Looking to build a nice htpc and know nothing! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 30 Old 08-25-2013, 11:42 AM - Thread Starter
skzzzzy's Avatar
So today i was going to order a tivo romeo + dune or popcorn hour for my media, but just foundout you can add cable cards to htpc's... i never knew.
So im looking to build a nice live tv/dvr/media playback htpc..
My budgets about $1,000-$1,400
what i need is,
1. Ability to add a timewarner tv cable card with atleast 4-6 tuners
2. Ability to playback and media i have, avi, mkv, dvd iso, bluray iso, 3d
3. Completely lag free, silent, low energy.
4. Wifi
5. Nice remote
So far the only things i have picked out are,
Samsung 840 120gb SSD
for the OS
WD Red 2TB nas drive
For live tv dvr
WD Red 3TB nas drive x2
For Media playback of mine.
And possibly,
Ceton InfiniTV 6 PCIe - 5205-DCT06IN-PCIE - Six-tuner Card
For a cable card.
Have no clue what would be a good case, cpu, mb for a htpc or even which OS to use.
skzzzzy is offline
post #2 of 30 Old 08-25-2013, 02:43 PM - Thread Starter
skzzzzy's Avatar
Heres what im at so far and its already over my budget =\.
Case:
Fractal Design Black Aluminum / Steel Node 605 FD-CA-NODE-605-BL ATX Media Center / HTPC Case
CPU:
AMD FX-6300 Vishera 3.5GHz (4.1GHz Turbo) Socket AM3+ 95W Six-Core Desktop Processor FD6300WMHKBOX
Motherboard:
GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
RAM:
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
Media HDD's:
2x Western Digital Red NAS Hard Drive WD30EFRX 3TB IntelliPower 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
Live TV DVR HDD:
Seagate Constellation CS ST2000NC000 2 TB 3.5" Internal Hard Drive - 6Gb/s SATA - 7200 rpm - 64 MB
OS HDD:
SAMSUNG 840 EVO MZ-7TE120BW 2.5" 120GB SATA III TLC Internal Solid State Drive (SSD)
Cable card device:
Ceton InfiniTV 6 PCIe - 5205-DCT06IN-PCIE - Six-tuner Card for Watching Digital Cable TV on the PC, PCI-Express x1 Interface
GPU:
SAPPHIRE Radeon HD 6670 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready Video Card
Power Supply:
CORSAIR Builder Series CX600 600W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply
OS:
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
$1,554.89
skzzzzy is offline
post #3 of 30 Old 08-25-2013, 03:01 PM
mdavej's Avatar
Quoted: 2273 Post(s)
Liked: 992
Do you really need 6 simultaneous tuners? If not, dropping down to 4 will save $100, or $200 if you buy used.
That video card is way overkill. A $15 card will work fine for HD video.
Only 64GB is needed for your SSD.
You didn't mention how many other TVs are in your system, but for 2 or 3 simultaneous extender sessions, you only need 4GB.
600W power supply is also overkill.
A cool looking case is nice, but will your PC be anywhere near your home theater, or located remotely? If it will never be seen, you can get a cheaper case.
A nice remote can run a couple of hundred dollars. A perfectly functional remote can be had for as little as $10. In any case you'll need a $15-ish IR dongle for the PC, unless you plan to use a wifi solution like iRule.
mdavej is offline
post #4 of 30 Old 08-25-2013, 03:19 PM - Thread Starter
skzzzzy's Avatar
I wasnt sure what kind of GPU was needed.
Will only be for my bedroom TV
Started looking at 400w's but the upgrade to 600w was so minimal lol
I dont really have anywhere to hide the case, my rooms jam packed, going to put it on the shelf above my reciever on my tv stand.
I think im going to use my harmony one if its possible, i havent even checked yet.iRule.
skzzzzy is offline
post #5 of 30 Old 08-25-2013, 03:47 PM
mdavej's Avatar
Liked: 992
In that case you can definitely get by with 4GB RAM, 64GB SSD and a cheap video card like this:
http://www.avsforum.com/t/1485227/6450-vs-610
Think about the tuners too. My family of 4 using 4 TVs rarely uses all 4 tuners. Each tuner costs roughly $50.
