My SG08 HTPC/Gamer build.. - AVS Forum | Home Theater Discussions And Reviews
Old 09-11-2013, 08:18 AM - Thread Starter
Copyright28's Avatar
Quoted: 17 Post(s)
So I kinda went a little overkill on the HTPC steup but in the end I have a machine I can game on in the living room when I have company over. Here are some pics of it mid way built and fully built. The case wasn't that hard to cable but it took some time. There are a few things I could have done cleaner but at the end of the day there is really no Window to show off anything so I was happy with the end results.. FYI the Geminii S524 cooler was mounted with no bottom plate (Asus P8H77-i has stuff in the way) and just the nuts with some insulated washers. I have seen a few ppl do this and felt ok with it. With the cooler fully tightened the board was not warping and I ended up getting 10C cooler load temps over the Vortex Plus and the CPU fan never got over 900 RPM. So the end result was a VERY quiet HTPC even under full load in Prime95.
Specs..
i3 2125
Coolermaster Geminii S524 w/Noctua 120mm NF-F12 PWM Fan
Samsung 1600mhz DDR3 8gb
Asus P8H77-I motherboard
MSI 7790 1gb w/Noctua NF-A9x14 92mm fan mod (much quieter than stock fan)
Silverstone SG08 w/Noctua NF-S12A 120mm PWM Fan
Panasonic Bluray Slim
Copyright28 is offline
