XBMC with WHS2011 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 09-06-2013, 07:55 AM - Thread Starter
bkinder83's Avatar
Quoted: 13 Post(s)
I have been getting stuttering in XBMC while streaming movies lately that I feel are being caused by my server. High and low quality videos begin stuttering and recording "CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available" errors in the XBMC log that I have been fixing by rebooting the server. Does anyone have any ideas I could try to correct this?
XBMC Log:
http://pastebin.com/Wd74cafD
HTPC:
Win 7 SP1 x64
8 GB Ram
Intel i3-3320
Integrated Intel 2500 Graphics
XBMC 12.2
Server:
WHS2011
8 GB Ram
Pentium G630T
All machines are hardline on a gigabit network.
bkinder83 is offline
post #2 of 14 Old 09-06-2013, 08:05 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
XBMC has crappy playback with DVXA; it's broken
Mfusick is offline
post #3 of 14 Old 09-06-2013, 08:17 AM - Thread Starter
bkinder83's Avatar
Quoted: 13 Post(s)
I disabled DXVA hardware acceleration and selected software as the render method over DXVA after hearing there were issues using Intel GPU and DXVA. Is this not enough to avoid its ill effects?
post #4 of 14 Old 09-06-2013, 08:42 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
Sometime stuttering in XBMC is an audio issue -- like trying to send HD audio to a device that does not support it. The XBMC Wiki has more info.
StardogChampion is offline
post #5 of 14 Old 09-06-2013, 09:36 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
That is 100% correct. Make sure you are bitstreaming to something that can handle the stream. Bitstreaming DTS-HD to a TV monitor, for example, is going to not play or playback with stuttering.
Also you might want to consider an Intel Gigabit NIC. Since I have added one my speeds and stability went up.
assassin is offline
post #6 of 14 Old 09-06-2013, 11:50 AM - Thread Starter
bkinder83's Avatar
Quoted: 13 Post(s)
I have it running to a Harman Kardon AVR 3550HD which has DTS-HD and Dolby True HD capability.
The mobo on the server has an Intel 82579V LAN chipset and the HTPC is using Realtek 8111E. Both are gigabit. Do you think getting an Intel Gigabit NIC for the HTPC could correct this then?
The one thing that has me feeling it is server related is the fact that once the server restarts all stuttering goes away with only having to restart the video on the HTPC side. The server is a dedicated media server so I'm certain it isn't having the processor or memory stressed.
post #7 of 14 Old 09-06-2013, 12:59 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Slow hard drive or slow LAN ?
I would test both.
There's programs and instructions for doing both in my server thread if you need them.
I would check your LAN speed and also run a HDD test.
You could just try copy and pasting a problem movie and check your speed. If its over 50mb/sec then you know neither are your problem. In which case XBMC crappy player is the culprit. Double check settings or re install XBMC.
Have you tried other external players in the same problem movies ?
Mfusick is offline
post #8 of 14 Old 09-06-2013, 11:42 PM
Tong Chia's Avatar
Looks like a potential problem with DTS streaming.
Try playing back something with another type of audio like Dolby Digital and see if it makes a difference.
Tong Chia is offline
post #9 of 14 Old 09-07-2013, 02:22 AM
DavidT99's Avatar
Quoted: 13 Post(s)
Some valid random ideas provided but no structure. You need to eliminate areas of potential issues in a structured way. I would start by taking the htpc out of the equation and test a movie to another streaming device running MPC or VLC whilst connected to the same LAN point, if no stuttering then look further at the htpc, if stuttering move on to the network and work backwards to the server.
David
DavidT99 is offline
post #10 of 14 Old 09-07-2013, 02:48 AM
DavidT99's Avatar
Quoted: 13 Post(s)
Do you monitor your hdds smart data? Ii use the WHS add-in Home Server SMART 2013
DavidT99 is offline
post #11 of 14 Old 09-07-2013, 11:51 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
A simple copy paste of a problem movie to and from server and HTPC can confirm with the copy speeds two things:
LAN speed and HDD speed ok.
If you get 50mb/sec or higher your fine on both.
Then you can quickly move to the HTPC as problem area ... Trying another player or re installing
Mfusick is offline
post #12 of 14 Old 09-08-2013, 09:41 AM - Thread Starter
bkinder83's Avatar
Quoted: 13 Post(s)
David
Unfortunately (or maybe fortunately?) the stuttering is not consistent . I feel it is occurring after a certain uptime on the server. Once I get the stuttering again you are definitely right that I should go to a different computer and try streaming there before restarting the server to get smooth playback.
Ran the LAN Speed Test software from your server thread and am getting ~90MBps write/read speeds between Server and HTPC. I tried stopping the FlexRaid storage pool to test each drive individually and once the pool was stopped no drives (other than C:) showed in My Computer. Do you think this is indicative of an issue with my onboard SATA controller?
post #13 of 14 Old 09-08-2013, 11:16 AM
DavidT99's Avatar
Quoted: 13 Post(s)
Originally Posted by bkinder83 View Post
.......................... I tried stopping the FlexRaid storage pool to test each drive individually and once the pool was stopped no drives (other than C:) showed in My Computer. Do you think this is indicative of an issue with my onboard SATA controller?
This is how flexraid works, it takes away the drive letters. Go to Windows disk management and reallocate the drive Letter's.
David
DavidT99 is offline
post #14 of 14 Old 09-11-2013, 04:47 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Your drives are still there.
Mfusick is offline
Reply Home Theater Computers