You can use your harmony One with no problem.
Unlike a gaming PC, you to aim low with an HTPC. Every additional watt means more heat and noise. So you don't want to buy more than you need.
mdavej is offline
post #6 of 30 Old 08-25-2013, 04:54 PM
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
Most of the 80 Plus Bronze & better supplies seem to be most efficient at 50%. While a 600W PSU may be only a few dollars more than a 400W one, it's probably going to be less efficient when using in an HTPC.
I have a G620 CPU, 2 OTA dual tuner cards, and an HD6450 video card. While recording 4 programs & playing a 5th one the HTPC uses only 56 watts according to a Kill-A-Watt meter.
Mike99 is offline
post #7 of 30 Old 08-26-2013, 01:42 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
For tv/dvr/media playback, a quad-core is enough, for example, AMD A8-6600K (a good GPU is integrated), with a microATX FM2 mb (if you add a slim ODD) or an ATX FM2 mb (otherwise), e.g. ASRock A85X ones. DDR3-1866 is recommended.
renethx is offline
post #8 of 30 Old 08-28-2013, 09:09 AM - Thread Starter
skzzzzy's Avatar
would this be good enough?
CPU: i3 4340 3.6ghz HD 4600 GPU
Motherboard: Gigabyte GA-Z87N-Wifi LGA 1150
RAM: G.SKILL Ripjaws X Series (2 x 4GB) DDR3 1600
OS SSD: SAMSUNG 840 EVO MZ-7TE120BW 2.5" 120GB
DVR HDD: WD WD Blue 1TB 5400 RPM 8MB
OS: Microsoft Windows 7 Home Premium SP1 64-bit
or
Microsoft Windows 8 Professional 64-bit
Case: LIAN LI Black Aluminum PC-Q12B Mini ITX Media Center (Includes 80 Plus 300w Micro-atx PSU
Keyboard/Mouse: Logitech K400
Cable Card tuner: Ceton InfiniTV 4 PCIe - Quad-tuner Card
skzzzzy is offline
post #9 of 30 Old 08-28-2013, 09:25 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Yup, good enough. Do you have a media storage server? TV recordings will fill up 1TB very quickly.
renethx is offline
post #10 of 30 Old 08-28-2013, 09:38 AM - Thread Starter
skzzzzy's Avatar
I wanted to use a 2tb 3.5 but it wont fit that case and 2tb 2.5's cost too much.
Are 2.5's as reliable as 3.5's? can they handle recording that many shows at once on it without a hiccup?
I just purchased a synology 413 w/4x 3tb 2d reds but i dont think i can transfer to it? tmw cards are copy once so i think that disables me from transfering the files?
Another choice is, I could get an external HDD and plug to the pc or nas? worst case scenario ill keep it at 1tb, my current dvr is 500gb and has never passed 50%.
What all software do I need to install when i get it setup?
I want to beable to
record all my fav series auto if possible like on my dvr,
boot to live tv,
good codecs to install, and whatever else is reccomended?
skzzzzy is offline
post #11 of 30 Old 08-28-2013, 09:56 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
I want to beable to
boot to live tv,
you can transfer, but you will only be able to play on the machine they were recorded on. Which is fine for remote playing on the original recording machine.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #12 of 30 Old 08-28-2013, 10:06 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
2.5" drive is still fast enough to record multiple shows simultaneously. External USB 3.5" HDD enclosure (4-8 bays) is another solution or just start with a large enough case. Or iSCSI Target should work with NAS.
What you need is Windows Media Center (in Win 7/8) and the codecs built-in. There is no other choice for Copy Once contents.
renethx is offline
post #13 of 30 Old 08-28-2013, 11:22 AM - Thread Starter
skzzzzy's Avatar
So i wil be unable to use xbmc?
