I just bought one of the 24 bay Servermicro enclosures off Ebay that is referenced on this forum, and need a little direction as to what OS to run.
I searched RAID OS alternatives, and it's giving me a headache. Unraid, FreeNAS, FlexRaid, WHS, etc. Nobody seems to agree, and I don't know what would be best for what I'm trying to do.
Currently I have no server, just my main PC, an HTPC, and some laptops/tablets/etc (all running Win 7 for the most part). For the Supermicro file server, I'd like to put the two storage drives from the HTPC into this to take advantage of data backup (One 2 TB & one 3 TB currently). I also have a few 500 GB drives laying around I could throw in the Supermicro as well. I can purchase a couple of 2/3/4 TB drives if needed for parity/cache or whatever is needed. I would then add drives as needed. What I don't want to have to do is go out and buy 24 hard drives that are all the same size/vendor.
Supermicro server is basically going to house movie rips/pictures/home video/recorded tv from homerun prime, and then be accessed by WMC/Media Extenders/PC's. Basically a big file server that can stream content over gigabit network to everything else in the house.
Any of the programs stand out for this? Appreciate any help all.
You're right. Not everyone will agree. All I can tell you is what I've done.
I've got a 12-bay server with about 9tb of data capacity. My server also acts as a DVR and is a working PC some of the time. I'm running W8 Pro 64 with classic shell (can't stand windows 8). For server I'm running Flexraid with drive pooling. Remember, the parity drive, which you will lose all capacity of, needs to be the largest drive in the array so if you intend to use 4tb drives I would recommend you pick up a 4tb drive and start your array using that drive as your parity.
I have a 2U 12 bay Supermicro server that I picked up a year ago. I decided to install Windows 7 on it just in case I wanted to put in a Ceton tuner card at some point in the future.
I co-opted a disk drive from another PC to do it, but there is a way to install Windows 7 from a thumb drive if necessary. A year down the road I'm very happy with my choice. 7 had all the drivers needed to get it up and running. I've never worked with Linux and I was already taking on a big project, so I didn't feel like learning. I replaced all the the fans and put in a new power supply, so instead of a hurricane, it purrs like a kitten.
The Server isn't connected to a monitor or keyboard. I access it using my Ipad and Splashtop. It's a real luxury to have a full pc that I can off load video conversion and other tasks to.
Forgot to mention, I did initally have Flexraid installed, but had to remove it due to stability issues. I'm not sure if it was Flexraid, or if one of my hard drives is failing. It was new, and has had no problems since I took it out of the array, so I'm pretty sure it was Flexraid.
At this time I'm not using any RAID softward. I've jut been backing up my files the old fashion way. Once done you will love it. It's a great feeling to have almost unlimited storage.
I would also assume that FlexRaid would work on WHS 2011 as well right? I got lots of different server OS's to try out and still working on a solid solution. I like the solidness of Server 2008 R2 and I could run WHS 2011 in Hyper-V to handle all the client backup tasks. But of course its the matter of whether to run FR on 2008 R2 or on WHS 2011.
Originally Posted by AVTechMan /t/1487246/media-server-os-recommendation#post_23657041
I tried flexraid on WHS when moving off WHS. I considered FlexRaid on regular win 7 as one solution as well as a few other solutions
In the end I went with unRAID. Main reasons:
Cheap to buy and try: $120-ish for the "pro" version of what ever it's called. You can test with free version with just a USB stick (and a spare drive)
Like the technology
Boots off USB stick - 10 mins to replace failed OS drive: no installing windows, driver, and then trying to get storage back online
Lots of available plug-ins
Multiple parity drives
cache drives (for fast upload and later copy to array)
Very active forum and developer community
Was never really "comfortable* with FlexRaid's company. Can't put my finger on the reason. I don't think LimeWire is much better: AFAIK it's pretty much one guy (or at least FlexRaid is)
I used to work with UNIX many years ago, but very, very rusty. You need very little UNIX skills (if any to use and install)
I'm running on my HP Microserver N36L. Streams 1080p to my media center PC just fine
Been using for about 6 months. Happy with the choice.
Thanks for all of the replies everyone -- I've narrowed it down to unraid or flex on top of WHS or 7. Did some more research and saw that Assassin has server guides now so I'm gonna see what those look like and go from there.
in regards to cost, WHS 2011 is usually sold at NewEgg for $30-$35 once a month, and the most FlexRaid will cost (depending on the Package you want) is $60.
Max price for the two is $110 if you can't wait for the sale on WHS (normally $50)
If you want plug-ins, (or other server-centric opportunities) take a look at this site: http://www.wegotserved.com/
Originally Posted by Triglet /t/1487246/media-server-os-recommendation#post_23657483
I have downloaded Server 2012 to use for the 6 month trial, but the only problem I have is that it does not support XP clients for backup since I have two XP boxes. I have legacy software and hardware for some of the video work I do that will only work on XP, so upgrading to 7 won't be an option in that case.
Plus I need to test whether the Ceton (PCIe version) will work with 2012. I know how to do the manual bridging process to where I can share out the tuners to the clients.
I'd still recommend WHS2011 if you can get it. It's very stable, and while it's not actively developed any more, because it's built off Windows 2008 R2, there's still massive support for it, and you can get it for a rock bottom price. Windows 2012 Essentials (the supposed replacement for WHS2011) is hugely more expensive and while technically more up-to-date, almost everything you need can still be done on the older platform. Also, 2012 Essentials requires you to setup a full A/D domain during installation, which is way overkill for the average home user.
Originally Posted by mark_anderson_u /t/1487246/media-server-os-recommendation#post_23657427
Like the technology
Originally Posted by tman247 /t/1487246/media-server-os-recommendation#post_23657785
I wouldn't touch WHS2011. I own it and moved off it as soon as MS dropped it. I loved original WHS.
I get what you say about lots of support, but I still wouldn't use
I dropped it because of
Lack of Drive Extender (forcing you to buy StableBit, FlexRaid et al and I wasn't happy with any of those offerings). I know DE was pretty lame tech, but was easy for critical data
Originally Posted by mark_anderson_u /t/1487246/media-server-os-recommendation#post_23661591
You have to understand, WHS 2011 was out before Windows 8 so its no surprise that you had problems with Win8 client backups. WHS 2011 is based more on Windows 7 structure rather than 8. Server 2012 Essentials has native support for Win8 client backups.
I did a test 64-bit image restore and had no problems.
Originally Posted by AVTechMan /t/1487246/media-server-os-recommendation#post_23661616
There are many low cost alternatives to DE so that is not a reason to give up on WHS2011. Windows8 pc's backup fine for me and the only 64bit os restore I did worked ok too.
Itsa shame MS has decided to drop WHS, it works really well.
I too loved the first WHS, but it was getting very long in the tooth, and certainly the lack of DE was a huge issue for me in WHS2011, and caused a massive outcry when MS said they were dropping it, but it did open up a thriving 3rd party market for replacements. I waited about 12 months before moving to WHS2011 and selected Stablebit Drivepool once it reached maturity and reviews were good. It integrates nicely in the WHS console, and works very, very well. If a small outfit like Stablebit can do this, then lord knows why MS couldn't.
My biggest gripes with 2012 Essentials are;
1) Cost. It's stupidly expensive if it's being sold as a replacement for WHS2011
2) You have to use A/D, and have no choice in this (it puts quite an overhead on the server)
3) I would not trust one bit of my data to Storage Spaces. There have been some real horror stories with people losing data or SS not working as expected.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
