Subwoofer + HDMI output - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-10-2013, 06:33 AM - Thread Starter
KooSoul's Avatar
I have the weirdest problem. When I first installed my surround 5.1 + receiver to HTPC, it was working perfectly fine. Now all of a sudden the subwoofer output really low volume (I'm bitstreaming, and it shows DTS-HDMA on receiver or TrueHD) I uninstall HDMI driver, disconnected subwoofer, reset receiver I tried everything...even sound setting in control panel, I still can't get subwoofer to output correctly...
Someone please help me, I'm really desperate...tried 3,4 days without success it's so frustrating..., could it be my subwoofer? it's only 2 weeks old. BTW every other channel's sound level is good except subwoofer, can barely feel it and it's not placement either since I haven't changed the placement...I tried 2 different graphic card also, same result...dunno what else could it be... is it possible that bitstreaming is outputting lower LFE level for some reason?
Receiver: Pioneer VSX-43
Windows 7 64bits
KooSoul is offline
post #2 of 7 Old 09-10-2013, 08:49 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
What is your crossover point for the sub? Is the sub set up as LFA or Main+LFA. Please note, nomenclature may differ between AVR manufacturers, but should be covered in the Owner's Manual that came with the AVR.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #3 of 7 Old 09-10-2013, 09:03 AM - Thread Starter
KooSoul's Avatar
it's set at 80 Hz and I tried both LFA and Main (Subwoofer and Plus under pioneer). I still get signal sent to subwoofer but it's output very low. It was working perfectly until few days ago all of sudden its output became really low...could it be the subwoofer failing?
KooSoul is offline
post #4 of 7 Old 09-10-2013, 11:04 AM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
Do you have another receiver you can try the sub on? Have you checked the sub trim on the receiver and the gain on the sub?
Mrkazador is offline
post #5 of 7 Old 09-10-2013, 12:15 PM - Thread Starter
KooSoul's Avatar
I don't have another receiver unfortunately...but what is sub trim? I'm not aware of this function, I have a pioneer elite vsx-43 I read the manual but I didn't find it... How can I make it show? thanks
KooSoul is offline
post #6 of 7 Old 09-10-2013, 12:27 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
The sub trim is the sub level, default value should be 0db. Check to see if its not set to something very low like -12db. If you bitstream audio from the HTPC then you can rule that out because its not processing the audio. Its either the receiver or sub that is causing the problem.
post #7 of 7 Old 09-10-2013, 02:14 PM
Ruiner's Avatar
Test by using the analog subwoofer output on your motherboard. You'll probably need a 1/8 to RCA adapter.
Ruiner is offline
Reply Home Theater Computers