Should i just get a tivo and build a htpc for my file playbacks?
skzzzzy is offline
post #14 of 30 Old 08-28-2013, 11:33 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
To record Copy Once contents in PC, you have to use WMC and you can play recordings only within WMC of the PC you used to record them. The only other devices that can play recordings are WMC extenders (e.g. MS XBox, Ceton Echo). (If you use HDHomeRun Prime, there is another choice for watching live TV in other devices: DLNA.)
renethx is offline
post #15 of 30 Old 08-28-2013, 11:38 AM - Thread Starter
skzzzzy's Avatar
To record Copy Once contents in PC, you have to use WMC and you can play recordings only within WMC of the PC you used to record them. The only other devices that can play recordings are WMC extenders (e.g. MS XBox, Ceton Echo). (If you use HDHomeRun Prime, there is another choice for playback: DLNA.)
I think im going to just get a tivo, and build a htpc for playing back my media files. Seems like less of a hassle, then im not restricted on what i do with the htpc.
skzzzzy is offline
post #16 of 30 Old 08-28-2013, 11:39 AM
pittsoccer33's Avatar
Quoted: 650 Post(s)
Liked: 432
who is your cable provider?
cable programming is marked with a copy protection flag. different providers use them differently.
local channels are almost always copy freely. on most cable companies everything else is labeled copy once. only comcast and verizon are more permissive. they mark only premium movie channels as copy once.
you can use XBMC only if the channels you want to watch are copy freely. so a Comcast customer that doesn't subscribe to HBO, Showtime, etc would be fine. that could change tomorrow though. Dark Slayer is a frequent poster who uses XBMC and cable card.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #17 of 30 Old 08-28-2013, 11:46 AM - Thread Starter
skzzzzy's Avatar
TWC, mostly the only channels i watch are nat geo and history channel. The whole reason behind wanting to build a htpc was for xbmc, heard so much great stuff about it.
skzzzzy is offline
post #18 of 30 Old 08-28-2013, 11:50 AM
mdavej's Avatar
Liked: 992
Whether you use your PC for cable TV or not makes no difference in what you can or can't do with your other files.
Bottom line is using WMC as your DVR is going to save you a ton of money compared to Tivo or some other cable DVR. You can use whatever you want for your other files regardless. The hardware restrictions we've posted are simply because you said you were over budget. You're free to spend as much as you want. WMC and everything else will still work fine. The only reason I have an HTPC at all is to avoid DVR fees. So I put up with the complexity of the initial setup. If money is not a concern, then Tivo is definitely a simpler solution. But it sounds like you intend to build an HTPC anyway, so a DVR would be free, aside from the initial cost of the tuner, so you may as well give it a try. You can always return the tuner if you're not happy and pick up a Tivo.
mdavej is offline
post #19 of 30 Old 08-28-2013, 11:54 AM
Quoted: 650 Post(s)
Liked: 432
I'm a huge WMC proponent so obviously I'm very biased, but you might be surprised by what you're able to do with it. In my opinion XBMC's main advantage is some plug in support for a few streaming websites.
Going the Tivo route is going to double the cost of your media project and/or force you into a monthly subscription for the guide data.
I'm fairly certain you can use both in tandem - I know XBMC can launch other software. It should be possible to go right into live tv (inside WMC) from XBMC.
post #20 of 30 Old 08-28-2013, 12:08 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
There's some good information here too: looking to build a higher end htpc with your help.
Something that hasn't been mentioned yet is MediaBrowser to manage your media. It's a very nice addition to WMC.
StardogChampion is offline
post #21 of 30 Old 08-28-2013, 12:22 PM
Quoted: 650 Post(s)
Liked: 432
And it sounds like you're interested in the same programming as me. I only have a single cable card tuner and I get by just fine with it because those networks like H2 and Nat Geo replay their programming multiple times over a month, even multiple times a day.
