*OPTIMAL* settings for Handbrake? (Blu-ray and DVD rips) - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #121 of 136 Old 01-13-2016, 07:17 AM
Doug Schiller's Avatar
Originally Posted by g4s View Post
MakeMKV has kind of a strange business model. DVD functionality is free. Blu-ray ripping has a 30 day trial. http://www.makemkv.com/buy/
They should never charge while in beta.
It is strange for me, on one PC, the 30 day timer never starts, on the other it is down to like 23 days.
Doug Schiller is offline
post #122 of 136 Old 01-13-2016, 07:36 AM
g4s
g4s's Avatar
Yeah, they've been in beta for 6 or 8 years it seems to me. There must be some legal snag that comes up when selling something that decrypts. Maybe staying in beta forever avoids those problems? Good software though.
g4s is offline
post #123 of 136 Old 01-13-2016, 08:09 AM
Wow, you are right.
I am so used to running AnyDVD, I forgot that MakeMKV doesn't need it.
post #124 of 136 Old 01-13-2016, 10:20 PM
olds97_lss's Avatar
Quoted: 12 Post(s)
So, MakeMKV doesn't need it for any blu-ray? What about DVD's?
olds97_lss is offline
post #125 of 136 Old 01-13-2016, 11:57 PM
Aleron Ives's Avatar
Quoted: 1580 Post(s)
Liked: 1289
MakeMKV cracks all commercial copy protections on its own. I still use DVD Decrypter for DVDs, but MakeMKV can handle them, too.
Aleron Ives is offline
post #126 of 136 Old 02-03-2016, 04:12 PM
Liked: 0
Originally Posted by ixion View Post
Constant width in Handbrake:
Since most movies are widescreen with black bars, when I say “1080p”, I’m really referring to a constant width of 1920. And when I say “720p”, I mean constant with of 1280. And for SD material, I use a constant with of 720. So in Handbrake, I always set the preset to the max width (either 1920, 1280 or 720) and set the height to 0. By doing this, Handbrake will crop the black bars and ignore the actual real height and will preserve the aspect ratio (using my settings below).
My Handbrake settings:
Source: Bluray 1080p Movie
Watch on: Projector
Format: MKV
Picture: 1920 width, loose anamorphic modulus 2, autocrop
Filters: all off
Video: H.264, RF21, FPS same as source, x264 medium, tune None, profile High, Level 4.0
Audio: Auto Passthru
Can you elaborate on this part in bold if possible please ? I've followed your Picture settings. And when i try to set height to: 0
Handbrake makes a beep sound when i click out of the text box. If i click out of this screen it resets to the auto crop height number.
My output files seem to look very similar aspect wise when left autocrop, but the ratio differs slightly from the source.
I'm running the latest stable build for mac.
mmerkin is offline
post #127 of 136 Old 02-04-2016, 09:52 AM
Liked: 0
If you're using Loose anamorphic formatting, you don't need to set the Height value at all. It will be automatically determined by the Width and Modulus settings you choose. Selecting "Automatic" under the Cropping section will tell the program to scan the source to find proper values there, as well.
Zarggg is offline
post #128 of 136 Old 02-05-2016, 07:52 AM
Brian Hampton's Avatar
Quoted: 572 Post(s)
Liked: 302
I bought Makemkv.
I think optimal settings for handbrake start with uninstall
10k likes this.
Brian Hampton is offline
post #129 of 136 Old 02-05-2016, 01:13 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Originally Posted by Brian Hampton View Post
I bought Makemkv.
Please elaborate how MakeMKV can help compress the rips into different sizes and formats like Handbrake can do (and with the support Intel HQV as well)?
Foxbat121 is offline
post #130 of 136 Old 02-05-2016, 01:18 PM
Quoted: 572 Post(s)
Liked: 302
Well ... it doesn't... but the best compression in this case is no compression. It's actually the one that results in the highest quality.
post #131 of 136 Old 02-05-2016, 02:38 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
That's not the topic of this thread. Apparently, a lot ppl find it useful to re-compress the rip to save storage space. Hence this thread. The presumption is that the movie has been ripped one way or another (MakeMKV or AnyDVD).
post #132 of 136 Old 02-06-2016, 12:13 AM
Liked: 0
I imagine that most people concerned with the purpose of this thread don't want to carry around 30+GB files for our archive/media server, so your "suggestion" comes off as petty.
Zarggg is offline
post #133 of 136 Old 02-08-2016, 06:38 PM
Liked: 0
Ok cheers
mmerkin is offline
post #134 of 136 Old 02-12-2016, 04:59 PM
SeanBuchanan1985's Avatar
Why loose?
Originally Posted by mmerkin View Post
Ok cheers
I am just curious why when encoding a bluray the loose setting is being used... Wasn't that for DVDs? I am just curious because I always select none personally. I have some imax releases such as interstellar and when put in loose or strict the imax parts are cut off (not full screen)... just want to know why using loose for bluray rips? Thanks in advance.
SeanBuchanan1985 is offline
post #135 of 136 Old 02-21-2016, 04:03 PM
Liked: 0
Issue with Bluray display
My Set up
Onkyo Receiver 646- EPSON 2040- Cable- Streaming (Roku)- Bu ray DVD
I changed Blu ray player thinking player i wrong- Changed .Initially I just got voice now I get audio and Video
HDMI deep color- off
Now all movies work good But when I go to home screen it keeps on blinking sometimes. Sometimes it works
Called Onkyo product support - they keep me on phone for 30-40 minutes with no response
Changed HDMI cable
Tested Receiver and Projector and cables independently they worked.
Please suggest /help for making it work and move in the main menu
bkallepalli is offline
post #136 of 136 Old 03-21-2016, 10:30 PM
g4s
g4s's Avatar
Anyone interested in x265 10bit encoding with Handbrake should take a look at this blog I found. It's the only way I've found to encode 10bit color on Macs. 10bit color goes a long way in reducing banding from too much compression. The result is great looking tiny files. Of course you need to check your playback device for compatibility. For me this is breakthrough compression. https://mattgadient.com/2016/02/15/h...linux-windows/
g4s is offline
Reply Home Theater Computers
