Pro Logic IIx not working with 5.1 audio - AVS Forum | Home Theater Discussions And Reviews
Old 09-03-2013, 09:17 PM - Thread Starter
idividebyzero's Avatar
Quoted: 32 Post(s)
When I set the windows settings to 7.1 speakers Pro Logic IIx doesnt use the side speakers with a 5.1 source. I only get sound out of the speakers when playing a 7.1 PC game (I dont have a bluray player installed right now so I havent tested video). If I set the speakers to 5.1 then it works, but I will lose true 7.1.
It works like it should on the PS3 but not the PC, is there a setting somewhere or does it just not work with 7.1 speaker config?
idividebyzero is offline
Old 09-03-2013, 10:32 PM
fitbrit's Avatar
Quoted: 54 Post(s)
Liked: 50
In 7.1 mode, your PC is sending out a null signal over the rear channels. Your AV receiver isn't matrixing the rears because it thinks it's getting a "real" rear signal, albeit a silent one.
Are you using HDMI as an output, or spdif or something else?
fitbrit is offline
Old 09-04-2013, 06:55 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Windows Audio Engine upmixes 5.1 to 7.1 (if your speakers setting in Windows is 7.1) with null signals in the two channels. The solution is bypass Windows Audio Engine by WASAPI exclusive mode.
renethx is offline
Old 09-04-2013, 06:18 PM - Thread Starter
Quoted: 32 Post(s)
Im using HDMI (nvidia)
How do I do WASAPI exclusive mode? Is it just the "allow applications to take exclusive control" checkbox in the playback device properties? I already have those 2 checked.
I changed the speaker configuration in Shark007 to "same as input" and that fixed the 5.1 files, but the LPCM stereo stuff still doesnt work with Pro Logic, which is my main goal. LPCM is also a lot louder that it should be and doesnt sound as good.
Is there a way to get LPCM stereo set as 2 channels instead of 7.1?
Old 09-04-2013, 11:35 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
It is the audio renderer's role to select WASAPI shared mode (normal mode) or exclusive mode. Audio renderer that support WASAPI exclusive mode are ReClock, MPC-BE's audio renderer, JRiver MC, MediaPortal, XBMC.
Only in WASAPI exclusive mode, you will get unmolested LPCM.
renethx is offline
