Stuttering Issue...Please Advise - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 09-09-2013, 08:40 AM - Thread Starter
monsterzero2001's Avatar
Quoted: 16 Post(s)
My first post here,and have done a search looking for my specific problem but couldnt find it,so forgive if this is a previously addressed topic.
Im having a serious stuttering problem with my home theater setup.It normally occurs on files over 9GBs
I have a 1TB Seagate portable hard drive plugged into my Samsung Bluray player via HDMI,which is then fed into my Yamaha V861,again via HDMI and then video out to my Samsung es8000 TV
One smaller files the playback is flawless,but on larger full 1080p rips the video and audio stutters,pausing,starting again and so on...sometimes only a couple times,then like last night on a 21GB rip of Prometheous it was so bad it was unwatchable.
Any ideas,suggestions on fow to fix this?
Sony HW40ES,100" DragonFly Screen
Rogue Audio Cronos Magnum,GoldenEar T2
Cambridge Audio Azur 752BD
NAD T758,GoldenEar Super Center XL,GoldenEar SuperSats
Woo Audio WA2,BeyerDynamic T1,Sennheiser 600
PS3,PS4-monsterzero2012
monsterzero2001 is offline
post #2 of 18 Old 09-09-2013, 09:26 AM
Copyright28's Avatar
Quoted: 17 Post(s)
What media player are you using? What are the specs on your HTPC?
Copyright28 is offline
post #3 of 18 Old 09-09-2013, 09:51 AM - Thread Starter
Quoted: 16 Post(s)
Im not using any media player,nor is there a PC connected to the system.
The source is 1TB plug and play Seagate directly into HDMI in my Bluray player.Smaller files (6GBs and less) play fine...bigger files stutter both audio and video.
post #4 of 18 Old 09-09-2013, 10:16 AM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Originally Posted by monsterzero2001 View Post
...I have a 1TB Seagate portable hard drive plugged into my Samsung Bluray player via HDM...
I'm guessing you mean USB. Bluray players don't usually have HDMI Inputs (unless it's a home theater in a box). Portable hard drives don't usually have HDMI Outputs (unless it's a Go Flex). What are the model numbers of the bluray player and the portable hard drive?
If it's a Go Flex, just bypass the Bluray player and AVR, plug it directly into the Tv. Does it still stutter?
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #5 of 18 Old 09-09-2013, 10:25 AM - Thread Starter
Quoted: 16 Post(s)
Yup,youre right,USB is correct...the problem with bypassing the BluRay player then im using only optical out for audio which means no DTS...
post #6 of 18 Old 09-09-2013, 10:28 AM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
What is the model number of the Bluray player?
Does it have the latest Firmware?
post #7 of 18 Old 09-09-2013, 10:35 AM - Thread Starter
Quoted: 16 Post(s)
Samsung 5500 xt
This model
http://www.amazon.co.uk/Samsung-BD-E5500-Blu-ray-Player-Smart/dp/B007L3Z086
No idea how to check if the firmware is up to date,and dont know whow to update it....sorry,im kinda clueless on this stuff
post #8 of 18 Old 09-09-2013, 10:42 AM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
BD-E5500 Support goto Firmware
monsterzero2001 likes this.
post #9 of 18 Old 09-09-2013, 11:00 AM - Thread Starter
Quoted: 16 Post(s)
okay so im downloading the update to a USB thumb drive...its a ZIP file,do I need to open and extract first or...?
post #10 of 18 Old 09-09-2013, 11:12 AM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Yes, follow the Instructions CAREFULLY
post #11 of 18 Old 09-09-2013, 11:32 AM - Thread Starter
Quoted: 16 Post(s)
okay,I ended up running a LAN line into the Bluray player and accessed update firmware from the menu,and the firmware is already up to date.
Anything else it could be?
post #12 of 18 Old 09-09-2013, 12:08 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Where are you getting these movie rips?
Do they play fine on the computer that created them?
If you put the original disc in that bluray player, does it play ok?
post #13 of 18 Old 09-09-2013, 12:26 PM - Thread Starter
Quoted: 16 Post(s)
yeah they play fine on my computer,but my comp is a 32" with a 2.1 sound,whereas my home theater is 55" with 5.1 surround so playing on computer,while it works isnt really an option I want to pursue for obvious reasons.And yes the discs play fine on the system,its just the rips that mess up.
I was hoping perhaps it was a setting,or a cable issue,but at this point I have no idea what it is...
post #14 of 18 Old 09-09-2013, 01:21 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Is that playback on the PC from an internal drive or the same USB external storage?
Do you have copy of the rip on internal drive of the PC?
Now that you have the bluray player connected to the LAN, does it allow you to see shared folders/files on the PC? Try playing the rip via network?
post #15 of 18 Old 09-09-2013, 02:07 PM - Thread Starter
Quoted: 16 Post(s)
dont have a networked system,just an old desktop...
The files play seamlessly on the computer off of the portable disc and off the internal hard drive,though I usually dump them off the computer to save space.
I appreciate you trying to figure this out for me!
post #16 of 18 Old 09-10-2013, 10:27 AM - Thread Starter
Quoted: 16 Post(s)
Today I tried various trouble shooting changes to fix the problem
Took the harddrive to a friends house...all files played seamlessly.
Swapped the HDMI cables from the PS3 to Bluray.
Changed upscaling settings on receiver
Updated the firmware on TV.
Tried different smoothing settings on the TV.
The problem still persists with large files.
Is it possible that its receiver not being able to process huge amounts of info all at once?
I noticed on the panel of the receiver that whenever the stutter occured the info switched from DTS to Pro-Logic,and then back to DTS when the stutter corrected
post #17 of 18 Old 09-10-2013, 10:52 AM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Bypass the AVR - plug the bluray player directly into the Tv. What happens?
post #18 of 18 Old 09-11-2013, 07:16 AM - Thread Starter
Quoted: 16 Post(s)
I found the problem...here in Thailand shops on occasion can be very helpful when they smell a potential sale.
I dragged my hard drive over to a high end A/V shop here in Bangkok,and the files(yes they were .mkv) played flawlessly through their setups.
They agreed to come to my house and brought with them some high end HDMI cables,but the problem still persisted.
Then they unboxed an Oppo 103 and we tried that,and it played perfectly! The 100.00 Samsung bluray player was the culprit...
Unfortunately the Oppo was too long to fit into my theater furniture,so I will have to add another tier to the top,place the Oppo,under it,and then the TV on top of that.
But after reading the specs on the 103 vs.105,I think I will splurge for the 105 and those amazing Sabre DACs
Thanks Hammerdwn!
Reply Home Theater Computers
