, 10:00 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
If you are not on windows you can use Unraid
Mfusick is offline
Old 08-21-2013, 11:40 AM - Thread Starter
hcker2000's Avatar
Unraid is not acceptable as it is its own linux distro. I'm looking to build this on top of that I already have going. I'm thinking SnapRAID could work. Any one used it?
Old 08-21-2013, 12:10 PM
bryansj's Avatar
Quoted: 1129 Post(s)
Liked: 559
Why not just get FlexRAID parity and not the pooling option?
bryansj is offline
Old 08-21-2013, 12:40 PM - Thread Starter
hcker2000's Avatar
I could do that. I'm hoping some one can give me some more info as well on the restore process if say I lose a hard drive.
Can I simply add a new disk of the same size and restore with a button click?
Can I use multiple smaller disks and restore to those rather than one larger disk?
Old 08-21-2013, 12:41 PM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
If you're using an existing system and plan on adding the server on top of it then I'd probably go with FlexRAID. Also, if you do decide to go with FlexRAID, go for the dual license even if you don't currently plan to use the pooling feature. At some point you're probably going to expand the system and you'll be glad you have it. Besides, it's cheaper to buy them together than separately.
captain_video is online now
Old 08-21-2013, 01:18 PM
Elpee's Avatar
Quoted: 61 Post(s)
I'm currently using SnapRaid but on Windows OS not Ubuntu.
If you really like SnapRaid, go and ask Andrea at his (SnapRaid) forum.
I've heard FlexRaid also supports Linux (including Ubuntu, Redhat, SUSE, Zentyal, OpenMediaVault, and many others).
Elpee is offline
Old 08-21-2013, 02:07 PM - Thread Starter
hcker2000's Avatar
How are you liking it on windows? What are the sync times like?
Old 08-21-2013, 02:41 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I also use Snapraid on my windows media server and use Junction folders for pooling.  A "poor mans" storage and pooling solution biggrin.gif
Sync times are based on your read/writes speeds of your hard drives so it varies. If the hard drive can read at 100MBps and the parity can write at 100MBps then you should get 100MB a second for a sync. I've never seen a sync that was unusually slow except for my hard drives that are 99% full. A snapraid check will take around 5hrs to complete if I remember correctly. I have three 2TB HDD with 2 full and 1 half full. Doesn't hurt to try out, if you don't like it then you can just delete the parity and go with something else.
Mrkazador is offline
Old 08-21-2013, 02:53 PM - Thread Starter
hcker2000's Avatar
See thats cool. I like the idea of the oh well dosnt work well or takes to long or what ever and just re-format the parity drive an uninstall and your all set.
Old 08-21-2013, 03:01 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
You don't install Snapraid, its run like a portable program. Its literally just deleting your parity (right click, delete) and deleting the Snapraid folder. Snapraid also creates a content file that you specify where its placed but its a single file, right click and delete.
Old 08-26-2013, 08:24 AM - Thread Starter
hcker2000's Avatar
I got snapraid setup over the weekend and it was a snap to setup. Very easy to understand. Only down side is that it dosnt do on the fly data reconstruction of data on a failed disk like raid 5 but I'm ok with that. I also setup my parity file on a usb3 external drive so I can keep that spun down except when I want to run a sync or check.
