3.5" bay vfd solution - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Somewhatlost
post #1 of 10 Old 08-27-2013, 11:47 PM - Thread Starter
ikkuranus's Avatar
Quoted: 86 Post(s)
Liked: 53
I currently have a self built htpc with the apex mi-008 chassis. This case only has an available 3.5" external bay because the 5.25 bay has one of those flip down doors for optical drives.
My question is does anyone know if the Nmediapc pro-lcd would be small enough to fit in a 3.5" bay after desoldering the vfd from the pcb? Assuming that isn't the case does anyone know of a lcd of similar price and features that is already setup for a 3.5" bay or could be modified to do so? (similar price being 30-40us$ and preferably on amazon.com)
I have seen a few 3.5" vfd but they were all 80-100$ which is way too expensive as I could just buy a new case with one already included.
ikkuranus is offline
post #2 of 10 Old 08-28-2013, 08:09 AM
Somewhatlost's Avatar
Quoted: 20 Post(s)
Liked: 25
technically, it is an LCD not a VFD...
but anyway, I would just get the OEM version (comes as just the electronics, no plastic 'bay mount' crap), get a dremel (or preferably a small mill) and have at it... I am sure there would be a way to make it fit and look good.
might take some time and experimenting though...
NOTE: As one wise professional something once stated, I am ignorant & childish, with a mindset comparable to 9/11 troofers and wackjob conspiracy theorists. so don't take anything I say as advice...
Somewhatlost is offline
post #3 of 10 Old 08-28-2013, 11:01 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
I had it, ebayed it. It was useless from anywhere but 2-3 feet from PC. Went to target bought a $5 LED alarm clock, took it out of the case, and it fit the nMedia PC window perfectly.
That is all wife wanted, "clock like other people's DVRs"
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #4 of 10 Old 08-28-2013, 08:49 PM - Thread Starter
ikkuranus's Avatar
Quoted: 86 Post(s)
Liked: 53
The cheap ass in me says get the clock but I really want to be able to do custom stuff as well. Range isn't really an issue either.
post #5 of 10 Old 08-29-2013, 10:52 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
If you have 2x 5.25 bays available, I have an Antec Veris Premiere that I never end up using
http://store.antec.com/Product/accessory-veris_media/veris-premier/0-761345-30126-8.aspx
post #6 of 10 Old 08-29-2013, 11:56 AM
bryansj's Avatar
Quoted: 1134 Post(s)
Liked: 560
The wow factor of a VFD lasts about 30 seconds. I wouldn't bother.
bryansj is online now
post #7 of 10 Old 08-29-2013, 05:04 PM
Quoted: 20 Post(s)
Liked: 25
I don't know about that...
I liked my IMON-VFD so much I bought a 2nd one for another PC...
but then , I may just be easily amused...
vcrpro3 likes this.
post #8 of 10 Old 09-01-2013, 06:57 AM
Eiffel's Avatar
Quoted: 13 Post(s)
VFDs and LCD displays in HTPC were all the rage about 10 years ago... but like many others I've moved on. The only such display I found useful was a very large 20x2 VFD display (think cash register sized), which I could read from a distance and which meant I could play music without turning on my CRT display (or projector).
Nowadays, with tablets and LCD monitors, I see little reason to use them (I do wish there were some very cheap small monitors - say 7" XGA which one could connect to a PC though)
Eiffel is offline
post #9 of 10 Old 09-01-2013, 01:00 PM
Starsky's Avatar
ikkuranus, I have an old NEC VFD that I used with SmartieLCD back in the day, it is just the module (no bracket) and it is parallel (for internal header). Also the PCB is ~35x85mm so you need a little room for clearance above/below the 3.5 bay but the display itself is <25mm. I'd let it go for cheap rather than throw it out, if you're interested PM me.
Personally I like having a VFD but ultimately only found it useful as a clock, and occasionally setting it to blink 12:00 when I was feeling nostalgic.
Starsky is offline
post #10 of 10 Old 09-01-2013, 05:36 PM - Thread Starter
ikkuranus's Avatar
Quoted: 86 Post(s)
Liked: 53
Thanks for the offer but my motherboard don't have a parallel header. I assumed all suggestions or offers would connect to a usb header.
Reply Home Theater Computers
