Why does my PC say "native" under the 1080i resolution? (connected to TV) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 09-03-2013, 06:51 AM - Thread Starter
WeApOn's Avatar
Quoted: 35 Post(s)
I have a primary monitor attached to my PC via DVI-D. I also have a TV connected in this manner:
PC--->HDMI OUT--->Yamaha Receiver ---> 50ft HDMI --> Panasonic TV
It is a newer Yamaha Receiver and a 2012 Panasonic TV, so I know both should support 1080p and passthru.
However while I am in the NVIDIA Control Panel, I see listed under "change resolution" the word "native" next to the 1080i resolution.
I am able to choose 1080p output, and it works fine, but I am wondering if something is not set up correctly. I also am concerned that I am seeing some type of aliasing.. it looks very poor in fast motion. Very hard to read text, almost a blur. Now that could simply be that my particular TV has a poor refresh rate, but I wanted to make sure the 1080i/p aspect was working properly. Is there any way I could test?
WeApOn is offline
post #2 of 14 Old 09-03-2013, 08:49 AM
cybrsage's Avatar
Liked: 154
Go into the setup menu of your TV and see if it has the resolution set to 1080i or 1080 30Hz, or some such. Also check the Yamaha and see what it is set to. It sounds like one of them is set to interlaced instead of progressive.
cybrsage is offline
post #3 of 14 Old 09-03-2013, 06:07 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
You do not set 1080p or 1080i anywhere in a Tv.
You can set the output mode in an AVR to passthough or upconvert etc (but that has nothing to do with what modes the graphics card sees as native or available).
Comes down to EDID from the AVR. The AVR will tell the gpu what it's native resolution is. You can't change that anywhere in the AVR settings (see EDID override thread if needed).
What model is the AVR ?
What model is the Tv?
What gpu?
What version nvidia drivers?
What happens if you disconnect the dvi monitor and set the Tv hdmi as single display primary?
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is online now
post #4 of 14 Old 09-03-2013, 06:20 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
50' of cable is really pushing the limits of the Yamaha's HDMI output. I tried 2 - 50 footers with no success until I swapped it out with a 35'.
Dropkick Murphy is offline
post #5 of 14 Old 09-03-2013, 08:29 PM
assassin's Avatar
Quoted: 81 Post(s)
Liked: 242
Try a redmere cable for long hdmi runs.
assassin is offline
post #6 of 14 Old 09-04-2013, 09:16 AM
cybrsage's Avatar
Liked: 154
I was sure of it, so I looked at my manual again. It allows me to force the video source to send a specific style of video via HDMI-CEC. That is what I was thinking of and confused it.
If the OP is using HDMI-CEC (aka HDMI control, Viera Link, etc), turn it off and see if it fixes the problem.
cybrsage is offline
post #7 of 14 Old 09-04-2013, 10:53 AM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Interesting. That might have an effect on what format the AVR chooses to output to the Tv. But how would it change the EDID that the AVR sends to the GPU? Isn't EDID hard coded into the "display device" (which is the AVR in this case)?
post #8 of 14 Old 09-04-2013, 03:51 PM - Thread Starter
WeApOn's Avatar
Quoted: 35 Post(s)
Although the word (native) appears next to the 1080i output, I am able to set 1920x1080 with a 60hz refresh rate.
If I can confirm that I am getting 60fps, then I know I am running in 1080p, correct?
WeApOn is offline
post #9 of 14 Old 09-04-2013, 04:55 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Press INFO or RECALL on your Panasonic Tv remote. What does it say on your Tv?
Suggest you provide more details-
What model is the AVR ? Is it set to passthrough or set to upconvert all signals to 1080i or 1080p?
What model is the Tv? Do you have CEC turned on?
What model is the gpu?
post #10 of 14 Old 09-04-2013, 08:55 PM - Thread Starter
WeApOn's Avatar
Quoted: 35 Post(s)
Sorry, meant to give more details earlier.
Yamaha RX-V673
VIERA TC-L42E50
Unsure about CEC, where can I check?
Gigabyte GTX 670
Drivers from this June
I AM seeing 1080p listed when I press my info button -- thanks for that tip. According to that, it sounds like I am fine? Regardless of what the PC/AVR thinks the native resolution is, I seem to be running in 1080p/60.
I just had noticed some bad response time or something, which might be the case. I am playing PC games on this monitor, and it might have a slow response time.
WeApOn is offline
post #11 of 14 Old 09-05-2013, 07:36 PM
cybrsage's Avatar
Liked: 154
Yep, if it shows 1080p then that is what you are getting. You can keep troubleshooting if you like, but personally I would not bother since it is working fine as it is. I would just press the "I believe" button and go on with my life. smile.gif
cybrsage is offline
post #12 of 14 Old 09-05-2013, 10:26 PM
fitbrit's Avatar
Quoted: 54 Post(s)
Liked: 50
I'm seeing the same thing with recent versions of nVidia drivers. I've had to make a custom resolution to fix this, and I knew that it wasn't an issue a while back. However, I have changed my AVR and other set up since then too, so it might not be the drivers alone.
fitbrit is offline
post #13 of 14 Old 12-31-2014, 08:07 AM
Liked: 0
Hi,
I have a similar problem. I connect PC>Receiver>Monitor and for monitor resolution in settings on PC I can see 1080p recommended, while the monitor is showing maximum resolution as 1200p in its settings. I've spent ages googling, and cannot fix this....
But the weirdest part is, that with an older receiver, everything worked fine - I connected PC>AVR>Monitor and could set proper 1200p resolution for the monitor. However with newer AVR this 1200p disappeared. Could it be fault of new AVR? (It worked with Denon X2000, now I have Denon X2100, everything should be the same with them..).
phemark is offline
post #14 of 14 Old 01-10-2015, 09:22 AM
Liked: 0
So spoke with Denon support, sent them EDID files, and they confirmed that X2100 doesnt support any resolutions in the range of 1080p-2k (they support those 2 though), so that is the reason it couldn't output to my 1200p monitor with that resolution.
They said it was because of stricter chip in X2100 (as I can do this fine in X2000).
phemark is offline
Reply Home Theater Computers
