Record SPDIF from DAT under Windows 7 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-10-2013, 01:41 PM - Thread Starter
originalsnuffy's Avatar
Hi all,
I have a professional Tacam DAT player, and want to transfer Grateful Dead dubs (no SCMS) into the Windows 7 PC and record them. Under XP there is no problem. I can feed the coax spdif output from the DAT into the SPDIF input on my Creative Audigy platinum panel. I fire up Total Recorder, and can easily record. So I know that all hardware works and is compatible.
However, under Windows 7 this does no work. I can play the DAT through the PC, but it will not record. Everything comes out garbled. My understanding is that Windows 7 is designed to block the spdif inputs. I tried a number of programs to "reroute" the audio signal, but nothing worked.
Is there some kind of workaround or is this a lost cause under Windows 7 ?
originalsnuffy is offline
post #2 of 2 Old 01-03-2014, 09:12 PM - Thread Starter
smile.gifTurns out the the Daniel k modified audiigy drivers solved the problem.
Reply Home Theater Computers
