MKV files dropping out - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 08-27-2013, 06:42 PM - Thread Starter
ernicoats's Avatar
I have been having troubles with MKV files stopping around the 20min mark. The one of the file details are below. Any idea why would be great.
MOVIE 1
Audio Info
Codec................: DTS MA / Core
Bitrate..............: 5059 Kbps / 1510 Kbps (encoded from TrueHD wavs)
kHz/bit..............: 48.0 KHz / 24 bits
Channels.............: 8 / 6
Language.............: English
Video Info
Codec................: x264
Type.................: 1080p
Format Profile Level.: High@L4.1
Resolution...........: 1920x800
Aspect Ratio.........: 2.40:1
Bitrate..............: 10,000 Kbps
Framerate............: 23.976 FPS
MOVIE 2
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 47mn
Bit rate mode : Variable
Bit rate : 30.5 Mbps
Maximum bit rate : 36.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.613
Stream size : 22.9 GiB (91%)
Title : MPEG-4 AVC Video / 29686 kbps / 1080p / 23,976 fps / 16:9 / High Profile 4.1
Language : English
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Codec ID : A_DTS
Duration : 1h 47mn
Bit rate : 2 395 Kbps / 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Title : DTS-HD Master Audio / English / 3803 kbps / 5.1 / 48 kHz / 24-bit
ernicoats is offline
Reply Home Theater Computers
