Intel DG45FC Motherboard - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-08-2013, 07:57 PM - Thread Starter
olschl's Avatar
Will the DG45FC motherboard accept an Intel Core 2 Duo E8400 CPU? I am currently running an E5200 CPU in my HTPC and was thinking of upgrading for a little better performance. Any thoughts appreciated.
olschl is offline
post #2 of 3 Old 09-08-2013, 08:49 PM
im bored's Avatar
Intel Desktop Board DG45FC
- uses socket LGA775
Intel Core2 Duo Processor E8400
Intel Pentium Processor E5200
The answer is Yes you can use which ever CPU you would like.
Seams like performance wise this is the difference
http://www.cpu-world.com/Compare/383/Intel_Core_2_Duo_E8400_vs_Intel_Pentium_Dual-Core_E5200.html
im bored is offline
post #3 of 3 Old 09-11-2013, 08:38 PM - Thread Starter
olschl's Avatar
Thank you sir. Doesn't appear to be that much of a performance gain. Thanks for taking the time to post.
olschl is offline
Reply Home Theater Computers
