PC connection issues to projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-02-2013, 03:33 AM - Thread Starter
ps2user's Avatar
Recently brought a projector to connect to my home cinema setup and having issues with my PCs running xmbc.
AVR - Onkyo 805
TV - Panasonic Plasma TV (don't remember model, 4yrs old)
Projector - Acer P1220
PC 2 - Dell Optiplex 360 + ATI GFX
PC 1 - Viewsonic VOT132 + Nvidia GFX
When i connect either PC via HDMI directly to the projector it displays ok.
When i connect either PC => HDMI => AVR => TV displays ok and AVR gets the bitstreammed sound ok
When i connect either PC => HDMI => AVR => Projector displays yet the AVR gets no sound at all. But when i have either PS3 or Wii U connected via HDMI => AVR => projector, display and sound is fine.
So far i've just managed to get sound through the AVR and picture on the projector by, and tinkering with xmbc display settings.
PC =>HDMI=> AVR => TV (TV switched off) for sound
PC => DVI /HDMI => Projector for display.
Originally i thought it was the new 10m HDMI cable i ordered but tested this and works ok connecting various ways also i even removed the 10m cable form the setup and still have the same issue.
I don't fancy changing the AVR with dual HDMI output as i'm still not convinced if that will work since i tried a HDMI dual output splitter and still did not work and its a bit pricey for me to replace the Onkyo 805.
Anyone got any ideas or suggestions?
ps2user is offline
post #2 of 3 Old 09-02-2013, 04:29 AM
springmaker's Avatar
Its probably a hdmi issue one thing to try turn off any hdmi control settings in the denon its used for arc and turning all equipment of at once but can sometimes cause other issues clearly the pc cant talk to projector when denon is in between thats why no sound or picture.
I can also add I had some issues with some of my graphics cards over a long hdmi cable some worked fine others couldnt connect.
Turn off hdmi control in projector aswell if it has it.
Update graphics drivers on pc.
springmaker is offline
post #3 of 3 Old 09-07-2013, 03:04 AM - Thread Starter
ps2user's Avatar
Turned out I had to create a new inf file for eido ( not sure if I spelt it right) and now it's sorted :thumbup:
ps2user is offline
Reply Home Theater Computers
