Need advice: Rebuilding Mom's HTPC for 3D (case and PSU and GPU card advice needed) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 09-12-2013, 11:18 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Hi All,
I built my parents a cheap HTPC they have enjoyed for the last year. The current machine is:
G630 CPU
Asrock Z68 mobo
120GB vertex 3 SSD
4TB Seagate storage (old 5 platter version)
8GB ddr3 1600mhz.
Crappy desktop case and PSU.
I'm in process of rebuilding it mostly because my dad has a new EPSON 1080p projector that does 3D with glasses and he's interested in using it.
I'm torn on what to do or how to do it. I could add a GPU card for 3D support, or I could swap put the CPU with a 3D capable CPU. Since its older Z68 I am wondering if I'd have to flash the bios to support ivy bridge ? Worth it over just getting a cheap GPU?
The monkey wrench is that I think I want to change the form factor to a HTPC style component case from the desktop case so my dad can locate it on a shelf with his AVR. (Denon AVR3313IC) (Both are in a laundry closet and hidden).
I'd like a low profile case (height) but that messes up GPU card choices because I need to make sure the GPU fits. Otherwise integrated CPU 3D leaves this as non issue.
Lastly - I'm looking for max value here. My parents are not very discerning about these matters or well educated on differences. The cost and simplicity is paramount.
What's good case and PSU (deals available?)
What's best way to get 3D? GPU card and keep G630 CPU ? Which GPU card ? (No MADVR needed). Or, which high value CPU ?
Mfusick is offline
post #2 of 17 Old 09-12-2013, 03:57 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
mini-ITX the whole way. Trust me. Mom will love you more than if you build her a big beige tower.
BTW, motherboard model number will help with suggesting a case.
StardogChampion is offline
post #3 of 17 Old 09-12-2013, 04:26 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
ATX or M-ATX tongue.gif Sorry I thought I said that.... lol.
I can actually pick out a case... just wondering more how to match up the GPU card and the case (without going full height) so I guess I am asking what is a good GPU card that can do half height and 3D without spending too much. (CHEAP!) They will never do madvr or games. Or, is it better to grab a CPU instead of GPU.
Opinions ?
I can pick out a case and PSU, but I would love pointers on specific models and why, and most importantly pointers on good sales or available deals. I could actually keep the case I guess... and go full height GPU but that takes up space in mom's laundry closet. lol. It's half laundry and half electronics. The DirecTV receiver, bluray, router, switch, surround receiver are all located there so it's a good place for a HTPC. I am really pretty flexible on the case. I guess I am confusing the issue by asking about that.
GPU vs CPU ? What say you ?
Mfusick is offline
post #4 of 17 Old 09-12-2013, 04:41 PM
Dark_Slayer's Avatar
Quoted: 660 Post(s)
Liked: 434
If the AVR is hidden in a laundry closet, why bother? Or bring the AVR out and keep the HTPC hidden.
Also, software is the real monkey wrench on 3D (IMO). It's not worth the fuss for me, and I feel like I'd use it 2-3 times right after I got everything setup (and to show off) then never again.
If it were my parents, I'd try a GT 610 and a trial PDVD13 or TMT to see how they like it. It seems like the 610 is acceptable, but hopefully Renethx will weigh in with his many pearls of 3D wisdom
Dark_Slayer is offline
post #5 of 17 Old 09-12-2013, 05:34 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
The only reason to swap cases it to put it on the AV rack shelfs and free up the bigger shelf for other crap (laundry detergent lol )
I built the PC when it was in another location, I would have went with a component style if I knew then it would end up here. My dad wanted everything moved here.
Mfusick is offline
post #6 of 17 Old 09-12-2013, 06:04 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Adding a discrete card is easier and cheaper. E.g. Sapphire HD 6570 (100323-2L), $40 AR, (a low-profile bracket included).
renethx is offline
post #7 of 17 Old 09-12-2013, 08:39 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Thank you biggrin.gif That's what I was thinking
Mfusick is offline
post #8 of 17 Old 09-24-2013, 04:14 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
What's best player for 3D ?
Mfusick is offline
post #9 of 17 Old 09-24-2013, 04:22 PM
staknhalo's Avatar
Quoted: 383 Post(s)
Liked: 241
either TMT or PowerDVD. I prefer TMT just cause it blends/integrates better with WMC.
staknhalo is offline
post #10 of 17 Old 09-25-2013, 07:54 AM
laverdure's Avatar
+1 for TMT. Seamless integration with WMC/MB, just like MPC-HC. Harmony remote commands worked right out of the gate too.
laverdure is offline
post #11 of 17 Old 09-27-2013, 02:38 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
What is the best way to get it ? Is it just for ISO or disk playback ? How about F-SBS or H-SBS MKV's ?? What player for those ?
Mfusick is offline
post #12 of 17 Old 09-27-2013, 11:02 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
ISO works best. Ripping (actually re-encoding) in SBS (full or half) is not so good: takes a long time, a larger file (full) or resolution halved (half). If you want to rip in MKV, use MakeMKV, that will keep MVC. But TMT does not support this format, PowerDVD does, so does Stereoscopic Player.
renethx is offline
post #13 of 17 Old 09-28-2013, 08:23 AM
slosvt's Avatar
Quoted: 59 Post(s)
Liked: 29
Would an Intel g1610 and this card do 3d?
slosvt is offline
post #14 of 17 Old 09-28-2013, 08:26 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Awesome ! I will check it out. Mom and Dad are in FL for two weeks and I want to go get this set up before my dad comes home (and supervises me rolleyes.gif )
He really wants to try 3D and get it working because his new projector (Epson) came with some 3D glasses. Personally I am not that interested in doing 3D myself, and I am assuming this is one of those things where I spend a day setting it up, and $50 on a GPU card for their HTPC but it basically goes unused. Oh well.. tongue.gif
Mfusick is offline
post #15 of 17 Old 09-28-2013, 10:58 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Yes.
MVC (BR 3D codec) decoding:
ISO/ODD+TMT/PowerDVD: decoding is done by UVD in GPU, so any processor should be good.
MKV+PowerDVD/Stereoscopic Player: decoding is done by CPU, G1610 is fast enough.
Frame packing 3D output:
The Radeon card can do this.
renethx is offline
post #16 of 17 Old 10-13-2013, 07:06 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
I have a question....
Does the performance of something like a $60 3.0gz dual core Pentium with a $40 Radeon for a total price $90-$140 as a combo have better performance than an i3 for same total price ? On matters of MADVR ? 3D or Gaming ?
Would a 6570 + a dual core beat out an upper level i3 ?
Mfusick is offline
post #17 of 17 Old 01-18-2014, 02:11 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Where has renethx been ?
Mfusick is offline
Reply Home Theater Computers
