Anyone know hex codes for PC IR receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-23-2013, 02:40 PM - Thread Starter
Ian_Currie's Avatar
Quoted: 66 Post(s)
Liked: 25
I have a Pronto remote that I can input HEX codes and I have a USB infra-red receiver for my HTPC.
I just now need to know what the hex codes are for a PC keyboard (arrow keys, backspace, etc).
Can anyone help me out?
Thanks in advance!
Ian_Currie is offline
post #2 of 7 Old 08-24-2013, 06:59 AM
stanger89's Avatar
Quoted: 3370 Post(s)
Liked: 1833
Depends on what software you're using (like Eventghost or Girder, etc) to handle the IR signals in which case they can be whatever you want them to be. If you're using an MCE IR Receiver, you just pick an MCE remote from the database for your remote.
stanger89 is online now
post #3 of 7 Old 08-24-2013, 10:05 AM - Thread Starter
Ian_Currie's Avatar
Quoted: 66 Post(s)
Liked: 25
Thanks for the reply.
I bought a HP USB MCE IR Wireless Receiver that I thought didn't need any software.
I tried EventGhost and from what I can tell it didn't recognize it.
I guess I should pose my question this way:
Is there any way I can get my Pronto remote to emulate a PC keyboard so that I can use it to control Media Browser (and other apps)?
If so, do I need a specific USB IR receiver? Do I need special software to translate the codes received by the receiver to be seen as keyboard codes?
Any help appreciated, I'm going nuts trying to figure this out and am trying not to break down and buy a Harmony Remote because I'd prefer not to have two remotes (and I love my Philips Pronto).
Thanks in advance!
post #4 of 7 Old 08-24-2013, 12:27 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
Andy_Steb is offline
post #5 of 7 Old 08-24-2013, 01:37 PM
stanger89's Avatar
Liked: 1833
You shouldn't have to, you should be able to just pick the profile for a Windows Media Center computer and it should just work, no software needed. I think at least, I've not used remotes in windows since a streamzap with Girder a long time ago (I'm using my MCE IR receiver in OpenELEC at the moment).
post #6 of 7 Old 08-24-2013, 06:01 PM
mdavej's Avatar
Quoted: 2222 Post(s)
Liked: 972
I made these for you. I hope they work. Warning: Spoiler! (Click to show)
Code:
Device Code: 4.15 Function: 0
0000 0073 0000 0023 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 09AC
Device Code: 4.15 Function: 1
0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 09BC
Device Code: 4.15 Function: 2
0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0010 09AC
Device Code: 4.15 Function: 3
0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 09BC
Device Code: 4.15 Function: 4
0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 09AC
Device Code: 4.15 Function: 5
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0020 09BC
Device Code: 4.15 Function: 6
0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0020 0010 09AC
Device Code: 4.15 Function: 7
0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 09BC
Device Code: 4.15 Function: 8
0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 09AC
Device Code: 4.15 Function: 9
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0020 09BC
Device Code: 4.15 Function: 10 Clear
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0020 0020 0010 09AC
Device Code: 4.15 Function: 11 Digit Enter
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0020 0010 0010 09BC
Device Code: 4.15 Function: 12 Power
0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0020 0010 0010 0010 09AC
Device Code: 4.15 Function: 13 Windows
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0020 0020 09BC
Device Code: 4.15 Function: 14 Mute
0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0020 0010 09AC
Device Code: 4.15 Function: 15 Info
0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 09BC
Device Code: 4.15 Function: 16 Vol+
0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 09AC
Device Code: 4.15 Function: 17 Vol-
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0020 09BC
Device Code: 4.15 Function: 18 Ch+
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0020 0020 0010 09AC
Device Code: 4.15 Function: 19 Ch-
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0020 0010 0010 09BC
Device Code: 4.15 Function: 20 FFWD
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0020 0020 0010 0010 0010 09AC
Device Code: 4.15 Function: 21 Rew
0000 0073 0000 0020 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0020 0020 0020 09BC
Device Code: 4.15 Function: 22 Play
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0020 0010 0010 0020 0010 09AC
Device Code: 4.15 Function: 23 Record
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0020 0010 0010 0010 0010 09BC
Device Code: 4.15 Function: 24 Pause
0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0020 0010 0010 0010 0010 0010 09AC
Device Code: 4.15 Function: 25 Stop
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0020 0010 0010 0020 09BC
Device Code: 4.15 Function: 26 SkipFwd
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0020 0020 0020 0010 09AC
Device Code: 4.15 Function: 27 SkipBack
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0020 0020 0010 0010 09BC
Device Code: 4.15 Function: 28 Caps Lock
0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0020 0010 0010 0010 09AC
Device Code: 4.15 Function: 29 Mouse
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0020 0020 09BC
Device Code: 4.15 Function: 30 Up
0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0010 09AC
Device Code: 4.15 Function: 31 Down
0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 09BC
Device Code: 4.15 Function: 32 Left
0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 09AC
Device Code: 4.15 Function: 33 Right
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0020 09BC
Device Code: 4.15 Function: 34 OK
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0020 0020 0010 09AC
Device Code: 4.15 Function: 35 Back
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0020 0010 0010 09BC
Device Code: 4.15 Function: 36 DVD Menu
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0020 0020 0010 0010 0010 09AC
Device Code: 4.15 Function: 37 Live TV
0000 0073 0000 0020 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0020 0020 0020 09BC
Device Code: 4.15 Function: 38 Guide
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0020 0010 0010 0020 0010 09AC
Device Code: 4.15 Function: 70 Yellow / My TV
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0020 0010 0010 0020 0010 09AC
Device Code: 4.15 Function: 71 Green / My Music
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0020 0010 0010 0010 0010 09BC
Device Code: 4.15 Function: 72 Recorded TV
0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0020 0020 0010 0010 0020 0020 0010 0010 0010 0010 0010 09AC
Device Code: 4.15 Function: 73 Blue / My Pictures
0000 0073 0000 0020 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0020 0020 0010 0010 0020 0020 0010 0010 0020 09BC
Device Code: 4.15 Function: 74 Red / My Videos
0000 0073 0000 0020 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0020 0020 0010 0010 0020 0020 0020 0020 0010 09AC
mdavej is online now
post #7 of 7 Old 08-26-2013, 05:54 AM - Thread Starter
Ian_Currie's Avatar
Quoted: 66 Post(s)
Liked: 25
Thank you very much!
Reply Home Theater Computers
