Shout out of "Thanks" to whoever recommended the Dell Powerconnect Switch in a thread couple weeks ago - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 09-20-2013, 11:10 PM - Thread Starter
tomandbeth's Avatar
Replaced a couple of dell desktop switches and my home Network speeds increased 15-20%.
Now running 1 each 2708 and 2808. Anyway. Thanks for mentioning these
tomandbeth is offline
post #2 of 15 Old 09-21-2013, 12:16 AM
amarshonarbangla's Avatar
Quoted: 28 Post(s)
Liked: 43
You are welcome.
amarshonarbangla is offline
post #3 of 15 Old 09-23-2013, 05:56 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Your switch speeds things up ? What switch and how much $$?
I never bothered playing around with such things. (I have a consumer level Asus switch )
Mfusick is offline
post #4 of 15 Old 09-24-2013, 10:53 PM - Thread Starter
tomandbeth's Avatar
As the title says,Dell Powerconnects.
a 2816 gives you 16 ports
post #5 of 15 Old 09-25-2013, 12:01 AM
jmelan's Avatar
Quoted: 57 Post(s)
Liked: 33
Replaced my Asus router/switch and dlink with Cisco 8 port switches (sg200-08, 100 ea) and transfer rates are now 120 mb per second.
The dlink switches were running at 80 mb per sec before they all died - killed 2 of them running RDP from my laptop.
I am not buying cheap switches again.
Sent from my GT-I9505 using Tapatalk 4
jmelan is offline
post #6 of 15 Old 09-25-2013, 07:24 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Interesting ... I get what I consider decent performance from my Asus switch ($25 newegg). But I've never gotten 125mb/sec
Usually 100mb/sec only....
Mfusick is offline
post #7 of 15 Old 09-25-2013, 07:56 AM
itznfb's Avatar
Liked: 58
If you're topping out at 100MB/s then you've either got one of those $15~$30 switches or possibly a cheapy NIC. Any half decent desktop switch should be able to just about max out Gigabit. My transfers across the network typically sit right at 240~245MB/s (lacp). That's using a Cisco SG200-26 which is a pretty entry level switch.
Running Windows Home Server 2011 Evil Abandoned Edition
itznfb is offline
post #8 of 15 Old 09-25-2013, 05:23 PM - Thread Starter
tomandbeth's Avatar
I started all this just to clean up the 14U rack the home theater is in. There was a Dlink 8 port switch hanging on the side uggggly
Bought the Dell 2708 as it has rackmount ears and would fit in a 1U slot on the back of the rack. First transfer of ~35 Gig
Movies and meta data and what had been 85 to 100 was 110 to 120. Added the second Dell 8 port and it rarely drops
below 115 now. My switches span a 200 foot run between the server and HTPC.
Just happened to drop by and saw the discussion on switches the night I got fed up with the look of that switch hanging off the side
and fricken happy that there was a nice boost of performance.
I should mention as well that I have "a dozen" IP security cams on this circuit using bandwidth.
post #9 of 15 Old 09-25-2013, 07:24 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I have a $25 Asus 8 port switch from Newegg. I said that above.
I have Intel NIC on both server and desktop and still only get about 100MB/sec average, 110MB most times, but never 120+ mad.gif Even SSD to SSD I get the same so I know it's my LAN
Mfusick is offline
post #10 of 15 Old 09-25-2013, 07:59 PM
itznfb's Avatar
Liked: 58
Is it this: ASUS GX-D1081
Any desktop switch that says Power Saving or Green you can bet won't provide full Gigabit speeds. Typically these cheap 5 and 8 ports desktop switches claim to have switching capacity of 10 and 16Gbps but you never see that in real world usage. With 16Gbps capacity it should be able to saturate all ports up and down at full gigabit.... but they can't even handle a single port at that speed. With all the money you spend on your gear you'd be well served to get a decent $200~$300 Dell/HP/Cisco switch. Get a smart switch that supports lacp and a couple Intel Gigabit CT's and you can team them so you can have 2Gbps up/down. You'll love it.
itznfb is offline
post #11 of 15 Old 09-25-2013, 08:12 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I think I would love this. I am noob at switched and "teaming" and I would need some guidance but I am interested.
Yeah I know I have a cheap Asus switch. I bought it cause it was cheap tongue.gif But again I am noob and did not realize that switched mattered. I thought a gigabit switch went gigabit. Stupid me. I am not that worried about it. 110MB/sec seems ok to me, but I like what you are saying. biggrin.gif
Mfusick is offline
post #12 of 15 Old 09-25-2013, 08:55 PM
itznfb's Avatar
Liked: 58
With how much you hate waiting on your PC tasks I know your researching new switches right now...
itznfb is offline
post #13 of 15 Old 09-25-2013, 09:01 PM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
The inexpensive HP 1400 series don't make an appreciable difference when added in series with my Dell 5324, but I haven't bothered to test to get definitive numbers. Here they sell for circa ~$50 for an 8 port but are unmanaged. Having a couple of managed units like the Dell, unless you're using the added features such as LACP, I'm not seeing much point in them for home use. The Dell does have an independent test done for it that shows it can max out all ports at once, but uses a lot of power doing it (~60W), and has two noisy fans. I paid $60 for the Dell second hand as I wanted it for the SFP ports as I have a ton of them and plenty of fibre interconnects, but never bothered to connect it up as it's quite fast enough as it is.
A9X-308 is offline
post #14 of 15 Old 09-27-2013, 02:40 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I looked quick but prices seems really high...
My $25 Asus gets me 110MB/sec (sometimes a little more) I am not sure 10MB/sec is worth $100+ to me. Am I really supposed to get 125MB/sec ?
Mfusick is offline
post #15 of 15 Old 09-27-2013, 03:23 PM
itznfb's Avatar
Liked: 58
A Gigabit switch should yield about 120MB/s. With single port I get a constant 120~122MB/s up and down. No matter what HDD is being read from or written to (actually I see a slow down with Greens sometimes but I have very few of those left in my network). With two ports teamed I get a constant 240~245MB/s with SSD but the rotating rust becomes the bottleneck there. 4 ports teamed and I need to RAID0 my SSD's to keep up biggrin.gif
itznfb is offline
Reply Home Theater Computers