When I would record something on History but wanted to watch a hockey game live WMC was smart enough to see that History planned on re-airing the same show at 1am and chose to record it then instead of interrupting my hockey game. You could probably get away with two tuners (to save some money) and never miss out on something.
post #22 of 30 Old 08-28-2013, 12:35 PM - Thread Starter
skzzzzy's Avatar
I really wanted 6 tuners even though I wouldnt use them lol.
only other tuner im currently looking at is hdhomerun prime, which is external. im trying to findout which is more reliable and issue free.
and ill give the htpc a try for liv tv. If it doesnt work out ill return the tuner and get the tivo.
skzzzzy is offline
post #23 of 30 Old 08-28-2013, 02:14 PM
Somewhatlost's Avatar
Quoted: 20 Post(s)
Liked: 25
I have 6 or 8 tuners (3 or 4 dual ATSC/QAM HDHomeruns), I forget how many exactly...
they are in my crawlspace with my servers...
it is scary back there... big spiders and such... and so many wires...
so I haven't been back there to count them in a while...
but anyway, you are not wrong wanting 6 tuners...
are you sure? you may not need them for "Live" TV...
but I haven't watched Live TV in years... (well except for morning news and such)
mostly I always watch DVR'd stuff... and my server goes out and records things it thinks I may like...
there are a few times it is recording 6 or 8 things at once...
there are also many times it is recording 0
6 tuners means you could be watching 2 live TV shows, and recording 4... seems reasonable to me...
NOTE: As one wise professional something once stated, I am ignorant & childish, with a mindset comparable to 9/11 troofers and wackjob conspiracy theorists. so don't take anything I say as advice...
Somewhatlost is offline
post #24 of 30 Old 08-28-2013, 02:31 PM
Charles R's Avatar
Liked: 648
I would go TiVo and OpenELEC (boot via USB Flash drive/accessing your NAS) for XBMC. Best of both worlds as far as I'm concerned. From someone using WMC and iSCSI.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Sony UBP-X800 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Roku Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #25 of 30 Old 08-28-2013, 06:20 PM - Thread Starter
skzzzzy's Avatar
Anyone think http://www.newegg.com/Product/Product.aspx?Item=N82E16811112361 case will work with the pci tuner card? its very skinny, only 3 and a half inches wide.
or any other case suggestions for my build? most cases im liking are too wide for my setup. it either needs to be a standing unit like the one i like or under 14" wide 9" height.
And do i need to get a after market cooler for the i3 cpu?
skzzzzy is offline
post #26 of 30 Old 08-29-2013, 12:43 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
renethx is offline
post #27 of 30 Old 08-29-2013, 08:11 AM
mdavej's Avatar
Liked: 992
My case is 13.9" x 10.5" x 4.0", and the Ceton card just fits. It has a low profile bracket, so the height works, but it's pretty long, which is what you have to worry about. I also had to add a fan right next to it to keep it cool enough.
mdavej is offline
post #28 of 30 Old 08-29-2013, 08:45 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
The length of Infinitv 6 PCIe is 6.6" (the same as Infinitv 4 PCIe), a slightly shorter than mini-ITX mb (6.7" x 6.7").
renethx is offline
post #29 of 30 Old 09-02-2013, 12:36 PM - Thread Starter
skzzzzy's Avatar
Well I just placed my order for my htpc, Ive had the Tivo Roamio for a few day, i really like it but just dont want to pay monthly for it.
Went with windows 8 pro because i was about to get it for $90 brand new,.
Disk Drive: LG Black 14X BD-R 2X BD-RE 16X BDXL Blu-ray Burner
CPU: Intel Core i3-4340 Haswell 3.6GHz LGA 1150 54W
Motherboard: ASUS H87M-PRO LGA 1150 Intel H87
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) DDR3 1600
DVR HDD: Western Digital Red NAS Hard Drive WD20EFRX 2TB
OS: Microsoft Windows 8 Professional 64-bit
Case: LIAN LI PC-V354B Black Aluminum MicroATX
PSU: CORSAIR Builder Series CX430 430W
Cable Card tuner: Ceton InfiniTV 6 PCIe - 5205-DCT06IN-PCIE
IR Reciever: Flirc
skzzzzy is offline
post #30 of 30 Old 09-08-2013, 07:40 PM
tecknotot's Avatar
Im just learning from experience now but make sure your motherboard is compatible with digital media via CETON and Windows 8. Not all motherboards will activate your CableCard.
tecknotot is offline
Reply Home Theater Computers
